Went wrench crazy on day off. Lift in and more
Just put in my OME springs! 850J front and 863 rear.
Wow.. Went up higher than I thought. Stock springs must have sagged a bit over the years.. Will measure and do pics soon.. Driving impressions after new rear rotors and pads come UPS Also got the hitch to slip in over the frame rail w/o out removing rear crossmember! A trick or two to it.. Not hard.. |
i want to know about the hitch
__________________ 91 FJ80 318k, spare tire mod, custom roof rack----SOLD 98 4runner 141k---SOLD 98 Avalon 149k 04 Sequoia 74k |
Cynical Optimist
I'd be interested to hear what you think and see some pics.
I'm getting ready to replace the light 851/860 combo with 850J/864's. How much other stuff do you have, ie weight adding stuff, front/back? I went with 864's because of so much stuff in the back and I pull a small trailer, hope the 864's aren't too stiff. Post up your impressions and pics if you would be so kind. __________________ I'm Dan and I approve this message. (KG6AJV) 1995 FZJ80 Expedition rigged, blown, OME's, L/R 44gal spare tank, other stuff 1974 FJ40, F, 4MT, 33" BFG's, HFS 4" - 1994 Pickup, 3" body lift, otherwise stock |
May depend on who made the hitch.. But
1. Remove spare tire. 2. Remove spare tire crossmember and the 90* brackets for it to the frame rails. 3. Trim the horizontal part of the hitch bracket. a. Cut off part of the forward corner on the passengers side. b. Cut off part of the aft corner on the drivers side. 4. Put the whole passenger side on top of the frame rail and push it into the pocket behind the fender. 5. Lift and turn the hitch at an angle to line up driverside trimmed area to clear the frame rail and push it up until it clears. 6. Shift the hitch over towards the drivers side so that the passengers side drops down onto the frame. With the trimming... I first tried to do it with out it.. Then I made a mark on the corner of the hitch where it contacted and trimmed a 45* angle and about 1/4" off the passengers side. Then I trimmed about 1/8" off the driver side and a tapered area behind that about 2" long... Going from edge of 1/8" trim to full width over 2" span. There is some sheet metal that needs to be trimmed or bent over just above the frame in the back. Where two sheets come together and the seam is at a right angle to the frame. I just cut a line in it on either side of the frame rail and folded it over. As for weight on the lift. ARB bull and mile marker front. Stock rear bumper. 315 Spare sitting on inside floor of truck.. You do have to notch the rear x to slide in the draw bar but not too much. Will do pics soon... Just got done notching. |
#5 | |
Pinoy 4WD Journey
__________________ Noel 97 LX450 (lockers retro 50%), CDL, Pin 7, HIRs, Cup Holder, 100 pads, George's LEDs, OEM grab bar, sidemarkers, ARB winch bar, PIAA 520, 295/75R16 NTG, Kaymar Deluxe with tire carrier, OME850J/863, Slee speedo gear, ARB fridge, silicone PHH/FHH, Xantrex 1750 inverter. Awaiting installation: XD9000, OEM subtank, slee SS brake lines, 3* blue bushings/caster plates, BIC 95300B dual batts. .... 94 4Runner, OEM 4.88 gear, V6 3VZE 04 Taco Ext Cab SR5 V6 TRD RR DIFF LOCK, groucho sliders |
Are you talking about relocating an existing hitch or installing one ?
__________________ "I hate conservatives, but I really f*cking hate liberals" Matt Stone Gumby--"I'm a liberal because I'd like everybody to have the opportunity to reach their potential". 94 FZJ80.....ARB, OME, Revo'd, Eclipsed and Locked. 86 FJ60: Sold! |
I would like to relocate my hitch above the frame rails but having a hard time visualizing his steps.
