LinkBack (1) | Thread Tools | Display Modes |
#61 |
ThinkTank Waterboy
We talked about WBs a while back and with everything things change. At that time innovate was probably the best choice and even that didn't have the range you say this one has.
__________________ Rick Bigelow '96 215k Groveland MA 01834 If you're not the lead dog, the view never changes |
#62 |
Kneel for the Shaman
Whats the thing on the toip of your air can?
Did you guys get the belt thing figured out? Glad your up and running. |
#63 | |
Can you imagine what the board discussions would be like if everybody had your knowledge. We'd be talking about driving remote control Land Cruisers on Mars from our backyard launches. Who needs NASA? __________________ "Passions Testify to Enthusiams for the Cause" F. Dostoevsky 1980 HJ45 Imported from Oz... 1994 80 locked, Supercharged, bored over 1.25mm long Ranger aux. fuel tank with Oz spec overhead gauge set. and other stuff... Adventure Trailer Chaser |
#64 | |
Yes we figured it out, thanks for the prompt return call. If your talking about the plug, it is just that. A 1" plug from NAPA to block it off. I have the benefit of being registered in the portion of our county that currently does not require smog checks. That made me laugh, because when we put it there I commented on how bad it looked. Robbie grinned and said when I felt compelled to remove it and weld the hole up to go ahead and then I wouldn't have to know it was there anymore. __________________ "Passions Testify to Enthusiams for the Cause" F. Dostoevsky 1980 HJ45 Imported from Oz... 1994 80 locked, Supercharged, bored over 1.25mm long Ranger aux. fuel tank with Oz spec overhead gauge set. and other stuff... Adventure Trailer Chaser Last edited by 24HOURSOFNEVADA; 06-29-08 at 12:56 PM. |
#65 |
sounds sweet would love to see some dyno numbers. 4 wheel dyno's a hard to find. thinking about SC ing as well. you HAVE to run premium correct. I know if you put that much money in it why would you run anything less but ouch premium is as much are near the price of diesel. :-<
__________________ was that a speed bump... oh just a smart car 97 FZJ80 locked up on 36s 87 zuki on toyotas, 6.5 tcase, locked, 36s |
#66 |
Welcome to the Robbie-built-Toyota-blown Club!
![]() ![]() ![]() Nick __________________ "Macadamia nuts in mixed nuts?!? Now that's a high class nut mix..." -Anonymous quote heard during a CM08 lunch break in the worm hole on Kane Creek |
#67 | |
Yes, premium is a must with this supercharger. Locally, premium is still about 40-50 cents a gallon less than diesel. At this point, I think all fuel is expensive. __________________ "Passions Testify to Enthusiams for the Cause" F. Dostoevsky 1980 HJ45 Imported from Oz... 1994 80 locked, Supercharged, bored over 1.25mm long Ranger aux. fuel tank with Oz spec overhead gauge set. and other stuff... Adventure Trailer Chaser |
#68 |
Thanks again. The motor is just getting stronger with more miles, or I'm getting bolder with it. __________________ "Passions Testify to Enthusiams for the Cause" F. Dostoevsky 1980 HJ45 Imported from Oz... 1994 80 locked, Supercharged, bored over 1.25mm long Ranger aux. fuel tank with Oz spec overhead gauge set. and other stuff... Adventure Trailer Chaser |
#69 | |
Looks like it turned out fantastic! Well done.
Any chance you could still ask Robbie for further feedback on this? __________________ 1996 LX450 w/ factory lockers, Optima Red Top, HIR 9011 Hi & Low Beams, OME 850J/863, Bilstein HD, ARB winch-bar, 295/75/16 Terra Grapplers, yellow box speedo correction, LED domes, CDL switch w/pin 7 mod. |
#70 |
I'm sure he'll chime in when he gets a second, but I believe his overall impression was very favorable. I don't think he would have given me a warrantee like he did without believing in the parts that were used. You can always send him a pm to hear his personal thoughts on it.
#71 |
As an update, I changed out the 8:1 FMU for a 12:1 FMU. It ads a little more fuel to the thirsty motor. Same brand FMU just a higher ratio. We also think the JE Pistons came out a little higher compression. More like 10:1.
The motor runs very strong. I have put a little over a thousand miles on it so far. Dragged the Adventure Trailer over a couple of high mtn. passes 8000 +/- and Im very impressed with it. __________________ "Passions Testify to Enthusiams for the Cause" F. Dostoevsky 1980 HJ45 Imported from Oz... 1994 80 locked, Supercharged, bored over 1.25mm long Ranger aux. fuel tank with Oz spec overhead gauge set. and other stuff... Adventure Trailer Chaser |
#72 |
I still drool looking at those pics in the beginning of the post. Great write up.
Did you ever get any dyno #'s? __________________ 1994 FZJ80 |
#73 |
which it's your AFR at full boost . ? there any temp issue yet .?
#74 |
ThinkTank Waterboy
So what prompted the realization that you were running lean and needed more fuel?
#75 |
ditto/ why the change in fmu?
