#31 |
That's exactly what i've been told. Must have been lied to.
__________________ 94 FZJ80/FJ80 mutt 315 Maxxis Bighorn, Rear Aussied, and stripped. Quote from Willy T. Payne "I'm f*cking this goat, you just hold the horns." (no goats were actually molested during the making of this comment) |
#32 |
Whitey
wow...
__________________ ~~~~~~~~~~~~~~~~ 93 FJZ80 Slee 4"/OMEJ, 35's, 4.88's, ARB's, Metal Tech sliders, ARB with M12000, On Board Air, caster plates, DC drive shaft, Pin7, CDL, adjustable rear uppers, A, homemade rear, Slee Skid Plate, extended brakelines, backup camera, Conferr Rack, Hella's, 96 FZJ80 285's OME 's ride
#33 |
IH8MUD Tour Guide
i would be interested to hear slee's response to that allegation.
__________________ 95' FZJ80 OME med./J lift, ARB rack, ARB Bull Bar w/tmax 12,500, 315 Nitto, stainless brake lines, Center Diff Lock, Sliders, IPOR Skid, IPOR rear bumper, upgraded slee sticker, custom dents, more to come. . . Remember it's a gateway drug, so it will actually lead to "crystal meh". |
#34 |
X2...
#35 |
We do use OME shocks, and they are supplied as OME. The springs are custom made for us to our specs, as is all the rest of the parts in the kits we sell.
#36 |
Guess that's settled.
#37 |
just out of curiosity, who told you that?
__________________ Matt 1992 FJ80 - OME 850/860, Bilsteins, ARB...
#38 |
I'd rather not say since it would bring unwanted attention to this person.
#39 | |
Deezz nutzz
![]() ![]() Your in Al right.........................
__________________ No cruisers, Im here for the Chicks and Beer McColgan for Prez Originally Posted by pagemaster It shows how weak and underbuilt the 100 series is. |
#40 |
Understood. really I was more curious if it was a vendor who told you that(which would be bad and I wouldn't want to give them any of my business), or if it was just another mud member (which would probably just be a misinformed opinion).
#41 |
Let's just say it was probably just a misinformed opinion.
#42 | |
The New Avocado
For me, since I was involved in the FOR design, it would be an adaptation of that result in terms of the taller coil. Still, the safe bet would be a 1" coil spacer on top of FOR 3.5" with a 10" 7100 or Fox (longer than the FOR bilsteins shocks) spacing travel down another ~1" and therefore bumpstops another 1" to fit 37's with no trimming - shock mounts could be modified to fine tune, 1" wheel spacer's added for the 37's. That's how I'd prototype, and of course if the end result is good then my work is done, because I already have the exact coil features I want. If I keep it up I'm going to talk my self into 37's when I get new tires next spring. It would be oh so easy, and 37" trxus weigh quite a bit less than 35" Toyos so I'm sure I wouldn't be busting anything .I won't be putting out a kit, though, just can't add the load with my kids being so young (and so many ), but it sure would be a fun and highly doable project.
__________________ 1995 FZJ80 - F.O.R. 3.5" lift - 35" trxus MT - 5.29's - Custom SROR Tube Bumpers - De-plasticized - Dented - Dieted Last edited by Nay; 06-13-08 at 12:43 PM. |
#43 |
Nay since you're familiar with the F.O.R. kit, I have 5100 bilsteins from frankie do you know how much lift I need to use these with my adaptors from Frankie?
#44 | |
The New Avocado
If you have the kit shocks, they will be balanced in travel up/down at ~3"-3.5" of lift with the eye adapters. Varying much from this would not be ideal, although OME uses the same shock from no lift to heavy, so take my statement with a grain of salt. I'd wait to run them until you get the springs, the valving is so soft that you might not like them with a different spring (read: ).
__________________ 1995 FZJ80 - F.O.R. 3.5" lift - 35" trxus MT - 5.29's - Custom SROR Tube Bumpers - De-plasticized - Dented - Dieted |
#45 |
Yeah I do have the kit shocks. I thought they would be stiffer not softer. I was wanting to run them with my OME's and possibly a spacer if needed. Judging by your post the spacer will be needed. Guess the softer ride will have to do since getting different shocks won't happen.