__________________ 94 FZJ80/FJ80 MUTT 315 Maxxis Bighorn, Rear Aussied, and stripped of BullSh*t 2" Ironman springs with 1" spacers and Bilsteins courtesy of Frankie's Offroad. Quote from Willy T. Payne "I'm f*cking this goat, you just hold the horns." (no goats were actually molested during the making of this comment) Tapage, "saving my penis for the next year .. fingers crossed .. ! "
#9 | |
i just remove mine until i have to tow..which isnt too often. |
#10 |
I relocated the one that was on it after blasting it and repainting it.
Sorry about pics delay. Busy man all weekend had work around the house and a side job fixing a boat in my garage. |
#11 |
I understand most of what you're saying, I think, but it would be great if I had some pics to see for sure. I'll keep checking back.
#12 | |
I had not made up my mind on the shocks yet but knew I did not want OME shocks. So I did the lift to get it and caster correction done and out of the way. Just a shock swap is so easy even swaping in eye adapters and shocks is easy.. I will shoot some pics of the hitch today first as I just put her up on stands to do rear brake rotors, pads, parking brake bellcrank pivot fix and parking brake adjustment. UPS ought to be by today with my rotors. Rockauto was $70 cheaper per rear rotor than a local parts chain... |
#13 |
Here we go hitch pics
From rear no bar installed. Put the trailer connector right into the bumper. Smashed the last one backing up and over a snow bank.. Not gonna happen now!
![]() Passengers side frame ![]() Drivers side frame ![]() Inside of bumper notch. Cut to outside and tops of lower "hitch holes" on the front and up to existing slot on rear of bumper/xmember. ![]() Rear view with 8" drop hitch + convert-a-ball inserted. Tow a couple different boats and a cycle trailer.. Nothing super heavy. I was standing up kind of close on this one so it looks lower than it is. The boat sits level. ![]() Shot showing clearance between bumper and hitch bar. Close but no interference at all.
#14 |
thanks for the pics, are the holes there or did you have to drill?
#15 |
thanks for the pics.
#16 |
Cool hitch mod.
I was wondering about the lift..... So instead of a full lift package you just installed OME springs?How much lift do you get with just springs? How big are your tires? Is the ride rough? If you get lift from just springs, why would someone opt for the entire lift package? Thanks a bunch. __________________ 95 stock locked FZJ 80 94 4 runner 2wd 90 camry (sold) ![]() 05 hayabusa |
#17 |
Just springs, extended brake lines and caster correction for now.
Shocks and rear panhard drop bracket to follow. Much more to doing it right than just springs. |
#18 |
So I guess my next newbie question is there anything in the kits that you can either do without or can you build the kit cheaper
? How much lift can you get from just the springs? How big are the tires you will run with springs? Thanks again.
#19 |
Um... Look at FAQ.
#20 |
#21 |
Cool hitch mod.
What brand of hitch do you have? OEM, Draw-tite, or other? Thanks! |
#22 |
Not sure was mixed black and orange before I put it in a bead blasting cabinet.. Might be OEM
#23 |
do you think that there is any way to retain the spare tire in the stock location?
__________________ 91 fj80 w/ 93 1HD-T. OME 850/860 w/ 1" front spacer, LEDs, HIRs, Hankook MT's 31x10.50r15, Tuffy center, ARB rear locker (in progress), in garage: lightforce lights, full rack, superwinch X9, maggiolina tent, hella horns. WTB: Tan DS mirror & housing '88 HJ60, "Louie" For Sale in Costa Rica.
#24 |
UM why. The spare hangs much lower than the hitch. Not going to gain anything.
#25 |
while the spare hangs lower than the hitch, I can take the spare off and throw it in the cargo area in about 3 minutes, for times that I'm offroad.
around town, I don't have much trouble with the hitch nor the spare hitting stuff, but it is cleaner/neater to have the spare down below than in the cargo area (around town). __________________ 91 fj80 w/ 93 1HD-T. OME 850/860 w/ 1" front spacer, LEDs, HIRs, Hankook MT's 31x10.50r15, Tuffy center, ARB rear locker (in progress), in garage: lightforce lights, full rack, superwinch X9, maggiolina tent, hella horns. WTB: Tan DS mirror & housing '88 HJ60, "Louie" For Sale in Costa Rica.
