Old 05-24-08, 12:47 AM   #1
New Headlights - more light please
Anyone seen or installed the DEPO headlights on their 80? I know the stock 80 lights don't put out much light and I didn't want to go with projectors. I just saw them on eBay (link below) and they look interesting...
Search results for Toyota depo landcruiser in Car & Truck Parts & Accessories
mihnitsurti is offline   Reply With Quote
Old 05-24-08, 01:34 AM   #2
fjfar80's Avatar
Mihn -
I have not heard of anyone using these lights. They are a product of Maxzone Performance lighting correct? They look fairly decent...similar to the 100 series lights. I would be interested in how the fit and finish is on them if you purchase a pair and the lighting.
Cheers.
- MWF
1997 FZJ80 - Flareless, Lined, MetalTech Sliders, LandTank MAF, PM'd to the Gills, 285 BFG ATs, Alpine, and XM but, just starting (it's sitting in CONUS...a bit lonely..awaiting customization and ready to get Super Charged)
1997 BMW 528i - AC Schnitzer'd out (right-hand drive)
1988 E28 M5 - Currently being restored in the US
"It is not the critic that counts" TR - 1910
http://faragesgarage.blogspot.com
http://www.flickr.com/photos/mrgarage
fjfar80 is offline   Reply With Quote
Old 05-24-08, 02:30 AM   #3
wearsabrowncoat's Avatar
I would say try the HIR bulbs and Slee wiring harness first. Proven improvements at fairly inexpensive prices. I am very happy with mine.
96 LX450 Locked, 285/75/16 BFG A/T, ARB, Warn 9000i, CDL+7 Pin, Dual battery trays w/ Slee style battery isolator, Auto up window, Landtank MAF & seat rails, LR cup holder, George's LEDs, Slee light harness, Deere bulbs, Clearshield headlight film, Slee style aux fuse box, Maglite holder.
wearsabrowncoat is online now   Reply With Quote
Old 05-24-08, 08:22 AM   #4
Darwalk's Avatar
TLCA# 18037
I have them. They are MUCH brighter than the stock ones. My complaint is that they give off an off pattern at the top of the projection. Other than that, they fit great, they are fully adjustable, and they look stock. I took the chrome trim off of my originals so that it would match the other chrome.
Darrin Walker
1997 FZJ80- MAF 5" comp kit, MAF HD rear links, Toyo Mt's, locked
CAL4WD# 10820
Darwalk is offline   Reply With Quote
Old 05-24-08, 09:24 AM   #5
Atoyot1031's Avatar
TLCA# 18402
Pics?
"Macadamia nuts in mixed nuts?!? Now that's a high class nut mix..." -Anonymous quote heard during a CM08 lunch break in the worm hole on Kane Creek
Atoyot1031 is offline   Reply With Quote
Old 05-24-08, 10:47 AM   #6
robmir's Avatar
Headlamp clear front is made of Glass or Acrilic ?
Uses the OEM USA spec bulbs or the E spec H4 for the low and H1 for the high ?
Could you please post a picture of them against a wall to understand your concern at the illumination pattern ?
Thanks in advance.
1993 FZJ80, 2" OME, 305/70-16, Auburn Locker, F&R TJM bullbars,Long Range 150 ltr gas tank, 170 Amp alt, 240 amp 3 Battery Isolator & 3 Deep Cycle batt,4 DBA slotted rotors, Carbon/Ceramic pads, SS/Teflon brake hoses, Warn 9000, PIAA 80 Racing,Coil&Shock Dampened Front Seats.Engel 60 Qts Fridge.
robmir is offline   Reply With Quote
Old 05-24-08, 02:53 PM   #7
Splittilps's Avatar
I was looking at these lights and was wondering if they uses the same bulbs as the originals or do you have to change the wiring harness?
Splittilps is offline   Reply With Quote
Old 05-24-08, 02:54 PM   #8
Splittilps's Avatar
O... I forgot to say I Have a HDJ81 RHD if that makes a difference
Old 05-24-08, 04:14 PM   #9
I have these lights. They fit well (considering my 80 was wrecked on the front end) and they are brighter than stock. They use an H1/H4 combination for the bulbs.
Izeloz is offline   Reply With Quote
Old 05-24-08, 07:09 PM   #10
robmir's Avatar
Same question please: glass or plastic front lamp ?
OEM is glass and never will be damaged by UV rays
Old 05-24-08, 09:33 PM   #11
Darwalk's Avatar
TLCA# 18037
Here you go......
And the lenses are glass, not plastic, or poly......
Darrin Walker
CAL4WD# 10820
Old 05-25-08, 01:06 AM   #12
medtro's Avatar
From the ebay auction
Quality: Made by Depo, quality tested, clear lens are made of glass
Copper State Cruisers #005
medtro is online now   Reply With Quote
Old 05-25-08, 09:38 AM   #13
Darwalk's Avatar
TLCA# 18037
The pic I put up shows the chrome a little off on the top, but that is how my stockers were too, so I wasn't to concerned about that. The lights themselves fit great into the stock location, and the lens adjusting screws are right on top of the units, so they are simple to adjust.
I am down in Mexico right now, so I can't take pics of the light projection, but I will on Monday when I get home.
Darrin Walker
CAL4WD# 10820
Old 05-25-08, 11:00 AM   #14
Where are my keys?!
treerootCO's Avatar
TLCA# 14133
picked up a set for project ptarmigan
aka Mike D.----->Bio Page
"Its better to be thought a fool rather than to speak up and remove all doubt." - Lincoln
Workin' on pimpin' the 80...
www.root45.com
www.risingsun4x4club.org
TLCA #14133
treerootCO is offline   Reply With Quote
Old 06-18-08, 01:47 PM   #15
If these use H1/H4, do you need to change the harness to switch from 9005/9006?
