LinkBack (7) | Thread Tools | Display Modes |
#271 |
I understand it is an accelerator, but I would like to know what is the volume of hydrogen than is added to the fuel to make it so much more efficient. Also how is the hydrogen delivery to the intake regulated, or is it just sucked it as fast as it can be produced?
#272 |
grown up MOD
some of you folks need to back it down a bit and let Blake finish and post his numbers.................
end of story. I have warned previously but if things I don't consider appropriate continue I will bitch slap somebody. my advice is don't let it be you. __________________ "If it wasn't a Landcruiser and hadn't been built the way it was you do realize you would be DEAD." VA State Police Officer |
#273 |
I am not sure if I have explained this already so I will now.
on the average engine you have an 8ms gap between when your intake valve opens and when your exhaust valve opens- Gas is engineered to take 33ms to fully burn So you have all this unburned gas going into your exhaust manifold. In the space while both your intake and exhaust valves are open fuel begins being sprayed into the cylinder, this is to cool down the fuel so it does not burn in the manifold that is polluting and makes more heat in the engine bay so we have cooled it down and its all stuck in the catalytic converter- This is where your extra fuel is supposed to be burned so that it doesn't pollute. I focus all my efforts on trying to get as much of this fuel to burn in your cylinder that way theres less waste. I am not improving the engines efficiency at all. only attempting to get the gas to burn faster. think of it as a burning wood pile- an additive that burns faster and hotter will make the whole thing go up faster. __________________ Blake 89 FJ62 SOLD- 98 C43 AMG benz- Crashed :-( 2001 Tacoma Double cab- TRD, Supercharged, Headers, Exhaust, Intake, Stereo- TRADED 01 Jetta, modified to no end! SOLD 94 Cruiser- 6" slee, Arb, 4x4 Labs rear, HID, Sliders, Dual batteries, Stereo in the works, 35's |
#274 |
love to know were this figure comes from, source?
__________________ "Mate , you must drink some serious piss to need to get to youre chilly bin that quickly." - topend yobbo |
#275 |
LMBO my training class. I have no idea.
#276 | ||||||
#277 | ||
I'd like to see someone plumb in a cylinder full of H2 & O2(think welding gas bottle). Then do some experiments with the introduction at med and higher levels. That would take the whole snake oil/battery drain issue out of the equation.
I've been surfing the web hardcore lately on this and it is all over the map. However, I have read a couple of nuggets that referred to real scientific research that suggested the combustion of fuel (gas & diesel) improved. ***Found this info on gassavers.org I'm not suggesting any accuracy, just passing along info...*** Quote:
__________________ 85' FJ60 - 2F, desmog, 4-spd, 4.88's, Aussie rear, SOA, 37's on 2" bs Copper State Cruisers #71 KavikOffRoad.com 60 Series porn Last edited by Kavik; 06-19-08 at 08:25 PM. |
#278 |
it just seems to me that if there is only 8ms gap between when
your intake valve opens and when your exhaust valve opens your engine would be turning about 11,000 rpm... (but maybe i'm way off, my toddler has sapped what little mental acumen i once had) __________________ "Mate , you must drink some serious piss to need to get to youre chilly bin that quickly." - topend yobbo Last edited by JO MAOMA; 06-20-08 at 09:19 AM. Reason: spelllling |
#279 | |
![]() I am trying to understand this. I watched the 30 minute video that is not worth the tape it was recorded on, presented by a man that was previously involved in a huge scam. I think it this stays in tech, we can ask questions. Blake is installing these as a business (or at least for money) and has done the training from the company, so good or bad for him he should answer the questions. I won't get personal with Blake, but I do want to understand this stuff more, and don't tell me it is secrets only revealed in special technician training, because that is utter BS. |
#280 |
I suggest a "status thread" only Storm can(should) post in...
That way, for someone like me that does not frequent this tech can check up and not have to read through a thousand degrading posts..... just a thought __________________ "Let me have a Diablo sandwich, a Dr.Pepper...and make it fast, I'm in a *** **** hurry..." ... "You want sumpin?" "hush puppies daddy" "We got no time for that ****!" |
#281 |
I think that Reffug just indicated that this should be that status thread ...until the data is posted.
