Old 05-20-08, 09:07 AM   #1
YinDW is on a distinguished road
a/c temp cut switch
I have figured out what happened to my a/c for my 97 landcruiser. The a/c temp cut switch has failed. It is located on the cold side (driver side) of the engine block next to the coolant temp sender.
The FSM does not tell me whether or not I can replace the unit without removing the intake manifold.
I tried to put a deep socket on it but it did not do it. Any advice on how to replace this switch?
YinDW is offline   Reply With Quote
Old 05-20-08, 09:43 AM   #2
Photoman's Avatar
Photoman is an unknown quantity at this point
It should be a 19mm deep well. There is a “tab” that sticks down so to socket has to clear this to go on, but it should be no problem. A 6 point socket would be best.
Old picture.
Bill
If it ain't broke, fix it until it is.
97 40th
Photoman is offline   Reply With Quote
Old 05-20-08, 10:12 AM   #3
You want to do what...?
e9999's Avatar
e9999 is an unknown quantity at this point
"cold" side...?
don't you think they would rather put it at the highest temperature point (coolant leaving the engine)?
'97: 86K, 3xlock, Custom HD roo bar for sale, 285 MT/Rs on steelies, Hanna sliders, 851+1.5"/863/N73/N74E/SD24, ARB bull with M12, Kaymar with duals, Kaymar rack, Slee TC skid, 2m/440, more stuff, loose nut behind the wheel!)
'03: 97K, the better half's...
DD
Old 05-20-08, 10:37 AM   #4
miked's Avatar
miked
At what temp does this cut out?
It happened to me the other day while sitting at a light in a high ambient temp.
miked is offline   Reply With Quote
Old 05-20-08, 11:41 AM   #5
e9999's Avatar
number floating around is 226F IIRC. IOW, if you are cutting off at a traffic light under no load cuz of high temp, you likely have a cooling problem to look at immediately.
DD
Old 05-20-08, 12:00 PM   #6
94cruisercal's Avatar
94cruisercal is on a distinguished road
Originally Posted by e9999 View Post
"cold" side...?
The cold side location is probably ideal to sense the efficiency or lack of efficient operation of the radiator. Your coolant Will be hot leaving the engine however if it is still too hot after leaving the radiator then you have a problem
94cruisercal is offline   Reply With Quote
Old 05-20-08, 12:33 PM   #7
cold side explained
i apologize for the erroneous reference to diesel engine engineer talk.
I work with a lot of diesel engine (6 cylinders) applications. "Cold side" refers to the side of the engine compartment with the intake. The "Hot side" is the engine compartment that has the exhaust manifold.
Just a point of reference. Please ignore that...
Old 05-20-08, 02:33 PM   #8
e9999's Avatar
ah, good to know! interesting.
DD
Western Union Money Transfer | Credit Card Consolidation | Hookah | Mortgage | Cheap Car Insurance
