Old 06-10-08, 01:18 AM   #1
RichElliott's Avatar
Doable? Toyta 4.5 Litre V8 Turbo Diesel Engine Swap
Hi all!
I was checking out the latest FJ70 on Toyota's Australia page and was impressed with what I learned about their new 4.5 Liter V8 Turbo Diesel Engine. 20% more power. 30% less weight. 20 to 25 mpg.
So it got me thinking... how cool would it be to get my hands on one of these engines w/ the manual 5 speed transmission and swap them into my 97 fj80? Since diesel's are much more efficient than gasoline engines at low RPMs, this would make an awesome trail rig.
Thoughts?
Has anyone else already tried this?
Links:
Toyota's Page
Interesting Article
"It's not me, it's you."
1997 FZJ80
RichElliott is offline   Reply With Quote
Old 06-10-08, 03:36 AM   #2
Brian894X4's Avatar
They had to redesign the front end of the 70 to make it fit. The 70 was designed around the 2F and later 3F and the 1FZ itself was designed around the dimensions of the 3F to back fit all the previous models and the 80 series was designed around the 3F/1FZ, so I have to wonder if there would be fitment issues. There's probably more room in an 80 than a old 70, but who knows.
Beyond that, the cost of obtaining one of those engines is probably beyond astranomical, but if I ever won the lottery, I'd sure look into it.
1995 FZJ80, modified for regional expeditions. Click here for more...
My main website:
In Search of History Expeditions
Foreign Toyota 4x4s
Military Toyota 4x4s
Brian894X4 is offline   Reply With Quote
Old 06-10-08, 04:10 AM   #3
You would be better off in every aspect by just putting a Cummins into your FZJ. It's cheaper, simpler, easier to fix (assumption), and would probably, if you went with the 4BT, get better efficiency.
'97 Lexus LX450 - CDL/7 Pin | Factory cup holder | Black LX wheels | 305/70 Toyo M/T | Optima Redtop | Auto-Up mod | George's LEDs | 1.5" Spacers |
F0RSAKEN is offline   Reply With Quote
Old 06-10-08, 06:48 AM   #4
WarDamnEagle's Avatar
I think you will have trouble legally importing this into the US. I've looked into importing diesel vehicles and engines into the US and it isn't easy (unless the vehicle is over 25 years old). The fines listed are also pretty stiff. Just FYI.
But it would be cool!
1985 4Runner - ROTM WarDamnEagle's 85 4Runner
1997 FZJ80 - locked and stock
2007 HDJ100 - DD
.....and these are just the Toyotas
WarDamnEagle is offline   Reply With Quote
Old 06-10-08, 08:49 AM   #5
I seriously doubt the 4BT is more efficient than the new V8. Its an old design. The 1HZ or 1HDT would be a better bet. They would be close to bolt up, and probably still more efficient than the 4BT.
1992 FJ80, stock except brush guard , and BF Goodrich AT 33's.
Hopefully soon to come; ARB, OME 2.5 inch lift, etc.
ThePookieBear is offline   Reply With Quote
Old 06-10-08, 10:11 AM   #6
Just swap in a cummins, do a turbo/intercooler and convert it to WVO. Then make real good friends with the owner of a local fast food joint---free gas forever!
Ryan Sieckmann
1997 Honda Odyssey EX (my beater)
2007 Chrysler Pacifica Touring AWD (baby momma mobile)
Prev. 1994 FZJ80
Prev. 1995 Montero (prev on fire-vid here)
NoMoreFires! is offline   Reply With Quote
Old 06-10-08, 05:17 PM   #7
Tapage's Avatar
Interesting .. you must need to buy the hole drivetrain, V8 and ECU .. keep in mind that the single turbo from a 70 series are less powerfull than the other twin turbo that come in the 200 series and both run a variable vane turbo with D4D tech inside .. ( common rail )
HJ-60 2H-T Intercooler Tencha
Originally Posted by pygpen
Old 06-10-08, 05:21 PM   #8
Hilux's Avatar
TLCA# 9h9-69
I just love posting this....gotta love...the Gov!
"Let me have a Diablo sandwich, a Dr.Pepper...and make it fast, I'm in a *** **** hurry..."
"You want sumpin?"
"hush puppies daddy"
"We got no time for that ****!"
Hilux is offline   Reply With Quote
Old 06-10-08, 07:33 PM   #9
TX80Fan's Avatar
...anything is possible with the right wallet
1997 FZJ80 CE, 6M1 'BOOGER' GREEN, 103k orig. miles , Baselined, ARB, SuperWinch 12.5, OEM Hand Throttle, HIR's, SROR custom sliders, CDL/Pin 7, Slee TC Skid Plate, OME 2.5" 850/860 w/CC, Toyo 285's w/1.5" spacers, Hi-Lift 'Extreme', PIAA 520's, HD port. air comp., Slee cup holder...
