Old 05-29-08, 03:20 PM   #1
Front wheel, Drive Flange Cap comes off
Guys,
My little sis got this 80 1993, about 2 months ago, I noticed gear lube sprayed all over the front right wheel. So I took the fancy plastic toyota cap off and the drive flange cap (steel) had fallen off. So I put it back on, tapped it with a hammer. Done! I thought.......
Now I noticed it again, why is this thing coming off? Is the front right axle walking around that much and pushing it out?
1995 Land Cruiser (Elsie) Locked, 33's, CDL
For Sale: 1990 4Runner, 37's, SAS, 5.29's (sold)
85badger is offline   Reply With Quote
Old 05-29-08, 03:40 PM   #2
jonheld's Avatar
TLCA# 5980
You're referring to the removable grease cap that is a press fit onto the drive flange? If that's falling off it probably just needs a slight bend to fit more securely. I usually need to work it off with a small flathead screwdriver.
The inner axle can't move outward enough to knock it out.
Jon Held
1991 FJ80 "Lumbering White Rhino"
Times Square, New York, USA
TLCA# 5980
http://gclcny.com/jh/
Buy your FJ80 FSM here:
http://gclcny.com/jh/fsm.html
jonheld is offline   Reply With Quote
Old 05-29-08, 03:48 PM   #3
bhmmapping's Avatar
TLCA# 18734
I would be more concerned with the gear oil coming out of the drive flange than the grease cap falling off.
Matt
1992 FJ80 - OME 850/860, Bilsteins, ARB...
bhmmapping is offline   Reply With Quote
Old 05-29-08, 03:50 PM   #4
Yes, that's what I'm trying to describe. You think all I need to do is tweek it abit? I'll give it a try, I actually thought that was the fix, but that sounds too easy.
Old 05-29-08, 03:53 PM   #5
Well, you know how girls are about vehicles, I told her to check it, make sure it is still on and not leaking.............I'm going to fix it and fill the diff back up tonight.
Old 05-29-08, 03:59 PM   #6
Doc
Corn Eater
Doc's Avatar
TLCA# 17266
I have to more than 'tap' my cap back on. It takes a few forcefull blows from a 1.5lb brass hammer to get it seated propperly. If yours is 'tapping' back on, it's too loose. tweak the lip like suggested above.
Eric P.
1993 Landcruiser, 190K miles. Lifted, Locked, Slidered, Slee'd, Snork'd, Winched, bobbed. Daily driver. ROTW
Tall Corn Cruisers- El Presidente.
Doc is offline   Reply With Quote
Old 05-29-08, 04:02 PM   #7
OK, I'll work the lip over! I'll check back in if that was it!! Thanks
Old 05-29-08, 04:19 PM   #8
Parts Shaman (per Romer)
cruiserdan's Avatar
TLCA# 11332
Actually it can if you have a mis-match on the birfield/drive flange.
We had a 93 in here a couple weeks ago and it was popping the dust cap off. An inspection revealed that the vehicle had recently had a birfield replaced and the installer did not also install the new taller drive flange to go along with it. The long birf combined with the short flange would knock the cap off when the birf moved outward.
This vehicle could possibly have the same issue.
If this vehicle has factory birfs in it they will have paint marks on the end under the dust cap. If the paint is pink the birf is short and if it's green the birf is long.
If it's green you will need a 43421-60040 drive flange to go with it.
Old 05-29-08, 04:21 PM   #9
We had a 93 in here a couple weeks ago and it was popping the dust cap off. An inspection reveiled that the vehicle had recently had a birfield replaced and the installer did not also install the new taller drive flange to go along with it. The long birf combined with the short flange would knock the cap off when the birf moved outward.
Damn your good!! How much for the taller drive flange and a new cap? I'm headed home right now and will get back tomorrow with the news, pink or green. I do know that the front right has had some work done to it before she bought it, so this is probably the problem.
Old 05-29-08, 04:31 PM   #10
TLCA# 13863
Not only is he damn good he's a hell of a guy.
(That oughta keep my truck safe for a while)
Buck
Toyota 4x4's of Texas aka T4x4T
97 LX450 OME 2.5, 1" spacers, CDL w/pin7, Toyo 315's, cup holder, Bullbar, Hannah Sliders & Rear Bumper.
TLCA# 13863
Buckru is offline   Reply With Quote
Old 05-29-08, 04:46 PM   #11
cruiserdan's Avatar
TLCA# 11332
The flange lists for $53.02 and runs a mudder $39.76. The cap lists for $3.32 and nets out at $2.49.
Old 05-29-08, 05:22 PM   #12
Tapage's Avatar
Little Hijack ..
I thought in my factory 95 part time 80 I have the short bierfidls .. so I thought Boby make the long ones .. how much longer are ?
Hijack over ..
HJ-60 2H-T Intercooler Tencha
Originally Posted by pygpen
Old 05-29-08, 05:25 PM   #13
cruiserdan's Avatar
TLCA# 11332
~7mm longer.
Old 05-29-08, 05:35 PM   #14
AKcruiserfreak's Avatar
Man, Dan's all over stuff today. BTW thanks for the Valve cover gasket and Blue fan hub. I'll be going over my front end soon enough.
TK
1971 FJ-40 2" shackle lift, 33" BFG,PTO winch, lots o' miles, con fer roof rack, safety yellow, weber 38dgas, Downey header.
1993 FZJ-80 114k, new ecu, ARB/Warn12k, Wild Country TXR 285's,Astrostart autostart, OME850J+1" Slee spacers,OME863 rear, Blue hub, 67" sliders.
AKcruiserfreak is offline   Reply With Quote
Old 05-29-08, 09:49 PM   #15
Sarmajor's Avatar
Caps / Drive Flanges
I replaced my CV's and drive flanges with the longer "7mm" and found that the dust caps were loose on the new flanges.
A bit of tin bashing was required to shrink them so that they fit firmly.
Down here in NZ it is also recomended to use a bit of silicone sealant when fitting them as they are NOT water tight and we all know what water does to bearings!!
Mine 1992 HDJ-81, Triple Locked, Factory Sun Roof, Safari Intercooler, Airtech Snorkel, Milford Cargo Barrier, Ome 2" lift, Warn XP9000, Hella Rallye 2000's ARB Winch Bar.
Hers 1992 HDJ-81, Triple Locked, Factory Sun Roof, Milford Cargo Barrier, ARB Winch bar, Hella Rallye 2000's, Safari Snorkel.
Sarmajor is offline   Reply With Quote
Old 05-30-08, 06:57 AM   #16
After further inspection...........it does have the green birfield in it. Also the inside of the dust cap has interference marks from the birfield. So....Dan I need the new flange and new dust cap!
Old 05-30-08, 12:10 PM   #17
Tapage's Avatar
Sarmajor ..
Did you know if someone with the longer bierf are install 'em in a part time 80 or at least with AISIN hubs .. ?
P.S. thanks for your info Mr. Dan
Old 06-10-08, 11:50 AM   #18
Update for people with this problem. Dan was correct, I needed the thicker drive flange. Got the parts put on last night....all is well. BTW....that c-clip is a PITA to put on by yourself!
Thanks for everyones help..........again!
Old 06-11-08, 01:40 AM   #19
Sarmajor's Avatar
birfields
Originally Posted by Tapage View Post
Sarmajor ..
I have had no experience with Free wheeling hubs at all. Perhaps someone else can answer this question??
Cheers
Hedley
Equity Release | Personal Loans | Remortgages | Online Loans | Credit Cards UK