__________________ 97lx450 4" slee/j's, sliders, bumpers, 3" exhaust, custom turbo, HG pm/Valve job/seals, sweet custom skid plate, Sleeoffroad parts, Buys oe parts from Cruiser Dan used to have 37" swampers.. 1 tons and 42's pending..... Budget Blown my build http://forum.ih8mud.com/hardcore-cor...j80-build.html 98 100 series. rear locker. 2008 6.7L dodge 2500 quad cab |
#76 | |
Sorry for the delay guys. I've been pretty busy with archery season approaching. So, far she's right around 14 at wot, but see the below post for more info. As far as temps, they have been great. I did replace the radiator with a brand new OEM Toyota during the rebuild. __________________ "Passions Testify to Enthusiams for the Cause" F. Dostoevsky 1980 HJ45 Imported from Oz... 1994 80 locked, Supercharged, bored over 1.25mm long Ranger aux. fuel tank with Oz spec overhead gauge set. and other stuff... Adventure Trailer Chaser Last edited by 24HOURSOFNEVADA; 07-27-08 at 01:36 PM. |
#77 | |
Again, sorry for the delay in the responses. The answer is a simple one. Under Wide Open Throttle (W.O.T.) She still detonated slightly. It's slight, but it's there. An example of how slight it is, I took my father for a ride (He is a former boat and car racer) to demonstrate it. When finished, his quote was "If that's how you have to drive it to get it to detonate, I would say you don't have a detonation problem". So, a quick call to Robbie and it was decided to up the FMU. I'm adding a water/meth injection system next week and will keep you updated. Still learning.... __________________ "Passions Testify to Enthusiams for the Cause" F. Dostoevsky 1980 HJ45 Imported from Oz... 1994 80 locked, Supercharged, bored over 1.25mm long Ranger aux. fuel tank with Oz spec overhead gauge set. and other stuff... Adventure Trailer Chaser |
#78 |
ThinkTank Waterboy
I'd look into an intercooler to help with that verses water meth injection unless of course a WB showed it was still a fueling issue.
#79 | |
As usual, your right on. The shop that is providing the water/met injector is going to look at an air to water intercooler also. I was going to keep that a surprise but oh well. The shop is Infinite Velocity Motorsports in Sparks. They build a lot of motors for D. Trent of Trent Fabrication fame. __________________ "Passions Testify to Enthusiams for the Cause" F. Dostoevsky 1980 HJ45 Imported from Oz... 1994 80 locked, Supercharged, bored over 1.25mm long Ranger aux. fuel tank with Oz spec overhead gauge set. and other stuff... Adventure Trailer Chaser |
#80 | |
ThinkTank Waterboy
#81 |
Hello All:
I like the MLS HG a lot. It looks like the stuff I have seen from OEM compaines that use MLS. One thing that I did choose to use was some Hylomar around the water passages of the block side. Why only the block side, Just that I believe that this is where coolant could pass. The head needs to move and I believe that the head is softer and will create some slight impressions from the Head gasket(like a few different OEM do). Where the block is harder and will not allow the gasket to make impressions as easy. As for the different FMU. A conversation I had had with a retailer lead me to believe that the FMU was acculmative in its action. By this I understood it to add it value of pressure to the stock one. I understood it to add a extra 48 psi underfull boost to the already 43 psi of the stock system, it did not, it only added about 48psi total. So the fuel system needed more pressure to not have detonation that Jereme was experenceing. So by going to 12 to 1 it will bump it to about 72 psi, which is where the celica fuel pump will also have it internal pressure relief(which is about 70 psi). I also did adjust the internals of the Air flow Meter, eased up the spring a bit and returned the arm of the sensor to about it orginal position. This puts the meter in almost the same area to sense it should be in idle. Yes, I think a well designed intercooler would help a lot, it would cost more in the short term, but may aide the engine to live longer. The methonal/water injection would also help, cost less in the begining and need more service. Also cure the problem. All what the pocket book can stand. Many different way to get to a good end product. I can not wait to see what Rick does with his Turbo. Out of any way to force air into a engine, I like turbos the best. I am currently traveling with the family and hope to pop in and see different forums when I can. Hope all you guys are doing well. Catch you when I can. later Robbie __________________ 93 FZJ 80, 4.6 l, 6 slee suspenion, Front and rear and side aromor, 44 gal aux tank, 4.88, 35 MTR, daily driver, 36 TSL fun tire, drawer system, dual batteries. Can't wait for a trip. ![]() Senior Driver FJCTT
#82 |
Doesn't the 1FZ have a knock sensor? If not or you need something more aggressive you could look at a J&S (J&S Electronics SafeGuard Indivdual Cylinder Knock Control). I'm very happy with mine (on my built 3FE which of course doesn't have a stock knock sensor). I can run more timing than stock now on 87 octane and have peace of mind. These can be kind of hard to get however, John can be hard to reach.
That aside it does sound like an intercooler would be a good investment. Nice job! __________________ Joel '89 FJ-62 |
#83 |
It does have a knock sensor. The shop said the intercooler would be so far away from the intake that I'd experience tremendous lag. So, much so, that they fear I'd be unhappy and wont do it. The water/meth kit is installed and works like a champ...until I run out of water/meth.
#84 |
Well done - thanks for the pics
__________________ 1996 FJZ80, factory F&R lockers, TRD Supercharger, 3" OME medium lift, ARB front bumper, Stubbs sliders, 33" Goodyear Silent Armors, Landtank seat extenders, JDF fan, Blue fan clutch, KC lights, leather, Full Pioneer/Sirius sound, not enough time for wheelin'! |
#85 |
Thanks. I appreciate it. One of these days, I'll add pics of that as well. __________________ "Passions Testify to Enthusiams for the Cause" F. Dostoevsky 1980 HJ45 Imported from Oz... 1994 80 locked, Supercharged, bored over 1.25mm long Ranger aux. fuel tank with Oz spec overhead gauge set. and other stuff... Adventure Trailer Chaser |
