Old 06-03-08, 11:37 AM   #1
Schmeal's Avatar
Whats up with these stupid cone washers!?!
Good morning all,
I figured I would share my experiences with the forum from last night because its pretty noteworthy. I picked up my LX450 last weekend with a bit of brake vibration. I quickly ordered new rotors and pads planning on starting fresh even though po stated the brakes were just replaced (total lie, about to hit wear indicators). I have a chilton manual that somewhat covers the land cruiser and have owned and wrenched on just about every other gen and model of toyota truck (all IFS though). i figured "Ill bust these rotors and pads out in less than an hour, easy as pie". As soon as i get the wheel off i notice the rotor is bolted to the hub like older trucks. I figure "no big deal, hub has to go too". I reach back to remove the caliper and end up with a fist full of grease from the knuckles. I remove this and that still cant get the hub off or its cap plate. I struggle with the dust cover and the stupid snap ring for and hour and then I sit back and think to myself "this thing isn't anything like a normal toyota is it" and "what have i gotten myself into by buying this giant ba$tard". I went on the net covered in grease to find out there are cone washers I have to drift some way and a giant 54mm nut that I am going to have to remove that I have no socket for.
I put the thing back together in denial that I had to back out of a wrench job. Cruiser 1 Schmeal 0.
Also to add insult to injury when I get to work this morning my center cap on wheel I was working on is gone. The truck has the factory wheels chromed with chrome center caps which I think was done aftermarket making it impossible to find a replacement.
Schmeal is offline   Reply With Quote
Old 06-03-08, 11:41 AM   #2
you can find chrome replacement caps on ebay for pretty cheap. what ever you do dont buy them from the dealer. IMO
I have the perfect canvas for a perfect work of art
stocknlocked94 is offline   Reply With Quote
Old 06-03-08, 11:44 AM   #3
Wow, some serious head-banging here. Obviously, you should read the FAQ we have set up for "birfield repack" or "axle repack". The amount of grease indicates to me you might consider doing the whole job since replacing the front rotors is a significant portion of the job - 50% of the time, perhaps?
DougM
'93 FZJ since new, 2.2kw starter, Revo 275s, locked, big Hellas, rr fog, rr flood, rr Airlift, synthetics, ARB bullbar. 97 FZJ - exact same stuff but Michelin Alpins in winter "Slicker than owl shit on a wet log." - Carter
IdahoDoug is offline   Reply With Quote
Old 06-03-08, 11:48 AM   #4
natvet's Avatar
TLCA# 18169
cone washers
take large brass drift and BFH to the hub studs till cone washers pop up.
The answers to most all question can be found here.
FAQ for 80/LX450 - April 26, 2008 - Added leather replacement w/ links to seat heater
look under knuckle rebuild. Sounds like this will also be needed
Nathan
73 FJ40
1997 FZJ80 DD
Did you ever notice that when you blow in a dog's face, he gets mad at you, but when you take him for a car ride, he sticks his head out the window?
natvet is offline   Reply With Quote
Old 06-03-08, 11:53 AM   #5
mainemike's Avatar
TLCA# 17772
Once you see how it is assembled, disassembly will make sense. It's not that difficult once you "see" the teardown order of parts.
http://forum.ih8mud.com/80-series-te...build-faq.html
but you are not in IFS land anymore. Everything on this 'giant bastard' is bigger and far more overbuilt than what you may be used to wrenching.
1996 FZJ80 not-locked, Emu 861/862, ARB, Slee sliders and skids, 285 Nitto TGs, Scan Gauge, hopefully exploring somewhere in North America.
www.purplelizard.com
mainemike is offline   Reply With Quote
Old 06-03-08, 11:59 AM   #6
Whitey
FJBen's Avatar
TLCA# 15530
Leave the nuts on the stud when you whack on them...
hmmm...
anyways that way the cone washers don't go shooting across the garage floor never to be found again.
93 FJZ80 Slee 4"/OMEJ, 35's, 4.88's, ARB's, Metal Tech sliders, ARB with M12000, On Board Air, caster plates, DC drive shaft, Pin7, CDL, adjustable rear uppers, A, homemade rear, Slee Skid Plate, extended brakelines, backup camera, Conferr Rack, Hella's, FOR SALE
96 FZJ80 285's OME 's ride
FJBen is offline   Reply With Quote
Old 06-03-08, 12:13 PM   #7
CodyRx7's Avatar
brass drift?
Just take a baby sledge hammer.....mine is like 2 or 3lbs or something.
Give it a nice whack on the side near the cone washers (on the hub, not the studs)...and they pop out enough for you to grab them and pull them off.
97 LX450 - Champagne Silver / 161k / 5.29s / ARB lockers F/R
39" Michelin XML tires, 8" coils / L shocks, 1.5" wheel spacers, Slee caster plates, ARB rack & Safari Snorkel, 60 ARB bullbar, custom sliders, dual swingout rear bumper, Overland RTT on a Monster M100 trailer
Copper State Cruisers #045
CodyRx7 is offline   Reply With Quote
Old 06-03-08, 01:03 PM   #8
Schmeal's Avatar
Thanks for the tips guys, I guess I might as well do the whole axle service since the truck has about 83,000 on it. Oh and read the write-ups maybe buy some proper tools before I go tearing into my truck again.
Glad I found this site otherwise I would be sol, or at the dealer getting reamed out.
Thanks again for the help and cheers!
"whats a FZJ?"
