Old 06-30-08, 06:35 PM   #31
FYI
The north american distributor is a IH8MUD advertising vendor.
LC80Ducati996 is offline   Reply With Quote
Old 06-30-08, 06:58 PM   #32
We Have Assumed Control
Lockd97's Avatar
Really?
Id be interested in the over the frame part # BB3107.
Scott-
97 40th S/C'd Landtank MAF WBO2 Locked CDL
OME 850/860's shocks NITTO's air bags heated seats
98 Tacoma S/C'd w/fuel mods piggyback'd
Lockd97 is offline   Reply With Quote
Old 06-30-08, 08:07 PM   #33
inacoma's Avatar
Originally Posted by LC80Ducati996 View Post
FYI
...and that would be?
75 FJ40
85 mini x-cab sr5...**SOLD**
96 LX450
99 Tacoma **SOLD**...and I miss it!
05 GX470
02 Golf TDI (hey..something needed good MPG!)
...all with 'stuff'
www.cruizer.net
inacoma is offline   Reply With Quote
Old 06-30-08, 08:14 PM   #34
Originally Posted by Lockd97 View Post
Really?
it would only be half of the way over.
The down pipe has the upward bend on it.
Old 06-30-08, 08:18 PM   #35
jamisobe's Avatar
Looks to me like part # BB3107 would go from the cat over the frame to the muffler though I am sure you would have to cut to fit. I would of liked to of had that section when I did mine. It would of saved me alot of time and could of given an even cleaner install.
95 FZJ80 custom headers & 3" flowmaster exhaust, 4" OME lift (with CC bushings, x br lines, adj panhards, heavier dropped sways), ARB lockers, 35" Toyo M/Ts, dual dry cell batteries, 2300 watt inverter, speedo corrected, & Kaymar w/carrier Next: ???
jamisobe is offline   Reply With Quote
Old 06-30-08, 08:23 PM   #36
Look at the color photo of all the sections I posted not the black and white pdf catalog photo of them lined up.
The downpipe has an upward 90 on it.
All that would be needed is to put an upward 90 off of a cat and a flange to connect it to the BB3107 which will go the rest of the way over.
Old 06-30-08, 08:36 PM   #37
jamisobe's Avatar
Yeah I see it. I guess you would have to buy two pieces to get the section you would need from the cat to the muffler. I would probably cut the flanges off and cut and butt for the best angle with the cat and muffler already in place.
Old 07-01-08, 07:59 AM   #38
Lockd97's Avatar
Exactly what I was thinking.
Is the NA Vendor a secret or what?
Scott-
Old 07-01-08, 03:38 PM   #39
Tapage's Avatar
wou .. this exhaust system looks good .. anycase for us ( turbo diesel ) all thinks are much more simple in the exhaust route .. but it come with a question.
We don't need ( pulling out the emision and CAT stuff ) a muffler it'self due to the turbo do the job as muffler .. it's the same in a gasser turbo ?
HJ-60 2H-T Intercooler Tencha
Originally Posted by pygpen
Old 07-01-08, 06:04 PM   #40
We dont need no stinking mufflers.
I'd still run a low restriction muffler but with either gas or diesel having a turbo does have a silencing effect.
Old 07-01-08, 06:08 PM   #41
Rocky Mountain Imports - Your source for JDM Parts and Vehicles
They are in the middle of a move to a new building. Also keep up to date with what I have going on. I am discussing group buy with them.
Honestly I dont know why some are just looking for the one or two pipes. Between all raw materials and time it will take to round out the rest I dont think you will come out ahead.
IMHO getting a full system and spicing in a cat or a resonator out back is less work for better results than just getting the over rail sections.
Old 07-01-08, 06:24 PM   #42
jamisobe's Avatar
I mentioned in another thread that I have a friend back in Ohio who has a Lingenfelter/Callaway twin turbo vette that puts out 900hp/1000hp to the rear wheels depending on the fuel/fuel program he uses. He runs no mufflers, no cats, and mandrel pipe all the way back and it sounds stock. Looks stock too.
Old 07-01-08, 06:28 PM   #43
jamisobe's Avatar
You will need the whole system unless you already have some 3" in place. It would be easy enough to swap out or remove that muffler if needed. Cut the flex join off and maybe you could use that front secondary pipe to replace the muffler if you have a turbo.
Old 07-01-08, 07:07 PM   #44
I also still recomend keeping the flex due to the proximity of the overframe and over rear frame to making contact.
If you have a turbo and used the turbonetics manifold I am sure you would end up using almost all of the front pipe due to where the turbo is mounted and where it puts the turbine outlet. It is necked a bit at the front most flange. I would only remove the tapered section. A pipe to merge the external wastegate and the turbine outlet would need to be fabricated and connected to the down pipe. I also would make a downpipe to block brace.
