Another A/C ?
My 91 is only blowing hot air, last summer it worked fine, this year nothing. Everything sounds like it is working, and the sight glass looks as it should according to the fsm. Could there be a door/ diverter somewhere in the dash thats not functioning properly?
Im ready to rip into it, I just dont want to start throwing good money at a car worth $2-3k __________________ 91 FJ80 318k, spare tire mod, custom roof rack----SOLD 98 4runner 141k---SOLD 98 Avalon 149k 04 Sequoia 74k |
Howdy! If you are low on freon, the system has a safety switch that will prevent the compressor from running. This is because the freon is also the lubricant for the system, and without it, it will burn out the compressor. When you turn on the AC, does the electric clutch on the compressor engage the pulley to drive the compressor? If it is not pumping, then you will not see any bubbles in the sight glass. John
__________________ 76 FJ55, Safari Grade. 350 SBC, Lockrightx2, SO, SR, PS, York on board, 35" Krawlers, and way too much junk in the trunk!!!! ![]() 85 Toyota mini truck for chase/support!CSC #41 |
yes i see bubbles, as stated everything looks to be functioning, just no cool or cold air at the vents
Top center of the firewall is the heater valve. Make sure this is being thrown correctly by the cable attached to the heat/cool slider in the dash. It sounds like your heater valve is always allowing coolant to the heater core.
Also with regards to the sight glass, you should only see bubbles when the compressor first kicks on and right after it kicks off. After running for a few seconds it should be clear. If you have constant bubbles in the sight glass, you are low on gas. __________________ Jon Held 1991 FJ80 "Lumbering White Rhino" Times Square, New York, USA TLCA# 5980 http://gclcny.com/jh/ Buy your FJ80 FSM here: http://gclcny.com/jh/fsm.html |
You want to do what...?
can you feel a difference in temps between the suction and discharge sides of the compressor?
(there is an extensive troubleshooting section in the FSM you could follow, some steps would require gauges) __________________ '97: 88K, 3xlock, Custom HD roo bar for sale, 285 MT/Rs on steelies, Hanna sliders, 851+1.5"/863/N73/N74E/SD24, ARB bull with M12, Kaymar with duals, Kaymar rack, Slee TC skid, 2m/440, more stuff, loose nut behind the wheel!) '03: 99K, the better half's... DD Accord souped up DR650 |
#6 | |
Grab a hold of the fat ac line on the metal portion, if it's cold, you have a heater valve problem, if it's not you have a leak in the a/c system. How is the fan clutch on your rig? Its getting hot, and the high side pressures can spike at a traffic light if the fan clutch is bad, and your a/c won't be able to cool worth a damn. If you see any portion of the a/c system that has a grimey, black, oily, nasty filthy, crud on it, you have found your leak, if the compressor is coated from the pulley back, you blew the front seal. If you want, I can help you out. __________________ 2- 91 FJ80's, one smashed In the family 74 FJ40 w/PTO winch, tow bar 83 FJ60 84 FJ60 90 FJ62 w/damage inducer 94 FZJ80 w/damage multiplier 95 FZJ80 " " 03 UZJ100 |
it used to blow nice cold air at highway speeds, and warm a little when in traffic. Its not blowing cold or cool at all. John, i have followed the fsm steps, thats why it seems odd for everything to run and no cold air.
Back under the hood __________________ 91 FJ80 318k, spare tire mod, custom roof rack----SOLD 98 4runner 141k---SOLD 98 Avalon 149k 04 Sequoia 74k |
#8 | |
Is there a way to tell if the valve is closed or open? __________________ 91 FJ80 318k, spare tire mod, custom roof rack----SOLD 98 4runner 141k---SOLD 98 Avalon 149k 04 Sequoia 74k |
Other than looking to see if the slide moves? If someone is inside the cab and moves the temp selector you can see it move (truck must be turned on!)
Other than that I would say you would be taking it off to make sure the actual divertor is still operating. But I've never actually played with the LC's so I'm not 100% __________________ 70 FJ40-sold, worst day of my life 79 TOY 4WD pup-stolen, 2nd worst day of my life 91 4Runner 4WD-burned to ground, 3rd worst day of my life 83 FJ60- suckiest day of my life 97 LX450, 221k, non-locked. Expedition vehicle in progress. Factory rack removed ![]() ふざけんなよ! |
#10 |
Truck doesn't have to be on. Cables move without battery power when you push the dash slider.
Wester Union | Free Web Arcade Games | Debt Help | Mortgage Calculator | Loans Bad Credit |