#46 | |
Whitey
35x12.50x16 Trxus = 76lbs 35" OD.....19/32 37x12.50x16 Trxus = 79lbs 37.2" OD.....21/32 Per Toyo: 315x75x16 Toyo = 76lbs 34.9" OD.....21/32 38x14.50x16 Toyo = 99lbs 37.7" OD.....21/32 (couldn't find a 37x16" listed) 37x13.40x17 Toyo = 93lbs 37.0" OD.....21/32 (have to run a 17" rim) Unless interco is wrong, the 35" Toyo and Trxus weigh the same. They say the 37" only weight 3lbs more per tire which seems a little odd for over a 2" larger tire. I'm not sure where you were getting that the 37" truxus weighs quite a bit less than the 35. I really would like to try FOR, but I"m not 100% on the spacers to get a true 4" (which isn't a big deal) I'm more concerned about an overly soft ride. I know Sam is running it, but looking for a bit firmer shock, which is what I'd like as well. My rig is fairly heavy, and isn't getting any lighter. I'm happy with the way it rides on the Slee up front, will probably do the rear Slee 4" __________________ ~~~~~~~~~~~~~~~~ 93 FJZ80 Slee 4"/OMEJ, 35's, 4.88's, ARB's, Metal Tech sliders, ARB with M12000, On Board Air, caster plates, DC drive shaft, Pin7, CDL, adjustable rear uppers, A, homemade rear, Slee Skid Plate, extended brakelines, backup camera, Conferr Rack, Hella's, 96 FZJ80 285's OME 's ride
#47 |
I have the elusive FOR bumper - custom done w/ my requested stinger. Frankie lost his butt on it, but he stood by the price he origonally gave me - which was WAY WAAAYYYY less than anything else out there. He's a good guy. But dealing with a start up buisness (he's been in other buisness for a while, the 80 series stuff is start up though), and a small buisness is sometimes difficult. He doesn't have 10 guys in the shop building stuff, and he doesn't have much time for spending on mud - unfortunate for him and us.
__________________ '97 LX450 - locked, Mickey Thompson MTZ 315's, J's, Rancho RS9000XL 14" shocks, RSC remote shock control 3" front drop brackets, 1" body lift, FOR custom front bumper, and a plethoria of rock lights Owner fabed rotating slider steps, rear bumper / winch and hitch, front and rear extended shock mounts, front spring spacers 1.375", front swaybar drops, rear bumpstop drops, rear swaybar extensions - 'If I can fab it, I won't buy it!' |
#48 |
I'm sure it's a fine bumper, Heath. I might have had one myself if it had ever made it to production.
I'm not knocking Frankie at all. Everything I've read suggests he's a skilled fabricator and a quality guy too. But I'm wondering -- and I think this is a fair question -- how long are you considered to be in start-up mode with a business or product line? More than two years? And hasn't this kit already been in production before? It seems to me the 80-series stuff is just a side line for FOR, not the main business, however good the product. Nothing wrong with that, as long as your purchasing timeframe aligns with their production window. __________________ Bruce Davis 97 FZJ80, 74K, factory locked, OME 851/860, Slee tube sliders, Slee transfer skid, Painless Fab tube bumperettes, CDL/pin7, Magnaflow 59906 cat, BFG 255/85R16 MTs |
#49 | |
The quick brown fox .....
Did you offer to cover his labour and materials costs? -B- __________________ 97 FZJ80 - Wing Nut MAF, locked, 315 Toyos, 4.88s, Slee 4", George's sliders, Slee bumpers, M12000, OBA, Outback drawers + other stuff. Transformation in progress... Sometimes you find yourself in the middle of nowhere. And sometimes in the middle of nowhere, you find yourself. |
#50 |
Well, since the center section was one of two prototypes that cost about 1800 each - uhm, no.
#51 |
I just got an email from Frankie. He said, "We have our shit together now new springs are rockin and a guranteed delivery of 10 weeks is done today so its on now ! Bumpers to follow soon..
Frankie,..,,." __________________ 94 FZJ80/FJ80 mutt 315 Maxxis Bighorn, Rear Aussied, and stripped. Quote from Willy T. Payne "I'm f*cking this goat, you just hold the horns." (no goats were actually molested during the making of this comment) |
#52 | |
If so.... let them come! -Dan __________________ 1. 2005 Toyota 4Runner Sport 4x4 V8. No sunroof, cloth seats - just the way I like! |
#53 |
Any updates on when the 3" will be available again?
#54 |
As far as I know it's 10 weeks from the day I posted which was 6-17-08. Can't wait....