Old 07-01-08, 07:49 PM   #45
jamisobe's Avatar
I'm not a fan of the flex pipe. I prefer rubber insulators between the exhaust and the frame. Flex pipe may work, but an exhaust can be made not to break hangers without it. Might as well do away with another source of power robbing turbulence if it isn't necessary. I have had my exhaust hanging trouble free for over 4 years without that flew pipe section.
Old 07-01-08, 08:57 PM   #46
Grench's Avatar
TLCA# 16296
Does anyone know what this is constructed of? Black painted mystery metal?
FZJ80 1
1996 MoonGrey FZJ80 125K - Lotsa toys/extras/mods/maint.
FZJ80 2
1996 Red FZJ80 120K- Fac lock. 861/862 OME.
Grench is offline   Reply With Quote
Old 07-01-08, 09:21 PM   #47
It is mild steel.
Sure the flex section causes some degree of turbulence. I ran a 3" downpipe with a flex section on a mid 10 sec 1/4mile car. Not sure if or what it cost in hp. Did'nt care. Some back to back dyno tests of naturally aspirated v8s have actually made more hp with a high flow cat than with just a straight pipe. The only thing changed was the presence or lack of a cat.
Some effects are so minor I really dont think they matter in non pro racing applications. Rather have a system that can flex a bit than one that can bend or break than 1-2 extra ponies. I have seen muscle cars back mufflers into curbs and tweak their whole system also have seen fwd cars with flex sections do it and only ding a tip because the flex section gave and poped back.
Old 07-01-08, 10:46 PM   #48
jamisobe's Avatar
Well I have crunched mine at the under frame location twice and I did get a small tear I had to fix, but a flex joint would not of saved that. Also, I backed into something once and bent the tail pipe, but that was fixed just by gripping the bend with vice-grips. I think that rubber washers provide enough insulation from vibration. Besides, I thought you said the flex joint was primarily to allow for motor tilt?
Old 07-01-08, 11:21 PM   #49
I think we should just agree to disagee. Not really sure why you are so active in flaming and nit picking such as turning things around.. I gave a second benefit of a feature and you are like I thought it was because of engine movement.. Duh.... it was.
Well stock routing with stock pipe does allow for the engine twisting too. With the 3" system I am sure they did it to make the pipes movement less severe for extra clearance.
As for the tailpipe. Put a turn down behind the bumper with the edge of the turn down even with the bottom of the bumper. A couple people here have gone to that with great results.
Old 07-02-08, 07:45 AM   #50
jamisobe's Avatar
Sorry about coming across as flaming. I was pokin' fun more than anything.
I actually looked at using a flex piece when I initially did my exhaust and we decided there wasn't enough room to fit it with my application including headers and power loss was mentioned. In hind sight though there haven't been any problems so I am happy with extra power gained.
My tailpipe has a turn down and is somewhat protected. I hit something at a bad angle. It could happen again, but I am more conscious of the risk.
Old 07-02-08, 07:57 AM   #51
jfz80's Avatar
TLCA# 16634
ok so what are the thoughts to the flex section concerning longevity....this system or another. And BTW that exhaust looks pretty badass. When i was getting mine, i asked around about the flex and then asked my installer as well and it was a resounding NO that i got. Most folk felt they would burn out and become ineffective in the 1-2 yr timeframe. just curious what others feel or have experienced.
95 FZJ-80 Lifted, Locked, armored,37'd, blown and bigelow enhanced ; single digit MPG wondermobile
72 FJ-55 IPOR bumpers/sliders, SOA, 3'' BL, 8274, and a big ole F'n engine, 35'
(for sale)
92 P/U stock, lil lady owned, gas miser/DD/worker aka tiny tim
jfz80 is offline   Reply With Quote
Old 07-02-08, 08:05 AM   #52
They come standard on millions of front wheel drive cars. I have seen that other components of the exhaust on the cars fail first.
Old 07-02-08, 03:28 PM   #53
ThinkTank Waterboy
landtank's Avatar
It is mild steel.
Yuk..
Rick Bigelow
'96 215k
Groveland MA 01834
Old 07-02-08, 03:35 PM   #54
concretejungle's Avatar
TLCA# 14646
no it's not I said get one, and i said that Dusty had one and said to get one.... so there are two YES votes.
95' FZJ80 OME med./J lift, ARB rack, ARB Bull Bar w/tmax 12,500, 315 Nitto, stainless brake lines, Center Diff Lock, Sliders, IPOR Skid, IPOR rear bumper, upgraded slee sticker, custom dents, more to come. . .
concretejungle is offline   Reply With Quote
Old 07-02-08, 06:08 PM   #55
Originally Posted by landtank View Post
Yuk..
Well considering one place wanted big $ for full stainless. less yuk. The same place even recomended jet hoting mild instead of having them make it in ss due to current stainless prices.
Old 07-03-08, 10:33 AM   #56
Lockd97's Avatar
Thanks for the company name. I'll be interested to see how your discussions go with a group buy.
I'm looking for one or two pieces because I already have everything to fab a 3" exhaust and the one or two pieces would be a time saver. The possible cost of the system may not be worth it to me.
Scott-