"if you have to ask big man, ha.... you can't afford it"
Old 06-03-08, 01:14 PM   #9
slow91fj90's Avatar
Im with CodyRX, I use a BFH and hit the side, but I stick a towel on the end so the cone washers dont go flying across the room.
91 FJ80, 3" OME, 33 PROCOMP MUD TERRAINS, ARB, GARMIN-V, 4:56'S, T-MAXX 10,OOO,NOT LOCKED,MOBILE AIR-CARD.
slow91fj90 is offline   Reply With Quote
Old 06-03-08, 01:24 PM   #10
beno's Avatar
TLCA# 14607
Cone washers have nothing on a good 2 pound BFH--the best tool for the front axle job.
-o-
1997 FZJ80 with and without lots of stuff.
2001 Honda Accord 3.0L V6 VTEC Coupe EX.
It is what it is....
beno is offline   Reply With Quote
Old 06-03-08, 07:08 PM   #11
Falco80's Avatar
TLCA# 18832
I agree, hit the side of the hub near the cone-washers and leave the nuts on the end of the studs so the bloody things don't fly off and dissapear! I'd imagine a 54mm hub nut scket would be easy to get over in the states? I picked mine up from an ebay store here in aus. Made the job a whole lot easier IMHO than using hammer and chisel....
Dan
92 FZJ80, 5sp, Part-Time Kit, 4" Lift, Locked, 305 muds....(Selling soon)
97 HDJ80, 5sp, 1HD-FT.....Turbo-diesel multivalve music to my ears!
Falco80 is offline   Reply With Quote
Old 06-03-08, 07:34 PM   #12
The quick brown fox .....
Beowulf's Avatar
Originally Posted by Schmeal View Post
... then I sit back and think to myself "this thing isn't anything like a normal toyota is it" and "what have i gotten myself into by buying this giant ba$tard"
Actually, it is like millions of "normal" Toyotas. The ones with solid front axles that, unfortunately, we can no longer buy here in the USA.
It is a giant ba$tard though.
Pitch the Haynes and get yourself a real FSM (Factory Service Manual) and get yourself a bunch of 1/2" drive sockets (the BIG ones), breaker bars, extensions, and ratchets. Your tiny 1/4" drive stuff won't hack it on a Land Cruiser.
Read the FAQ before you charge off on any wrenching project and you'll find ways to make the job much easier and much quicker.
Good luck.
-B-
97 FZJ80 - Wing Nut MAF, locked, 315 Toyos, 4.88s, Slee 4", George's sliders, Slee bumpers, M12000, OBA, Outback drawers + other stuff. Transformation in progress...
Old 06-04-08, 02:01 AM   #13
nicholas's Avatar
I have read the faq, done many searches and I'm still stuck. I've spent the last 4 hours pounding on my lower passenger side knuckle studs with a brass drift and a BFH and I still can't get 3 of the 4 cone washers off. I've even tried pounding from the top by placing the drift down through the upper trunion hole and directly upon the lower trunion stud. I put a bunch of PB blaster on them and I'm going to go get a propane torch tomorrow to see if that will help. So far the birf pack has been a breeze besides these damn cone washers! Does anyone have any other suggestions? Am I just being a ? I've been pounding pretty hard but I think I might wake up the neighbors so I'm calling it a night.
97LX450, 141K, 285CooperSST's, OME851/860's, S/C, CDL 7-Pin, Landtank MAF, Slee SS lines, 100 pads, silicone PHH, Raventai temp, CDan parts throughout($5K+). Chillin' in Cornfeilds (IA) studying.
nicholas is offline   Reply With Quote
Old 06-04-08, 03:13 AM   #14
CodyRx7's Avatar
You really have to hit it hard.
The first time I tackled the cone washers...I was gently tapping for probably 100 times until I got frustrated and gave it a hard WHACK.
2 popped out halfway, and I realized this isn't a job to be delicate with.
Old 06-04-08, 09:38 AM   #15
Beowulf's Avatar
Examine one of the cone washers that you have removed. There is a slit that goes through the cone washer.
Use a thin flat-blade screwdriver (or similar) and tap it into the slit.
-B-
Old 06-04-08, 09:45 AM   #16
nicholas's Avatar
-B-
I've tried the screwdriver in the slot on other cone washers, but unfortunately these are jammed in so far there isn't very much space in the slot. Has anyone has any luck with heating them with a torch? Thanks for the previous timely responses!
Old 06-04-08, 05:04 PM   #17
Grench's Avatar
TLCA# 16296
No torch. Once you get one cone washer off, the rest are usually relatively easy. I spent a solid hour getting the first one to come off on my wife's DS.
Something that helps is to pound one side for a bit then switch to the other. Pound on the drive flange right beside the stud using a brass drift, a 2 lb hammer, and a fair swing.
Tell yourself, I'm fixing a tank. Gentle isn't necessary.
That said, I make sure that I call Cruiserdan and order a full birf/wipers/seal/repack kit AND a couple of extra cone washers and studs and fresh bearings and... etc... before I even start one of these jobs. Spend the money to do it right so you don't have to do it again.
Read the FAQ. If you survive this repair, then read up on the 'PHH' and starter contacts before you put the DS wheel on.
Welcome!
FZJ80 1
1996 MoonGrey FZJ80 125K - Lotsa toys/extras/mods/maint.
FZJ80 2
1996 Red FZJ80 120K- Fac lock. 861/862 OME.
Grench is offline   Reply With Quote
Web Advertising | Bad Credit Mortgages | Personal Injury Lawyer Los Angeles | IKA Processing Equipment | Mortgages
