Old 05-20-08, 11:53 AM   #1
TN_LandCruiser's Avatar
TN_LandCruiser is on a distinguished road
Rear diff (3rd) seal leak
A couple weeks a go I noticed a small leak from the front of the rear differential just behind the coupler between the DS and the diff. I dont know exactly what to call this... This leak has become much more prevalent in the last two weeks and it now leaving puddles of stinky gear lube everywhere I park.
Does anyone have experience with this seal leaking and if so, what is the easiest way to fix it??? I can get pics if necessary.
Thanks!!!
1992 FJ80
7 Pin CDL Mod
265/70-R16 Maxxis Buckshot Mudders
OME J's front
OME Heavies Rear
ProComp 9000 shocks
Custom built Rear bumper & sliders
http://forum.ih8mud.com/tn-stlca/198...ml#post2927590
http://Schafer_Photography.photoshop.com
TN_LandCruiser is offline   Reply With Quote
Old 05-20-08, 12:38 PM   #2
The quick brown fox .....
Beowulf's Avatar
Beowulf is an unknown quantity at this point
That sounds like your pinion seal. I have not done that repair so not much advice on that. The "coupler" is called a Universal Joint; aka U-Joint or "uni" in OZ.
-B-
97 FZJ80 - Landtank MAF, locked, 315 Toyos, 4.88s, Slee 4", George's sliders, Slee bumpers, M12000, OBA, Outback drawers + other stuff. Transformation in progress...
Old 05-20-08, 12:47 PM   #3
Yes, thats it...THANK YOU. Its the rear pinion seal...ok, now that thats identified...who can tell me how to fix it? That gear lube stank is eating my garage walls!
1992 FJ80
7 Pin CDL Mod
OME J's front
OME Heavies Rear
ProComp 9000 shocks
Old 05-20-08, 12:48 PM   #4
Shipwreck's Avatar
TLCA# #4695
Shipwreck
The first thing I would do is remove the drive shaft and check the torque specs of the pinion nut. Pinion seal leaks can be indicative of a loose pinion nut which then allows movement of the upper bearing and excess wear and leakage at the seal. IIRC the torque should be in the neighborhood of 160 ft/lbs and the nut should be staked properly.
If all looks good, then remove the nut and pull the pinion flange. Check for a groove where the seal rides. If there is a significant groove, the pinion flange will either need to be replaced, or a speedi sleeve placed over the groove. You can now pull the pinion seal and tap in a new one. Check the washer underneath the seal for grooves and wear. This washer can spin around the upper bearing if the pinion nut was loose. Once the new seal is in place, put the pinion flange back on and tighten and stake a new nut.
There... You're done.
'75 FJ40 at work
'97 FZJ80 on the sand
Craig Park
PMC
TLCA #4695
Shipwreck is offline   Reply With Quote
Old 05-20-08, 01:12 PM   #5
Well that just sounds to easy to even be called a repair...Im guessing its a tad more labor intensive than you make it sound...LOL.
1992 FJ80
7 Pin CDL Mod
OME J's front
OME Heavies Rear
ProComp 9000 shocks
Old 06-04-08, 08:59 PM   #6
Well he sav'd the beer...
MarcoPolo's Avatar
MarcoPolo is on a distinguished road
How did that work out for ya? Got similiar work to do on my 40.
My pinion has a slight bit of movement however... maybe take care of that come fall/winter.
Marco
76'fj40 - Rancho Lift (kidney belt required), Detroit locked up front
2F 76,000+miles, workin out the rest...
Thank_a_Vet_young_&_old
Allowed to run wild, neglected, or cultivated .... A man's mind brings forth... If no useful seeds are put into it , an abundance of useless weed seeds will fall into it , and will continue to produce their worthless kind ... James Allen
MarcoPolo is offline   Reply With Quote
Old 06-04-08, 10:10 PM   #7
Havent gotten around to fixing it...but need to. Its pouring out. Entire underside of the truck is covering in nasty gear lube. Found a local axle shop that will hook me up for $50 if I supply the parts and remove the DS. Looks like CDan can get the parts for me for around $30, but the shipping is more than he could save me, so Im going to prolly call my local Yota shop.
1992 FJ80
7 Pin CDL Mod
OME J's front
OME Heavies Rear
ProComp 9000 shocks
Old 06-05-08, 12:57 AM   #8
Tools R Us's Avatar
Tools R Us is on a distinguished road
There is no torque spec on the pinion nut. It's an adjustment, the nut is tightened until the preload/rolling drag on the pinion bearings is correct. The tension is maintained by a crush sleeve that is between the bearings. That sleeve is single use, so the only way to correctly do it is to take it apart, replace the sleeve and set it up properly.
Copper State Cruisers #007
Loans | Refinance | Mortgages | Loans | Mortgages
