Old 05-18-08, 11:15 PM   #1
monteburns's Avatar
Brake-like scraping noise--from driveshaft?!
My 94 has developed a brake wear indicator sound that sounds like its coming from the front drive shaft. In fact, its so similar, I thought it was the brakes. I was shocked when I pulled all the wheels and found nice fat brake pads. The Cruiser drives normal, no vibration, grrrrr/rumbly sounds, no binding, etc. I greased the drive shafts and that seemed to make it a bit more quiet, but not much. Maybe my imagination.
Characteristics:
  • Metallic sound--scrape-scrape-scrape
  • Particularly loud when just starting out.
  • Sounds the same in forward and reverse.
  • Very noticeable at low speeds, even super slow speeds, but non-existent when getting up above 20 mph.
  • You can hear it when you're just barely letting your foot off the brake enough that the cruiser starts to move.
  • Makes the noise whether you press the brake or not.
  • Sounds like its coming from the front driveshaft location.
Thanks for your help!
1994, 285/75/16, Amsoiled, 168K miles, eternal CEL Code 71. Wife doesn't want a new minivan, but likes the 94 LC. I'm a lucky dude.
monteburns is offline   Reply With Quote
Old 05-19-08, 03:54 AM   #2
grown up MOD
reffug's Avatar
TLCA# 14549
Sounds like something in the DS is worn to the point of needing to be replaced.
If you greased it and it got better but then came back its probably time to rebuild the shaft.
"If it wasn't a Landcruiser and hadn't been built the way it was you do realize you would be DEAD." VA State Police Officer
reffug is offline   Reply With Quote
Old 05-19-08, 07:55 AM   #3
monteburns's Avatar
What is involved with a rebuild? Simply replacing the U-joints, or are there other things to do as well?
What does it cost?
Old 05-19-08, 09:03 AM   #4
CodyRx7's Avatar
Did you remove the rear resonator on your exhaust?
After I did, and didn't realize the mount near the center of the exhaust was on its way out - this allowed the stock muffler to just make contact with the rear driveshaft.
Sounded exactly like sticking brakes...or pads just on the wear indicator.
It drove me crazy so I pulled all the wheels to check the pads and when I had it up in the air I found the muffler touching the rear DS.
I've since replaced the stock muffler and added a new hanger out back.
97 LX450 - Champagne Silver / 161k / 5.29s / ARB lockers F/R
39" Michelin XML tires, 8" coils / L shocks, 1.5" wheel spacers, Slee caster plates, ARB rack & Safari Snorkel, 60 ARB bullbar, custom sliders, dual swingout rear bumper, Overland RTT on a Monster M100 trailer
Copper State Cruisers #045
CodyRx7 is offline   Reply With Quote
Old 05-19-08, 09:17 AM   #5
easyG's Avatar
X2 on what CodyRx7 said. I had the same thing happen when I broke that mount wheeling, muffler gets banged by the rear drive shaft. I noticed it mostly when I was turning.
____________________________________________
Here's to life...
97 locked 40 th Anniversary
04 Mazda 3 5 door
96 Chevy 3500 2wd crew cab 4 SALE
93 Chevy 2wd reg cab
91 Honda Accord
easyG is offline   Reply With Quote
Old 05-20-08, 08:13 AM   #6
monteburns's Avatar
Ok, on a thorough visual inspection, I found nothing touching either drive shaft. I did notice, however, that it appears that diff fluid is leaking out where the front drive shaft connects to the diff. Its not a big leak, but a leak nonetheless.
This is where the scrape sound appears to be coming from. The ring on the front drive shaft is on tight as well.
Old 05-21-08, 03:46 PM   #7
monteburns's Avatar
Any ideas on the above leak question?
Old 05-21-08, 09:29 PM   #8
dixie_cragger's Avatar
I had a similar noise on my truck and it went away with a new DC Slee shaft. I would pull off the front DS and see if the noise goes away. It's super easy (8 bolts and half a banana job) but it helps to run 2wd with a CDL switch!
1990 FJ62 (166k miles)
- ARB F/R Armor,OMEs,33" BFG M/Ts
1997 FZJ80 (118k miles)
- ARB/JKCustoms F/R Armor, OMEs,Warn 12k,IPF Spots,SLEE DC D/S,CDL, 35" Toyos
dixie_cragger is offline   Reply With Quote
Old 05-22-08, 02:51 AM   #9
grown up MOD
reffug's Avatar
TLCA# 14549
definately pull the DS and lock you CDL.
if the noise goes away then you have isolated the problem.
then either order the parts from Cdan to rebuild or take it to a reputable DS shop.
Old 05-22-08, 07:48 AM   #10
lathamb's Avatar
You might want to also check the little metal cover that is over the inspection hole on the brake calipers. One of mine got bent up just a little and made a very similar sounding noise. You might be able to see a line of wear on the inside of one of your rims.
Ben Latham
TLCA 18184
'74/'78 FJ40 in progress
'96 FZJ80: locked, OME'd, ARB'd, 305'd, CDL/Pin 7, JD HIRs, Blue Top Optima
lathamb is offline   Reply With Quote
Car Finance | Credit Counseling | Bank Accounts | Switch Energy Supplier | Ugg
