Old 05-16-08, 02:05 PM   #1
whosthecoolguy's Avatar
Arrow Wiring question for AUX. lighting.
I have 2 light force lights on the front of my truck, and I'm thinking of adding a 3rd light in the middle...kind of rally style
My question is wiring the 3rd light....do I need a whole new harness or is there a way to feed a 3rd light off the original harness running to the 2 exising lights so that they all work off of the same switch?
I'm an idiot at the electrical thing, any help would be appreciated.
Thanks!
Jeff
Jeff King
1991 HDJ81->4.2 liter Turbo Diesel, 2.5" OME Lift (850+860),33x10.5 BFG ATs,Locked F+R,ARB Commercial Bumper,M8274-50,Light Force 240s w/ Blue Filter,Sirius Satelite,Turbo Timer,Husky Cargo Liner,TomTom Navigation and an Ice Box inthe arm rest.
R.I.P Evel Knievel. King of the Stuntmen.
whosthecoolguy is offline   Reply With Quote
Old 05-16-08, 02:21 PM   #2
On top of the world...
Lka1988's Avatar
You should be fine just running another lead from the relay (you used a relay, right?).
Lane Anderson
1991 TRD FJ80, Red, 252k, 3FE Powa
Lifted, bumpered, Slee'd, flareless, LineX, 31" BFGs, Dual batts, CB, HIRs, OBA, GPS, OEM CHMSL, roof lights, kickin' sound system, 2-seater - 10 MPG!!
__________________________________________
Originally Posted by eskimochaos
we have concluded that the LC is the toughest most over-engineered leather-lined tank ever forged and that it is used to rescue villagers by the UN in the toughest terrain on a daily basis
Lka1988 is offline   Reply With Quote
Old 05-16-08, 02:29 PM   #3
I got a good deal on the Light Force wiring harness so that's what I used.
I'm thinking of running 3 of those HIDs from Kragen.
Would the Light harness be able to handle 3 of those?
Jeff King
Old 05-16-08, 02:32 PM   #4
Lka1988's Avatar
Depends how many amps the lights pull.
How big are the wires (gauge)? How many amps can the relay handle?
Lane Anderson
Old 05-16-08, 02:43 PM   #5
This is where is goes a little foggy for me...
Light Force Harness has:
Resistor protected 30 amp relay
Water proof blade fuse holder
Extra long cables (for larger vehicles)
All required terminals
Can be POSITIVELY or NEGATIVELY switched to suit some imported vehicles (refer to instructions)
These are the HIDs...not much info:
7" HID Off Road Light with a wide and very bright 35 watt Euro-Beam Light pattern. Features include a durable, hi-impact ABS housing with a red anodized aluminum trim ring. These have an internal starter and ballast. Easy two wire installation. Each light includes a clear polycarbonate protective lens cover to protect the tempered glass lens from rocks. The wiring harness to connect to the included blue back lit rocker switch is also included.
Jeff King
Old 05-16-08, 02:47 PM   #6
Lka1988's Avatar
35 watts...that should only draw around 3 amps per light...
You'll be fine with your current harness.
Lane Anderson
Old 05-16-08, 02:49 PM   #7
Thanks Lane,
So to make this easy for me, I just extend the two leads from the relay to the light and wire them up like the existing lights?
Jeff King
Old 05-16-08, 02:53 PM   #8
Lka1988's Avatar
Originally Posted by whosthecoolguy View Post
Thanks Lane,
Pretty much.
Lane Anderson
Old 05-16-08, 04:33 PM   #9
Corbet's Avatar
TLCA# 15340
I'd make sure the relay is rated properly for the total amp draw. Most relays have an amp rating printed on them. Add up the total amp draw from all three lights. Should double check your wire gauge too but if the mfg of the wiring harness supplies a relay that will handle your requirements one would "assume" the wiring is up to the same task.
Rising Sun 4 Wheel Drive Club Member
1976 FJ40, A project with little progress.
1985 FJ60, SBC 350, Ranger Overdrive, OME, 33" MT/R, SafariGard bumper with T-max winch.
1997 FZJ80 40th Anniversary, locked and now on 33"s
Corbet is offline   Reply With Quote
Old 05-16-08, 04:44 PM   #10
jasonmt's Avatar
You 240's should draw ~8A a piece so you should have ~14A of capacity you can use, otherwise it is a simple deal to use the same switch to run another relay.
I am around off and on depending upon what is going on up north, shoot me a pm if you need some help.
jasonmt is offline   Reply With Quote
Old 05-16-08, 04:53 PM   #11
tlcwagons.org
FirstToy's Avatar
35W HID's run about 3amps ea = 9amps for 3 lights.
Actual draw is anywhere from 35-41W but basically 3 HID's = 1 LF240.
No problem using your LF wiring harness. That is the advantage of HID and LED- very low power draw.
I love cachapas!
my wip
I drink your milkshake!
Old 05-16-08, 04:54 PM   #12
Thanks Jason.
I still owe you lunch so regardless, we'll have to get together when you are in town.
Thanks guys.
Jeff
Jeff King
Old 05-16-08, 10:51 PM   #13
robmir's Avatar
Keep in mind HID lamps draw a lot of amps for a short time when you turn on them.
1993 FZJ80, 2" OME, 305/70-16, Auburn Locker, F&R TJM bullbars,Long Range 150 ltr gas tank, 170 Amp alt, 240 amp 3 Battery Isolator & 3 Deep Cycle batt,4 DBA slotted rotors, Carbon/Ceramic pads, SS/Teflon brake hoses, Warn 9000, PIAA 80 Racing,Coil&Shock Dampened Front Seats.Engel 60 Qts Fridge.
robmir is offline   Reply With Quote
Loans | Myspace Layouts | Auto Loans | Read Techmeme News | Loans
