LinkBack (1) | Thread Tools | Display Modes |
#31 |
keep it going. nice. dyno perhaps?
__________________ 97lx450 4" slee/j's, sliders, bumpers, 3" exhaust, custom turbo, HG pm/Valve job/seals, sweet custom skid plate, Sleeoffroad parts, Buys oe parts from Cruiser Dan used to have 37" swampers.. 1 tons and 42's pending..... Budget Blown my build http://forum.ih8mud.com/hardcore-cor...j80-build.html 98 100 series. rear locker. 2008 6.7L dodge 2500 quad cab |
#32 | ||
The Cometic HG part # is C-4530 and then you just change/add the last three digits to meet your bore increase. Again, thanks guys. __________________ "Passions Testify to Enthusiams for the Cause" F. Dostoevsky 1980 HJ45 Imported from Oz... 1994 80 locked, Supercharged, bored over 1.25mm long Ranger aux. fuel tank with Oz spec overhead gauge set. and other stuff... Adventure Trailer Chaser |
#33 |
ThinkTank Waterboy
the stock Fuel pump has proved to be more than adequate for the job at hand. I'm sure it's not going to be a problem but then again I don't see it as an advantage either.
The autometer wideband will not read below 10.0 AFR i think while the innovate will read as low as 8.0. This has help on the 95+ trucks as they tend to have an AFR greater than 10.0 at WOT stock. I had a BEGI RR FPR but gave it to a fellow SC'd 93 truck. It will be nice to see how well it does for those trucks. The downfall of these is that it responds to pressure and the actual density of the air can change while the pressure doesn't which lends to fluctuating AFR readings. __________________ Rick Bigelow '96 215k Groveland MA 01834 If you're not the lead dog, the view never changes |
#34 | |
The 1JZ and 2JZ motors from the Supra turbos come stock with a MHG. The earlier Supra the 7MGTE did not and suffered many BHGs with boost levels above the stock 6ish levels. All 7M owners going for big numbers install the MHG. You can see plenty about this on the site: 7M-GTE Technical Discussion - SupraMania ...this is a direct link to the 7MGTE section. - Sean __________________ 97 40th F/C/R lockers. Yellow top, diff-lock switch, Massive inverter project underway. Currently at 170K+. 87 Toyota Supra Turbo - stock, 5-speed, targa roof, midnight blue. Currently at 125K+. And the man in the suit has just bought a new car from the profit he's made on your dreams. |
#35 | |
#36 | |
The quick brown fox .....
-B- __________________ 97 FZJ80 - Wing Nut MAF, locked, 315 Toyos, 4.88s, Slee 4", George's sliders, Slee bumpers, M12000, OBA, Outback drawers + other stuff. Transformation in progress... Sometimes you find yourself in the middle of nowhere. And sometimes in the middle of nowhere, you find yourself. |
#37 |
Nice build .. how much you gonna bost it .? 7 maybe 8 PSI . ?
Stock rods .? |
#38 |
Here's an injector and info sheet back from WitchHunter Per.
#39 |
If there is a four wheel dyno around I'd be game (I know there is not one in Reno). I'm not expecting the numbers to be all that impressive. It wasn't that much of an increase in displacement and I don't think we are going to increase the boost right off the back.
My goal was to build this engine to be strong and perform well with the s/c. I wouldn't mind going all out an another one in the future. Kind of like a multi year build up on the totally wild side. __________________ "Passions Testify to Enthusiams for the Cause" F. Dostoevsky 1980 HJ45 Imported from Oz... 1994 80 locked, Supercharged, bored over 1.25mm long Ranger aux. fuel tank with Oz spec overhead gauge set. and other stuff... Adventure Trailer Chaser |
#40 | |
I have promised to leave the boost alone for awhile...so we will have to see. I did use the stock rods as they are very beefy and balanced nicely. Much like the crank in this thing. I did get a quote on those billet rods from UAE and while they are very beautiful, I passed at a little over a thousand bucks for six rods. Maybe in the next one HAHA! Thanks again for the compliments. __________________ "Passions Testify to Enthusiams for the Cause" F. Dostoevsky 1980 HJ45 Imported from Oz... 1994 80 locked, Supercharged, bored over 1.25mm long Ranger aux. fuel tank with Oz spec overhead gauge set. and other stuff... Adventure Trailer Chaser |
#41 |
Your build here is quite impressive.
I assume you outsourced the machine work and the like? How much did all of that run? (not talking about what you are paying Robbie) I have a shot 1FZ sitting around in my living room (seriously) and I am tempted to make it a long term project (couple of years) and would like to get a parts list with part #'s from you if I can. Nice job. -o- __________________ 1997 FZJ80 with and without lots of stuff. 2001 Honda Accord 3.0L V6 VTEC Coupe EX. It is what it is.... |
#42 | |
![]() -B- __________________ 97 FZJ80 - Wing Nut MAF, locked, 315 Toyos, 4.88s, Slee 4", George's sliders, Slee bumpers, M12000, OBA, Outback drawers + other stuff. Transformation in progress... Sometimes you find yourself in the middle of nowhere. And sometimes in the middle of nowhere, you find yourself. |
#43 |
Haven't heard from ya yet....