__________________ 95 FZJ80 custom headers & 3" flowmaster exhaust, 4" OME lift (with CC bushings, x br lines, adj panhards, heavier dropped sways), ARB lockers, 35" Toyo M/Ts, dual dry cell batteries, 2300 watt inverter, speedo corrected, & Kaymar w/carrier Next: ??? |
#282 | |
The quick brown fox .....
-B- __________________ 97 FZJ80 - Wing Nut MAF, locked, 315 Toyos, 4.88s, Slee 4", George's sliders, Slee bumpers, M12000, OBA, Outback drawers + other stuff. Transformation in progress... Sometimes you find yourself in the middle of nowhere. And sometimes in the middle of nowhere, you find yourself. |
#283 | |
Blake, you need to rethink your fast burning fuel statement. Good fuels burns Slower, Cooler, and more uniformly. Ruben |
#284 |
Most likely melt the piston? At what point would this happen Ruben? Don't answer me here though. Start a new thread to warn people of the dangers of melting pistons when their engines continually inhale small amounts of water gas.
__________________ 95 FZJ80 custom headers & 3" flowmaster exhaust, 4" OME lift (with CC bushings, x br lines, adj panhards, heavier dropped sways), ARB lockers, 35" Toyo M/Ts, dual dry cell batteries, 2300 watt inverter, speedo corrected, & Kaymar w/carrier Next: ??? Last edited by jamisobe; 06-20-08 at 12:39 AM. |
#285 | |
Without getting too deeply into the metals used and the chemical properties of available fuels, including even pure hydrogen, if the fuel mixture is leaned beyond a certain limit, the temps rise beyond the limits of the metal's tolerance. I have seen it all too many times. Excessively lean mixtures cause high temps that literally blow holes in pistons, the way that a torch cuts through steel. I have seen all too many cases where a simple intake leak causes one cylinder to run lean. The lean burn causes a hot combustion that can burn through an inch-thick aluminum piston crown in short order! I spent too many years with Honda, the leader of the lean mixture, to have any real illusions. Honda has some incredible lean-burn systems in production cars. The result is that we had some really catastrophic engine failures. Entire model lines were subject to not only burned out pistons, but even to holes torched through iron cylinder walls by excessive combustion temps. Mercedes has tested and driven a car that runs on creek water, by breaking the water down into hydrogen and oxygen. It burned the hydrogen and used the oxygen as a combustion booster. The technology was scrapped because it would severely deplete our water supply. The myth that a hydrogen and oxygen engine will emit an equal amount of water vapor was proven wrong. There is no magic in energy creation. Energy must consume, and once consumed, it cannot be reclaimed. It is certainly a valuable effort to find new ways to use fuels. But it is futile to return to areas that have been proven to be ineffectice or detrimental. Last edited by Brian Macgyver; 06-20-08 at 04:38 AM. |
#286 | |
grown up MOD
I've got no problem with the tact you have been taking Christo. My comment was aimed at those who are not trying to understand so much as call BS and the like. I respect your knowledge of these rigs as I am sure everyone else does and have no problem with your trying to further your understanding. Oh and shottz its totally different, he literally asks for it................. __________________ "If it wasn't a Landcruiser and hadn't been built the way it was you do realize you would be DEAD." VA State Police Officer Last edited by reffug; 06-20-08 at 07:55 AM. |
#287 | ||
I would have been happy if Blake said, hey I bought this and installed it and this is what I found but now he is an installed and he is doing it for money. So this thread is a ways for them to try and convince people that this stuff works. It might not have stated that way, but it certainly is borderline infomercial right now. All we need is Billy Maes. And I quote Quote:
My gut feeling is that they are leaning the hell out of the truck and all the other gismo's is to try and not blow the motor up. Some direct questions. 1 Why call it a vaporizer since it is impossible for that little heat exchanger to get the fuel close to a state of vapor. So this is the first BS. 2. Why baffle us with special magnetic aluminum. Where is the proof that this works. 3. What is the output of hydrogen and how is it regulated. How is it injected and controlled? 4. What signals does the optimizer interrupt. In the video they say that they do not do anything to the stock ECU or sensors, but they are clearly interrupting the signals. So what are they feeding the ECU ? 5. What are the HP and torque numbers? I know blake does not have access to a dyno easily (he could contact us and I can give him the details of the shop in Denver), but I am sure the parent company does. If we could do a pre and post dyno run just to prove a results for a couple of turbo installs, he should be able to do the same since he has a whole fleet of trucks lined up. 6. Consider the source. Have a look at this video. YouTube - Dennis Lee Free Electricity Humming Bird Sundance Generator Covers some other magic stuff. Does Dennis Lee have any credibility? Last edited by reffug; 06-20-08 at 07:55 AM. |
