Old 06-11-08, 03:43 PM   #1
scott67fj40's Avatar
lock out hub for fj80?
Anyone know if a lockout hub conversion is available for an fj80 front axle?
67 fj40, Chevy 350
SM420 Trans
Saginaw PS
S-A-W Racerunner coilovers
3 linked front 4 linked rear
Currie Antirock
FJ80 axles longfields
ARB lockers front and rear
Warn 9000
37x13.50 Xterrains
and so on and so on..............
scott67fj40 is offline   Reply With Quote
Old 06-11-08, 09:24 PM   #2
Doc
Corn Eater
Doc's Avatar
TLCA# 17266
I don't see why you couldn't use mini truck hubs like we do on the FZJ's.
Eric P.
1993 Landcruiser, 190K miles. Lifted, Locked, Slidered, Slee'd, Snork'd, Winched, bobbed. Daily driver. ROTW
Tall Corn Cruisers- El Presidente.
Doc is offline   Reply With Quote
Old 06-11-08, 09:48 PM   #3
ArmyFJ's Avatar
TLCA# 17652
The AVM hubs that come with the Slee part time kit fit.
Matthew
For Sale: '91 FJ80 - 3FE, CDL 7 Pin Mod, Part Time, 6" Slee Lift, Slee HD Tie Rod and Drag Link, Aussie Locker RR, 37" Toyo M/Ts, ARB Front Bumper, Warn 10K, Ultimate Air
Past Rigs:
'75 FJ40 - 350 TPI, SM465, NP205, High Angle Driveline, Ford 9" w/ Detroit Locker RR, Front Disk Conversion, 4x4 Labs High Steer, 4 inch M.A.F. Lift, 35x12.50 MTRs
ArmyFJ is offline   Reply With Quote
Old 06-12-08, 12:21 PM   #4
Tools R Us's Avatar
IIRC the earlier stock hubs (Mini, FJ60, etc) will fit the FJ80 and early FZJ80 (up to 94?) if they still have the stock short birfs. The later (mid 94 & up?) and all replacement birfs are slightly longer at the spline. They require some spacer/machining play to to get the bushing to birf bell clearance correct and clear the hub dial on the other end.
Copper State Cruisers #007
Tools R Us is online now   Reply With Quote
Old 06-12-08, 03:22 PM   #5
I run mini-truck lockouts on my '97 axle. The c-clips on the end won't work, even with a spacer as they won't fit under the hub dial. I've been running without the clips entirely and with the inner axles tacked with no problems.
ref: FJ-80 w/ mini truck lockouts - Pirate4x4.Com Bulletin Board
--Dan
houlster is offline   Reply With Quote
Old 06-12-08, 03:38 PM   #6
Tools R Us's Avatar
--Dan
That's one way to skin it!
Also there is some extra meat in the dial that can be removed with some lathe play. I would like to try cutting the splined birf end off even with the inner hub, making a plate washer and holding it together with a button head bolt into the threaded hole in the birf. This is how some of the IFS rigs work.
LinkBack to this Thread: http://forum.ih8mud.com/80-series-tech/225951-lock-out-hub-fj80.html
Posted By For Type Date
diamond axle - TTORA Forum This thread Refback 11-11-08 05:23 PM
diamond axle - TTORA Forum This thread Refback 11-11-08 04:38 PM
Myspace Layout Stealer | Mortgage Loans | Free Credit Report | Fish Tank Help | Loans