![]() Just thinking out-loud Beo....you know me.... My offer still stands.
#44 | |
Couldn't reply earlier, but now I've got a chance to provide a couple links: Head gasket - Wikipedia, the free encyclopedia Head Gaskets Why Head Gaskets Fail - Read about the Toyota 3.4L Head Gasket Failure, Larry Carley, Underhood Service, August 2002 Federal-Mogul - Fel-Pro PermaTorqueMLS Head Gaskets The main concern with the MLS gasket is the surface finish required on the head and block. As far as my statement about the 2JZ engine, I've owned a vehicle with the 2JZ-GTE motor for over 8 years and frequent boards discussing that vehicle. It is common knowledge to members of those forums that the 2JZ-GTE with stock internals and head gasket can easily be pushed to 800 hp at the wheels. Boost pressures of over 30 psi on the stock head gasket are not a problem. I can't find info tonight that I consider credible enough to post a link to. Most of these high hp guys aren't making a big deal out of the fact that they use a stock head gasket (they list out the many aftermarket parts, but not the stock parts), so you have to look for the ones that specified they have never opened the motor to be absolutely sure. Many others brag of stock bottom end, but don't mention what head gasket they're running. The connecting rod bolts are the weakest link in the 2JZ. They "only" take about 1000 hp. Less if you raise the stock rev limit. Beowulf - Feel free to take this to PM for more discussion. I'll be weighing this HG material decision too for future maintenance. __________________ 1996 LX450 w/ factory lockers, Optima Red Top, HIR 9011 Hi & Low Beams, OME 850J/863, Bilstein HD, ARB winch-bar, 295/75/16 Terra Grapplers, yellow box speedo correction, LED domes, CDL switch w/pin 7 mod. |
#45 | |
Stealth 316 - Fuel Pump Upgrade Guide This article is excellent. Take note that a stock Supra runs fuel pump at 9v until under boost & WOT, then the fuel pump ECU kicks the voltage up to a regulated 12v. This keeps noise and heat low when cruising. Many people running more boost or larger turbos will bypass this fuel pump ecu circuit and run heavier gauge wire to get a little higher voltage at the fuel pump. Many also run dual Supra pumps, or dual Walboros. The Supra Denso pump is very voltage sensitive related to it's flow rates. It also pulls a 'lot' of current. Make sure the wiring is up to the task. __________________ 1996 LX450 w/ factory lockers, Optima Red Top, HIR 9011 Hi & Low Beams, OME 850J/863, Bilstein HD, ARB winch-bar, 295/75/16 Terra Grapplers, yellow box speedo correction, LED domes, CDL switch w/pin 7 mod. |
#46 | |
The service I received from JE left a lot to be desired. At least with the rep we dealt with. According to my machinist, he has had stellar dealings with JE until the last three custom orders dealing with the same rep. __________________ "Passions Testify to Enthusiams for the Cause" F. Dostoevsky 1980 HJ45 Imported from Oz... 1994 80 locked, Supercharged, bored over 1.25mm long Ranger aux. fuel tank with Oz spec overhead gauge set. and other stuff... Adventure Trailer Chaser Last edited by 24HOURSOFNEVADA; 06-17-08 at 12:55 AM. |
#47 | |
#48 | |
The link to the Supra forum confirmed what you are saying about the finish needed on the block and head. I consider that a con though a very minor one. -B- __________________ 97 FZJ80 - Wing Nut MAF, locked, 315 Toyos, 4.88s, Slee 4", George's sliders, Slee bumpers, M12000, OBA, Outback drawers + other stuff. Transformation in progress... Sometimes you find yourself in the middle of nowhere. And sometimes in the middle of nowhere, you find yourself. |
#49 |
Maybe I'll wait till you've got that block all cleaned up and bored out with new pistons.... and *then* call in the favour.
#50 | |
Long term project? Hell, if it's already in your living room turn it into a coffee table in the meantime. C'mon, a nice piece of glass over the top and your done.
#51 | |
(pronounced rod-ree)
#52 |
now that's some funny chit....
#53 |
The motor is installed, tuned and running. We (Robbie and I) took it for a nice run this morning. The motor is strong and pulls nicely. I'm putting miles on it to get it broken in and then the fun will really begin.
As for Robbie, aka powderpig, he's off on to his next "Adventure." I cannot express my thanks enough for his help and expertise. He's a true professional and that seems to be hard to find these days. ![]() ![]()
#54 | |
__________________ 97 FZJ80, Locked & Loaded, Safari Turbo, Safari Intercooler, LandTank MAF, 3" Ceramic Coated Custom Exhaust, Ron Davis Racing Radiator, OME HD 2.5" Suspension, DBA Slotted Rotors, New Toyota Calipers All Around, Toyota Pads, 33" Revos, ARB Front Bumper, Center Diff Switch, Slee Stuff: Roof Rack, Step Sliders, Skid Plates, SS Brake Lines, DC Drive Shaft. HG PM'd, 8.5psi and climbing, My Rocky Mountain Mojo Mobile! |
#55 |
