Old 05-19-08, 12:16 PM   #1
GSMTR Chair
Trollhole's Avatar
TLCA# 15077
93 tranny issues
Has 215k 93.
Tranny has been flawless. Fluids have been changed regularly.
Just drove it through the mountains this week with no issues. Get in this morning and have to get on the gas a little. It slips. Only slips at high rpms when changing gears. Nothing under 4k. Didn't notice it in 1st to 2nd only 2nd to 3rd. Can pretty much peg the engine when changing gears. Assuming I keep my foot off the skinny pedal it works just fine.
Not good though.
Ideas or suggestions to try.
Has been good to me up until now.
Marshall
Upstate Cruisers
Toyota part number lookup Click here!
Buying a Land Cruiser Guide
73 Fj55 Big Ugly
76 FJ40 ROTW Big Gay 2f Build
75 FJ55 My Build
93 FZJ80 stock everything and staying that way.
Old 05-19-08, 01:47 PM   #2
sseaman's Avatar
have you checked the fluid level today?
91 FJ80 318k, spare tire mod, custom roof rack----SOLD
98 4runner 141k---SOLD
98 Avalon 149k
04 Sequoia 74k
sseaman is online now   Reply With Quote
Old 05-19-08, 03:22 PM   #3
GSMTR Chair
Trollhole's Avatar
TLCA# 15077
Yeah. I'm good there. Fluid has about 15k on it.
Marshall
Upstate Cruisers
73 Fj55 Big Ugly
75 FJ55 My Build
Old 05-19-08, 07:27 PM   #4
Cruiser Jimmy's Avatar
TLCA# 12112
Have you made any adjustment to the kickdown cable yet before or after the problem?
According to my FSM ('92) this is what the A/T General Troubleshooting section says:
Problem:
Slips on 1-2, 2-3 or 3-O/D up-shift, or slips or shudders on acceleration.
Possible cause:
Manual Linkage out of adjustment
Throttle cable out of adjustment
Valve body fault
Transmission fault
Also, Did you keep the tranny out of overdrive in the mountains?
TLCA Chapter Club
'92 FJ80, '83,'87 FJ60
2008 Toyota Trail Teams: East Coast
Cruiser Jimmy is offline   Reply With Quote
Old 07-28-08, 02:36 PM   #5
Vitesse_6's Avatar
TLCA# 8382
FWIW My Throttle Valve Cable took a dump this weekend.
Somehow the cable was crossing over to the throttle or cruise control cable cradle and not letting the RPM's drop, Unless I tapped the throttle a few times.
I will be replacing mine very soon.
Enjoy
Brian Passey KE7TGH
wasatchcruisers
71 FJ40 Stinky
94 FZJ80 Ryoku Ryu
Cruiser ring's anyone
Stuff I've done...
My 40 work in progress
Vitesse_6 is offline   Reply With Quote
Old 07-28-08, 03:16 PM   #6
Check the throttle position sensor cable, if it's a bit slack you'd get slipping like that. Chances are it's slipping a bit on other changes and you're not noticing so I'd check it out soon so you're clutch plates don't get more worn out.
I've had two cables go bad on me. The first time I carried on driving the truck for about 6 months like it, manual shifting to avoid the judder on some gear changes. What I didn't realise at the time was not enough pressure was being put on the clutch plates because the valve body / ECU was being told light/no throttle was being applied. It wore the clutch plates out and cost me a rebuild ... I would advise you not to make the same mistake I did
The cable is a bit of a PITA to change but nowhere near as bad as a tranny rebuild.
I think checking the throttle position sensor cable adjustment should be regular PM to keep your clutch plates in good shape.
Jon.
01 UZJ100
93 & 94 HDJ80s
wildsmith is offline   Reply With Quote
Old 07-28-08, 06:15 PM   #7
I'd go with the cable adjustment as well - particularly since there are no other symptoms and good care.
DougM
'93 FZJ since new, 2.2kw starter, Revo 275s, locked, big Hellas, rr fog, rr flood, rr Airlift, synthetics, ARB bullbar. 97 FZJ - exact same stuff but Michelin Alpins in winter "Slicker than owl shit on a wet log." - Carter
IdahoDoug is offline   Reply With Quote
Homeowner Loans | Magic the Gathering trading | Car Credit | Loans | Mobile Phones
