3* caster correction with OME heavies???
I purchased the OME 850/863 springs and the shop I had put them on told me that my caster was off by 4* after the lift. I don't have aftermarket bumpers (looking for an ARB w/winch bumper). I already had purchased the 2* OME correction bushings and then had to purchase the 3* per the shop. Has anyone else had to use 3* bushing on such a small amount of lift? I know that some guys chose to run without caster correction with this lift. I have seen a lot of scenarios on this board but I haven't seen a lot with 3* CC and my same lift. Maybe I will need to get some spacers for the front (good excuse).
Any input would be greatly appreciated!
__________________ 1973 FJ40 Project: 35" BFG Krawlers, x-over steering, SOA, Shackle Reversal, PS, 4 wheel disc brakes, 2F, 4 spd, 2 Low mod (grinder!) 1998 4Runner SR5 255/85/16 Truxxs MT, 3" FR 4" RR, diff drop FOR SALE!!!! 1994 FZJ80 green :( factory lockers, leather, OME heavies, 305/70/16 SSR's, LX chromies |
I too have the 850/863 OME and I have not done the CC yet. My kit came with the yellow bushings which I plan to install soon. However, I think I'll go get a caster reading now so I know if I need the blues.
__________________ 1997 FZJ80 factory locked, OME 850/863 N73/N74E, Landtanks seat extension,slees light harness, HIRs, HID off-roads, slees off road light harness. Future projects; rebuild front axle, 150amp Alt.... |
I recently installed the OME Mediums with no aftermarket weight added to the truck and my caster was at -1 degree on each side. I ended up going with the blue bushings and have been pleased with the results. I am now in the low end of spec at 2.2 degrees each side.
Looks like you might be better off with Landtank's plates if you stay unweighted. -Jon __________________ 97 40th w/lockers - OME 851 (25mm spacer) / 863 - CDL - 315 Toyo MTs - slee'd front bumpered and sliders - ipor'd rear - custom drawers 01 Audi S4 |
You need Slee's blue bushings and Landtanks templates.
Read below. http://forum.ih8mud.com/80-series-te...s-results.html __________________ 1996 TLC, Cooper D. STT 305/70/16, CDL, 7 PIN, OME steer & 850/863, Bilstein HD, IPA fog. Slee's front bumper, skid plate, CC bushings, SS brake lines x 7, light/aux harness & speedo gear. Warn XD 9000, Hanna sliders. 4X4labs rear bumper. OEM sub tank & overhead console. Projection headlamps, clear lenses, rear tail LED, George's insde LED's. MagnFlow exhaust (cat back). Landtank's MAF, Eclipse Nav. Columbus varient RTT. |
#5 | |
__________________ <>< '93 FZJ80 ARB Front Bumper, OME Heavies, 33's, Aussie Locked Rear '01 Tacoma '78 Suzuki TS 250 Dual Sport UPSTATE CRUISERS OLDE NORTH STATE CRUISERS |
#6 | |
There are any problem if you run 3º caster bushings .. actually woul be intersting to know the real caster number on your Cruiser right now.
But anycase run more caster are not a huge problem more than a little more strees in your stering at each turn. Actually I'm runing caster plates with J springs. I forgot add that my caster measurements are 3.34 and 3.32 with J and Slee caster plates .. __________________ HJ-60 2H-T Intercooler Tencha HDJ-80 1HD-T not stock at all ! Marilu FZJ-80 1FZ-FE ready to Play ( wife rig ! ) Quote:
I was in the -2.5-3 degree range after my J springs lift, and after caster plates I am in the positive 2.5. Rides great, and I have only sliders as my extra weight right now. I had the blues, but they didn't get it. Long and short, if in doubt, PM Rick (landtank) and he can let you know what is up...
Good luck, Joel __________________ 1994 fzj80 "sandy": J springs, 315 procomp xtreme m/t, shortbus, local sliders... 1998 Uzj100-stock TLCA #17633 |
I just installed the OME heavies on my stock rig, ie, no extra weight. The front came up 3 inches and the rear came up 3.5 inches. I put the OME castor bushings on and it seems to be just fine. Tracks straight and handles fine. I haven't actually had the castor checked for the numbers though.
__________________ Ron 1978 FJ40 - Restoration project with 58K miles 1994 FZJ80 129K miles Locked with 295 Terra Grapplers and OME heavies 1994 FZJ80 with 43k miles. Tons of Parts for Sale 1984 FJ60 - Rustfree Texas Truck Rebuilt Engine with 5K (For Sale) 1984 Harley FLTC |
Thanks for all the responses! I believe my caster is +1 right now but I'm not sure. I guess I had the misconception that the 3* CC was too much but it sounds like many of you went that route at some point in your build.
I'm not sure if it would be a good idea to put about a 1" spacer (25mm?) up front to level it out but it sounds like I would still be within the tolerances. I will be putting an ARB on eventually, so I may want to wait for that before I do anything else to the height...unless I find some J's for the front...
#10 | |
ThinkTank Waterboy
If you think you are going to want those spacers skip the bushings all together and bolt on some plates. You'll be happy you did. __________________ Rick Bigelow '96 215k Groveland MA 01834 If you're not the lead dog, the view never changes |
#11 |
Wise words ..
#12 |
It's almost like god himself has spoken to me...
![]() I guess I will leave it alone until an ARB bumper magically appears on the front end. I'm sure I will be wanting J's and the plates at that point. Thanks for all the input everyone! __________________ 1973 FJ40 Project: 35" BFG Krawlers, x-over steering, SOA, Shackle Reversal, PS, 4 wheel disc brakes, 2F, 4 spd, 2 Low mod (grinder!) 1998 4Runner SR5 255/85/16 Truxxs MT, 3" FR 4" RR, diff drop FOR SALE!!!! 1994 FZJ80 green :( factory lockers, leather, OME heavies, 305/70/16 SSR's, LX chromies |
Secured Loans | Short Bowel Syndrome | Unsecured Loans | Loans | Xbox Mod Chips |
