#301 | |
Just for the record a 1FZFE short block is about $3k. That will suck up a lot of fuel savings if you blow one up. Yes, he is experimenting on his truck, but he is also an installer. So in essence he is somewhat acting as a vendor for these systems. So I think we can ask questions. If he does not want to talk about this system, why start the thread?
PS, this is the first line of the first post Quote:
#302 |
yessir! Im more than willing to answer questions when they are actual questions not stuff intended to be idiots or just annoy me. Im not leaning the gas out THAT much. I have never seen the temp gauge go higher than the half mark (stock running temps) on the cars I have done.
__________________ Blake 89 FJ62 SOLD- 98 C43 AMG benz- Crashed :-( 2001 Tacoma Double cab- TRD, Supercharged, Headers, Exhaust, Intake, Stereo- TRADED 01 Jetta, modified to no end! SOLD 94 Cruiser- 6" slee, Arb, 4x4 Labs rear, HID, Sliders, Dual batteries, Stereo in the works, 35's |
#303 | |
By the time the temp gauge move on the 80, it is to late. Temperature is not an indication that you are not detonating.
How much are you leaning it out? How do you quantify it? If you double the fuel mileage, you have to be taking 50% of the fuel away and adding something to make up for it. Otherwise it won't have the same power. You also state this in a earlier post: Quote:
#304 |
A characteristic of the open-loop controller is that it does not use feedback to determine if its input has achieved the desired goal. This means that the system does not observe the output of the processes that it is controlling. Consequently, a true open-loop system can not engage in machine learning and also cannot correct any errors that it could make. It also may not compensate for disturbances in the system.
OPEN LOOP Open-loop controller - Wikipedia, the free encyclopedia I don't trip codes I dont get knocking engines run smoother ect. I really do not think I am leaning it enough to hurt anything. on a obd2 setup I normally look for a number around 0% fuel trim short and long term than I check the actual engine coolant temp, I test making sure there has been no power loss at any point in the throttle using an accelerometer (belkin) __________________ Blake 89 FJ62 SOLD- 98 C43 AMG benz- Crashed :-( 2001 Tacoma Double cab- TRD, Supercharged, Headers, Exhaust, Intake, Stereo- TRADED 01 Jetta, modified to no end! SOLD 94 Cruiser- 6" slee, Arb, 4x4 Labs rear, HID, Sliders, Dual batteries, Stereo in the works, 35's |
#305 | ||
Temperature is not an indication of detonation. You can have mild detonation without temp increases. You will not know it. An accelerometer does not monitor power, it monitors acceleration. You should put it on a dyno to see if you are loosing power. |
#306 | |
Ideally, SS would have a dyno, but if that isn't feasible one would think that an accelerometer would be useful even if less than ideal. __________________ 95 FZJ80 custom headers & 3" flowmaster exhaust, 4" OME lift (with CC bushings, x br lines, adj panhards, heavier dropped sways), ARB lockers, 35" BFG A/Ts, dual dry cell batteries, 2300 watt inverter, speedo corrected, & Kaymar w/carrier Next: 5.29 gears, winch |
#307 | |
The quick brown fox .....
Do you mean a Beltronics accelerometer? -B- __________________ 97 FZJ80 - Wing Nut MAF, locked, 315 Toyos, 4.88s, Slee 4", George's sliders, Slee bumpers, M12000, OBA, Outback drawers + other stuff. Transformation in progress... Sometimes you find yourself in the middle of nowhere. And sometimes in the middle of nowhere, you find yourself. |
#308 |
HAHHAah yes you got it. I have no idea where I got belkin from
#309 | ||
Also, I do not believe that the fuel cell can produce enough to make a difference. People have been using propane for a long time to increase gas mileage. Ask the people in OZ and Europe. However also check the size of the tank they add as well as the pressure in the tank. |
#310 |
I don't think the hydrogen does much of anything. I just went on a drive with the cell turned off and noticed no difference in power. I think it is the combination of everything
#311 |
Also note that the device in question here is nothing like a fuel cell. A fuel cell produces electricity from fuel (H2, hydrocarbons, alcohols, etc.) and oxidyzer.
#312 | |
True, but wouldn't WOT be a constant?
I have had interest in this hydroxy thing ever since I saw a news story on it about a month ago. I remain unconvinced, but still interested. I would like to become convinced. If SS comes back and says "no power loss and 25mpg" I will be even more interested. Otherwise, my interest will obviously fade or evaporate. So drive on SS. Convince me I should stay interested. __________________ 95 FZJ80 custom headers & 3" flowmaster exhaust, 4" OME lift (with CC bushings, x br lines, adj panhards, heavier dropped sways), ARB lockers, 35" BFG A/Ts, dual dry cell batteries, 2300 watt inverter, speedo corrected, & Kaymar w/carrier Next: 5.29 gears, winch |
#313 |
Sure, but how are you going to control all the other little variables that come into play? Ambient temp, wind, traffic, etc....
