Belts Keep Breaking!!!! HELP
I own a 1996 Lexus LX470 and my belts keep breaking causing the engine to overheat. It has done this three times. The last time is busted my radiator. One of the belts busted today and caused the car to overheat again. I am using Gates belts each time. Does anyone have any suggestions that I can give my mechanic? It seems to happen after I pull my boat or pontoon. HELP
Correction I have a LX450
Village Idiot
The moderators will probably move it anyway, but you should searchthe 80 series forum as I am sure this has been discussed before. Try out the search function at the top of each forum.
I remember a gal on here that had this problem using aftermarket belts that weren't routed properly. My suggestion is to use Toyota belts, be sure all of the pullies are spinning freely and that they are routed properly. Check out these threads. http://forum.ih8mud.com/80-series-te...ment-saga.html http://forum.ih8mud.com/80-series-te...up-please.html http://forum.ih8mud.com/80-series-te...swap-help.html __________________ Travis 1999 UZJ100, TJM T-3, OME 866 Heavy kit, Custom Sliders, Onboard Water & Mombasa Penthouse. www.RealEstateBook.com "Anyone will say anything under the influence of madness." Jesco White |
There's your problem.
OEM > Gates __________________ Lane Anderson 1991 FJ80, Red, 249k, 3FE Powa ----- Lifted, flareless, LineX, 31" BFGs, Slee stuff, Dual batts, HIRs, OBA, GPS, headlight buzzer, couple lights, clear/tinted lenses, 100 Series bling, NLXTACY's garage opene, air horns __________________________________________
"If Chuck Norris drove a Land Cruiser, the resulting unstoppable force would destroy the earth." Cruiser Facts |
Oversize and under size belts don't last very long. Perfect fit makes all the difference.
Kalawang __________________ LC80 Full time AWD 1HD-T 1990 model 4" Lift 33" Yoko Geo MT Airtec Snorkel Bullbar 9,000 Warn PIAA CDL |
My guess is that you have a bearing and/or pulley problem. The most common is the idler pulley below the alternator, if the bearing goes bad it can lockup and take out the belts. Also look carefully at all of the pulleys, if any are bent, have gouges, etc in the area where the belts touch it will ruin belts.
Gates are good belts and run fine on the 80. Mine are Green Stripe, have been on for 2 years and ~30K miles. Had them off before Cruise Moab, replacing the alternator bearings, they looked great, nice wear pattern, so put them back on. Due to the cogged inside profile and the flat idler pulley, they make more noise than the OEM, but that is the only issue. There is little reason to run after market belts, good quality ones are about the same money as OEM from Dan. But if you ruin/break belts and need them quick, it good to know that they will work. Brother Rob's rig came with Gates on it, they had ~50k miles when he replaced them with OEM. __________________ Kevin Patterson '96 LX450 '84 4x4 Mini '73 FJ40 Copper State Cruisers #007 "We have come to the conclusion that we can run our car over any road that a man can take a team of horses and a wagon, providing we can get traction." Dr. Horatio Nelson Jackson, 1903 Last edited by Tools R Us; 06-11-08 at 10:42 AM. |
#8 | |
Running cogged belts would be fine in the short term, but I woudn't want to run them for long periods of time. __________________ '97 LX450 - The -mobile-roof rack, CDL button, 7 pin MOD, Auto Up Mod. '96 LX450 - New toy! ![]() Triple locked, -running boards, 1" body lift, grey wire mod. Jefferson State Cruisers (A wholely owned subsiderary of OR/CA TACO) Forums |
Someone recently had the same problem. The cause of the problem ended up being improper routing around the idler pulley. The dealer routed the belts around the idler which is incorrect. The top side of the belt is supposed to just touch the idler.
__________________ 1997 LX450 Green! with lockers |
#10 |
Can someone post the correct way to put on the belts so I can show my mechanic if it looks wrong? By the way I purchased Lexus belts today. We will see what happens!!!!!!! Someone please post a picture of the correct way to hav ethe belts on please.
#11 |
Like this;
__________________ Kevin Patterson '96 LX450 '84 4x4 Mini '73 FJ40 Copper State Cruisers #007 "We have come to the conclusion that we can run our car over any road that a man can take a team of horses and a wagon, providing we can get traction." Dr. Horatio Nelson Jackson, 1903 |
#12 |
x2 on the bearings. It happened to me on a Runner. Shreaded a brand new belt due to a bad alternator bearing.
![]() __________________ Rob Patterson Copper State Cruisers Scottsdale AZ. 97 FZJ80 Locked, J springs 315s ARB front 4x4 labs rear bumper. 87 4Runner. |
Secured Loans | Credit Cards | Property in India | Credit Cards | Free Advertising |