TX80Fan is offline   Reply With Quote
Old 06-10-08, 07:44 PM   #10
Jason Andrews's Avatar
Just swap in a cummins, do a turbo/intercooler and convert it to WVO. Then make real good friends with the owner of a local fast food joint---free FUEL forever!
There, fixed it for ya
'92 "The Albino Tractor" D.D. 225K, ARB/Slee6" 37"IROK, PG 4.88, 14"efan, SROR sliders, J-Moose roofrack
To Come- A Locker! A new seat, Dual Batts
-Official Thread Killer
Jason Andrews is offline   Reply With Quote
Old 06-10-08, 07:46 PM   #11
Diesel for blood
roscoFJ73's Avatar
Originally Posted by RichElliott View Post
Hi all!
Thoughts?
They are actually VDJ78/79 series
4WD Action magazine say the 105 series looks as if it would have enough room to do the V8 diesel swap.
As the 105 and 80 share a similar chassis,you could assume it doable.
The hard part is finding the engine
FJ73+1HZ Diesel NEW GEARBOX
33 in BFG A/T
Volvo 740 GL
Old 06-10-08, 10:54 PM   #12
I don't wheel
hj60's Avatar
TLCA# 11004
Just remember to cut the economy numbers by about 1/3 when you bring a foreign diesel here.
And if it's not common rail, you'll need to figger in the cost of lubricity additives, or a pump rebuild every few 10k miles.
Thank you to the E(verybody's) P(ain in the) A(ss).
Jonathan M. Rundlett <skadalajara@gmail.com>
Copper State Cruisers #001
Member of the Happy Hour Gang and the last true conservative in the U.S.
'94 80 Front Diff Lock, CDL, No Rear Diff Lock, Pin7mod, black-hub fan clutch w/13k CST fluid, IMT Stage I Front Bumper
Originally Posted by NLXTACY View Post
Others here can explain that a whole lot better than me but IIRC it had to do with the Vicious Coupler.
hj60 is offline   Reply With Quote
Old 06-11-08, 12:22 AM   #13
Thanks!
Thanks for all the awesome input! This is really more of a pipe dream for me, but I still think it would be really cool. I did some more research and found some good information that might address a couple of the questions here regarding common-rail and emissions:
From Jarvis Toyota in Australia, I found the following:
Engine:
The 1VD-FTV engine which powers the LandCruiser 70 Series vehicles has been developed as Toyota’s first V8 diesel engine. This engine with its advanced technical development provides improved fuel efficiency. Lower emissions which comply with Euro IV regulations and reduction of noise has also been achieved.
Engine Intercooler and Piping:
The 1VD-FTV engine has a single turbocharger with an air to air intercooler located above the engine to enhance output and exhaust performance. The intercooler is fed air via the bonnet scoop sculptured into the bonnet.
Engine Specifications for the Toyota Landcruiser 70 Series:
Engine Model: 1VD-FTV
Number of cylinders and arrangement: 8 cylinders, V-type
Bore x stroke: 86.0 x 96.0mm
Displacement: 4.461cm3
Compression ratio: 16.8 : 1
Valve mechanism: 32 valve, DOHC
Intake system: Turbocharger with intercooler
Fuel system: Common-rail type
Emission regulation: Euro IV
Maximum output: >150kW
Maximum torque: > 400Nm
Transmission:
The H150F 5-speed manual transmission has been retained for the facelift LandCruiser 70 series. This transmission has been modified for use with the new 1VD-FTV engine.
1997 FZJ80
Old 06-11-08, 12:34 AM   #14
ncrockinfj's Avatar
so does that mean that the 1fz would be an easy fit into a 3fe cruiser?
91 fj80 298k 3fe powa ; ome heavies, 36in IROKS, 17in Tundra wheels, rhino lined, abused, bruised, and still running like a champ
WWW.SAVETELLICO.ORG
ncrockinfj is offline   Reply With Quote
Old 06-11-08, 12:39 AM   #15
1shot1kill's Avatar
ya think!
A guy in my neck of the woods went this route and after nearly 30k and counting the rig still does not run!
IN VINO VERITAS
93 locked,sleed,Afrika Corps,sand ladders,snorkel,PIAA front/back,Arbed, 9k winch w/syn. od rope, Kaymared, quick release sways, OME, snorkel, dog ramp, Man-A-Fre rack, custom roof net, Lowarnce GPS, 4:88s, custom drivelines by NW Landcruiser, spacers, 38s - WIP!
1shot1kill is offline   Reply With Quote
Old 06-11-08, 10:29 AM   #16
Tapage's Avatar
Transmission:
The interesting part .. which mods . ?
Tags
4.5 liter v8 turbo diesel, swap
LinkBack to this Thread: http://forum.ih8mud.com/80-series-tech/225670-doable-toyta-4-5-litre-v8-turbo-diesel-engine-swap.html
Posted By For Type Date
diesel engine swap - forum post review | BoardReader This thread Refback 06-22-08 12:49 AM
Problem Mortgage | Personal Loans | Industrial Directory | Loans | WoW Gold