Old 06-18-08, 01:49 PM   #16
You will need to change the harness. I upgraded mine at the same time by adding relays and heavier gauge wiring.
Old 06-18-08, 03:50 PM   #17
CreeperSleeper's Avatar
TLCA# 15577
Oooh! That seems like a better idea than the ricer projectors...
Chad
Cascade Cruisers- President
KE7VSA
Views from the Creeper
MetalTech
Originally Posted by DanKunz View Post
You stacked rocks to climb your porch......HA!!!
CreeperSleeper is offline   Reply With Quote
Old 06-18-08, 09:16 PM   #18
jvazquez53's Avatar
How about HID. So far I'm happy with the OEM headlights
José
92 FJ80
83 FJ60
76 Fj40
74 TY250
83 IT 175
85 TY350
DT250
91 Isuzu P/UP
79 Plymouth Trailduster
72 Jeep Commando
jvazquez53 is online now   Reply With Quote
Old 07-01-08, 12:17 AM   #19
DUM8HIT
T Y L E R's Avatar
Hmmmm
Could you start with this headlight setup, BUT bake apart the lens and attach it to the stock headlight body after modding high/low projectors into the back of the stock setup?
I'd like to go projectors once I round up all the bits, and I like the idea of keeping glass if I can, and this setup has clear glass .. nothing to grind, and nothing to mess up the light pattern on the way out.
TY
Hybrid suspension - Slee 4" Front/OME863 Rear, Slee Front control arms, Slee DIY adjustable panhards, Slee sliders, 36X13.5R16 IROK radials on AR Black Trenches, 1.5" Trail-Gear spacers, Toughbook CF74 with GPS etc, sans roofrack, jumpseats, lockers. Clear lenses abound
T Y L E R is offline   Reply With Quote
Old 07-15-08, 06:56 PM   #20
Where are my keys?!
treerootCO's Avatar
TLCA# 14133
write up on installation of these headlights.
http://forum.ih8mud.com/80-series-te...ml#post3485348
www.root45.com
TLCA #14133
Old 11-06-08, 08:08 PM   #21
IH8Mud4Life
PScottBx's Avatar
TLCA# 16251
Old thread, sorry... but any other way to source these that anyone knows??
Thx...
Bx
1982 FJ45 Troop Carrier "Matilda" - - 1996 LX450 "80 in drag"
Good friends, a few cruisers, alot of laughs and a bunch of wives making this face -->
"If I'm off (which is rare)... I'm in!"
PScottBx is offline   Reply With Quote
Old 11-07-08, 07:16 AM   #23
alia176's Avatar
TLCA# 15941
I second the HIR lights. They're quite impressive using stock light circuitry. If they're not bright enough, then get an aftermarket headlight harness and see if that makes a difference. If they're STILL not good enough, then try the more exotic stuff.
I have the low beam and high beam HIRs and am very pleased.
TLCA # 15941
KE5LED
Currently working PA
alia176 is offline   Reply With Quote
Old 11-07-08, 07:31 AM   #24
VFRMAN's Avatar
I just installed the "high beam" HIR's from Max Lumens, into my "low beam" sockets. You have to modify the new bulbs with a clipper as usual, but then take the rubber o-ring off the old low beam bulbs and slip it over the top of the new bulb. Simple process. Light output is amazing and no glare, no pissed off traffic. All the fuss with anything more exotic seems like a waste to me.
There's a link for it somewhere. I can find it and post it up if anyone hasn't seen it. Must be old news, but I finally just did it last week. Very happy.
(And I had already installed the Slee harness prior to as well.)
96' FZJ 80,295/75/16 BFG KO's, 172k, OME Med,
08' Odyssey (yep, mini van)
01' Jetta VR6 SOLD!
96' Accord Wagon
04' CBR600RR
98' XR400R
VFRMAN is offline   Reply With Quote
Old 11-07-08, 08:55 AM   #25
Hi,
are those lights DOT approved??
TIA
Simon
Winnipeg
needs headlights for my HDJ81
simonliew is offline   Reply With Quote
Old 11-07-08, 09:29 AM   #26
what rubber o-ring?
I changed to HIR as well, there was no o-ring to remove from the old bulb that I saw...
Melovesha is offline   Reply With Quote
Old 11-07-08, 01:02 PM   #27
mot
I ruin surprises.
mot's Avatar
Originally Posted by simonliew View Post
Hi,
TIA
Simon
Winnipeg
Simon,
I "believe" they claim to be DOT approved (And has the stamp in the back/top of the housing (Not sure about whether there was one on the lense).
HTH's!
mot is offline   Reply With Quote
Old 11-07-08, 01:26 PM   #28
VFRMAN's Avatar
This is from an email from Max. Here is the link : http://shnu.us/HI-LO2.htm
"This is the single-step procedure for stock replacement trimming:
HIR 9011 and 9012 bulbs are exactly identical in all dimensions to 9005 and 9006 bulbs, except for two areas, the second of wh
To do the hi-lo conversion, there are three steps-
1) Trim the top tab to fit in a low housing socket (remove the side opposite to the white section, approximately). If the bulbs are not marked, refer to your current 9006 low bulbs and trim the new ones to match.
2) Cut the double guide rails out of the plug section of the bulb. Dremel, utility knife, soldering tip all work well.
3) Double up the o-ring, putting your old o-rings on the barrel of the 9011 bulb behind the existing ones. This centers the bulb and keeps it watertight. "
01' Jetta VR6 SOLD!
96' Accord Wagon
04' CBR600RR
98' XR400R
Old 11-07-08, 01:29 PM   #29
VFRMAN's Avatar