A timed run ("I can run the quarter mile in 123 seconds") would work, but it'd need to be done multiple times (with and without the system) to really get an idea of the difference. __________________ '97 LX450 - The -mobile-roof rack, CDL button, 7 pin MOD, Auto Up Mod. '96 LX450 - New toy! ![]() Triple locked, -running boards, 1" body lift, grey wire mod. Jefferson State Cruisers (A wholely owned subsiderary of OR/CA TACO) Forums |
#314 | |
SS, multiple runs would probably be a good idea. __________________ 95 FZJ80 custom headers & 3" flowmaster exhaust, 4" OME lift (with CC bushings, x br lines, adj panhards, heavier dropped sways), ARB lockers, 35" BFG A/Ts, dual dry cell batteries, 2300 watt inverter, speedo corrected, & Kaymar w/carrier Next: 5.29 gears, winch |
#315 | |
I would like nothing more than to be able to repower my 80 with a 22RE 4 cylinder engine and a 110 volt motor to back it up. It would go faster, and climb obstacles better. My 6,000 lb truck would actually have some real performance on the highway. The lemon in the fruit basket is the battery. GM recently developed a hybrid truck that used the venerable 4.3 L V-6 in trucks up to the one-ton 4WD dual rear wheel. It produced more direct brake horsepower than the big-block version. Yet it clocked in at over 26 MPG on the highway! This development was written up in automotive insiders magazines 8 years ago! The technology is in place. The truck was aimed at remodelers and landscapers. It would run power tools or electric lawnmowers for several hours without a recharge. This reduced both carbon and noise emissions. That truck ran on common household current, making it a generator for running a freezer in the most remote areas. A hunter could dress and quarter a deer in any place without bringing it home first. The venison would arrive at his home already cut and frozen. A man who wants to go camping might call his wife. "Honey, get the blender and the microwave, we're going camping!" The GM truck project was scrapped due to the lack of battery technology and proper disposal of dead batteries. The NMH batteries that are used in cel phones may be the secret. At present, they are costly to produce, and to dispose of safely. But in time, that may change. That should be the focus of our efforts. The hybrid may be the best future option. It produces better performance than current fuel engines can do, and it gets far better fuel economy. But it has some problems with battery cost and disposal. We need to work out those problems. |
#316 | |
__________________ Pat Doyle 1994 White FZJ 80, CDL switch. rear winch hitch attachment .-SOLD 1996 White FZJ 80, seats 7,leathered up, CDL,Locked,LandTanks MAF.2" OME lift/Shocks. |
#317 | |
Another issue beyond the obvious is an increase in overall consumption of electricity from the power grid. Nuclear power would be inexpensive, plentiful, and is the obvious solution. The current power grid could not support the sudden mass availability of efficient electric vehicles. Which brings us back to today. We need gas we can afford while we work on these issues. __________________ 95 FZJ80 custom headers & 3" flowmaster exhaust, 4" OME lift (with CC bushings, x br lines, adj panhards, heavier dropped sways), ARB lockers, 35" BFG A/Ts, dual dry cell batteries, 2300 watt inverter, speedo corrected, & Kaymar w/carrier Next: 5.29 gears, winch |
#318 | |
Silicon technology is dependent on the limits of process technology and atomic physics. Some of the limits of silicon Integrated Circuit (IC) technology are being reached today. It's why we're not seeing CPU clock speeds advance as they did through the 80's and 90's: it's just too difficult to get all parts of a chip to march in lock step when the number of transistors in a chip reaches a certain level. However, "Moore's law" is still holding close to true as the number of transistors on a single die continues to increase. Sorry for the slight hijack. I love computers
__________________ 1. 1993 FZJ-80 e-lockers, ARB bumper, extras FOR SALE!: Craigslist Ad and 'Mud Thread |
#319 |
I don't have time right now to answer questions/reply to statements but thanks Doyle Ill look for that thing! sounds like exactly what I need.
![]() I towed my bmw from here to just past san francisco today and that was like 100 mile round trip and it seemed to run well and ok power. got 14 mpg... BAD so I gotta get this thing leaning out NEED NEW 02 sensor!!! __________________ Blake 89 FJ62 SOLD- 98 C43 AMG benz- Crashed :-( 2001 Tacoma Double cab- TRD, Supercharged, Headers, Exhaust, Intake, Stereo- TRADED 01 Jetta, modified to no end! SOLD 94 Cruiser- 6" slee, Arb, 4x4 Labs rear, HID, Sliders, Dual batteries, Stereo in the works, 35's |
#320 | |
#321 |
Love the old car there. Wish I had a TII now.
#322 | |
ThinkTank Waterboy
Adjusting the trucks so the LTFT% is 0 is a really bad idea. The two major influences on LTFT% is the altitude the vehicle is in and the air temp (density) at that time. My truck has a LTFT% of +3 because I'm at sea level and others in higher elevation have LTFT% of -6%. This has been recorded on several trucks and I'm confident it can be relied on. So targeting a specific value all the time with give you varied results. It would seem you need to read the LTFT% prior to the install and then calculate a %drop in it to achieve consistent results. And the only way to do this is to leave the MAF signal alone. It's the one single signal that you would need to ensure that the LTFT% that you end up with is valid. __________________ Rick Bigelow '96 215k Groveland MA 01834 If you're not the lead dog, the view never changes |
