Cruise control on 91 not working
Picked up two 80's in the past two weeks both 91' on paper but door stickers show a 90 @198,000 miles and door on 91 @ 162,000 miles.
Any takers on explaining to why I needed two of these?!Any way I also have factory repair manual, electric ,owners. Both vehicles cruise control light come on but do not work. ![]() Is there a common problem with this cruise control system? Focusing on higher milage rig, already front end attention rotors, bearings, berfields etc. All suggestions welcome. Thanks, 2cruise |
the cruise control on these seem to be very sensitive to volt levels, mine was working when i had a tail light shorted out, when i fixed this it no longer works. Start by making sure the brake fluid res it full, and the brake light is not lit on the dash
and welcome to the addiction __________________ 91 FJ80 318k, spare tire mod, custom roof rack----SOLD 98 4runner 141k---SOLD 98 Avalon 149k 04 Sequoia 74k |
Put your cruise in diag mode (hold down the set button while driving) If the cruise light blinks your speed sensor is working, if it doesn't it failing) Mine works off and on. IMO the sensor costs to much to bother with.
__________________ Brad Fink 1991 80, OME heavys with 1.5 home brew spacers in front, Landtank's CC plates, Yukon 5.29s, F&R limited slip, manual hubs, Longs, home brew sliders and cat skid, 35x12.50s, part time 4wd, Scion head unit and allot of miles. |
#4 | |
On top of the world...
It's probably a fouled speed sensor. Something like $100 for a new one... I wouldn't bother, what with the 3FE and all.
__________________ Lane Anderson 1991 TRD FJ80, Red, 252k, 3FE Powa ----- Lifted, bumpered, Slee'd, flareless, LineX, 31" BFGs, Dual batts, CB, HIRs, OBA, GPS, OEM CHMSL, roof lights, kickin' sound system, 2-seater - 10 MPG!! __________________________________________ Quote:
i had the same problem with mine. so one day i was just wondering around the passenger side engine bay area, and found that a connection was loose, all i did was touch them and the connections separated. so i plugged them baci in properly and all of the sudden i noticed that i had cruise control again.
before i noticed the cables, the cruise control light will come on, but not hold. i hope this is whats wrong with urs as well. best of luck. __________________ "life's possibilities are endless. The only limitations are the ones we create for ourselves from fear of failure". |
#6 | |
thanks! |
#7 | |
Thanks for your experience! |
#8 | |
Thanks |
#9 | |
The need for the cruise is very limited but if it is simple to fix I will fix it. saving time chasing rabbits in the field I will try all of your suggestions with great appreciation. |
#10 | ||
![]() Well, best of luck to ya.
Mortgages | Mortgage Calculator | Anime Episodes | Credit Cards | Mortgage Loans |