#288 | |
If technologies that have been proven ineffective in the past were discarded out of hand then there are many technologies that would be non-existent today. Like the automobile for instance, hybrid technology, or even solar power. I have not personally experienced a car increase its gas mileage from using water electrolysis and I understand that there may be problems with it. But to say forget about from the get go is premature. Why not explore? If "hydroxy boosters" are working to some extent then that is increased energy efficiency. If it burns pistons or valves then that is a problem, but I have not yet heard of where it has done this in an uncorrectable, inherent manner. Only the ire of speculation. Of course its ok to be skeptical. I am skeptical, but I am also intrigued that there have purportedly been some real results. I am reserving judgment because I am curious and that is my choice. I will continue to watch SS and his progress and I would like for this technology to succeed. If it doesn't then it it will go away, but for now lets see. __________________ 95 FZJ80 custom headers & 3" flowmaster exhaust, 4" OME lift (with CC bushings, x br lines, adj panhards, heavier dropped sways), ARB lockers, 35" Toyo M/Ts, dual dry cell batteries, 2300 watt inverter, speedo corrected, & Kaymar w/carrier Next: ??? |
#289 |
That is what I had read years ago about internal combustion engines: the ideal is a slow, evenly burning fuel. This slower, even burning action is one aspect of burning fuel that improves as octane rating goes up. It's the lower octane fuels that have a higher chance of auto-igniting, and causing holes in pistons through shock force, and/or overly hot burning.
__________________ 1. 2005 Toyota 4Runner Sport 4x4 V8. No sunroof, cloth seats - just the way I like! |
#290 |
Someone should start "The official HAFC quesion & answer thread". Put all the questions and commentary there and let SS_Storm continue his updates here. He can post comments there as well without bogging down this thread.
There is obviously a lot of interest in the topic. At some point it would be nice not having it all lumped into this install thread. __________________ '97 FZJ80 You're a bottle-cap away from pushing me too far |
#291 | |
I realize some will disagree but I seriously believe "The Official HAFC Q&A thread" is is more appropriate for Mud Chat. The reason is that owners of all Land Cruisers models are interested in saving fuel. Most 80-Series trucks are not OBD-II; only the 96 and 97 so that is not a reason to keep it in the 80 section. -B- __________________ 97 FZJ80 - Wing Nut MAF, locked, 315 Toyos, 4.88s, Slee 4", George's sliders, Slee bumpers, M12000, OBA, Outback drawers + other stuff. Transformation in progress... Sometimes you find yourself in the middle of nowhere. And sometimes in the middle of nowhere, you find yourself. Last edited by Beowulf; 06-20-08 at 12:02 PM. |
#292 |
I think my problem with this whole thing is that there is no NEW methods or experimenting. All I see happening is the same UNPROVEN kit being installed on another vehicle by an individual who has too much money and too much time. So what we all see time and time again is NOTHING proven and it allows everyone to come out and poke fun at it.
What needs to happen to staff some of the ridicule it now try something new. New methodology, new testing, new chemicals, new metals, new conditions, new SOMETHING! People are trying to install this SAME kit on yet another vehicle and its doomed to failure and ridicule. So do some actual experimentation. Adding this scam kit on an 80 is not experimenting. Do something different! Try something that has NOT failed over and over and yet repackaged and sold. This would be THE single most interesting thread if someone actual took real chemistry and physics and experimented and looked to the forum members for feedback. For every single thread I have been on I was always excited to see the outcome. This is the first thread that I have been convinced, before the final results, that I have been had. __________________ 70 FJ40-sold, worst day of my life 79 TOY 4WD pup-stolen, 2nd worst day of my life 91 4Runner 4WD-burned to ground, 3rd worst day of my life 83 FJ60- suckiest day of my life 97 LX450, 221k, non-locked. Expedition vehicle in progress. Factory rack removed ![]() ふざけんなよ! |
