#31 | |
grown up MOD
__________________ "If it wasn't a Landcruiser and hadn't been built the way it was you do realize you would be DEAD." VA State Police Officer |
#32 | |
), but he's always run his on midgrade, and doesn't complain. I know mine runs better, and I've only used premium in the short time I've had it, but there are many other factors (I'm bored out, have a better/different exhaust, I'm cooler, etc.) so the comparison is definitely not equitable.
__________________ "Macadamia nuts in mixed nuts?!? Now that's a high class nut mix..." -Anonymous quote heard during a CM08 lunch break in the worm hole on Kane Creek |
#33 |
Said most, not all. I think hondas were designed to run on sewer water.
__________________ Ben Latham TLCA 18184 '74/'78 FJ40 in progress '96 FZJ80: locked, OME'd, ARB'd, 305'd, CDL/Pin 7, JD HIRs, Blue Top Optima Last edited by lathamb; 05-17-08 at 04:02 PM. |
#34 | |
__________________ Steve Crase TLCA 10222 1988 FJ62 - Bart 1997 FZJ80 40th Anniversary #3727 - Sandy |
#35 | |
__________________ 97 FZJ80, Locked & Loaded, Safari Turbo, Safari Intercooler, LandTank MAF, 3" Ceramic Coated Custom Exhaust, Ron Davis Racing Radiator, OME HD 2.5" Suspension, DBA Slotted Rotors, New Toyota Calipers All Around, Toyota Pads, 33" Revos, ARB Front Bumper, Center Diff Switch, Slee Stuff: Roof Rack, Step Sliders, Skid Plates, SS Brake Lines, DC Drive Shaft. HG PM'd, 8.5psi and climbing, My Rocky Mountain Mojo Mobile! |
#36 | ||
tlcwagons.org
I don't see a 'margin of error'. fuel either detonates or it doesn't. If it doesn't, than you are wasting fuel. If it fires early, than you get knock. In fact, if it is closer to early detonation, that tells me the engine is pretty efficient. Of couse then it goes to whether it is taking away power but again, even if it were, it is inconsequential - just imo. Quote:
But realize that many toyota v8's and i6's as well as domestic v8s do really well w/ forced induction I feel it's the nature of the engines and not so much something to do w/ stock knock sensors or characteristics (altho i understand the ecu management is very important to forced induction) Just my thoughts- I am thinking of this from stock engine perspective. maybe it's wrong but these are my feelings on it. I know once the discussion goes to forced induction, it's a whole new ballgame. |
#37 |
The points you're bringing up have a lot to do with survivability durability of the 1FZ when supercharged. What I was talking about is the ability to add a supercharger and not modify the engine management system in any way that I'm aware of and still allow the engine and entire system to be factory warranted and smog legal on top of that. There may be other engines that you can turbo or stick a supercharger on without changing the timing, ECU or anything else, but how many of them will be factory warrentied and still pass smog in all 50 states? Seems to me the engine managment system in the 1FZ must have some serious adapting abilities.
BTW, I ran a tank of 92 for the first time this weekend and I was surprised by the results. No major seat of the pants difference. Scangauge is inconclusive, since I can't compare direct apples to apples. But I did notice some major mileage improvements. But this was just one tank. It's not conclusive, but enough to make me to want to keep trying it and see it if the results are consistent. __________________ 1995 FZJ80, modified for regional expeditions. Click here for more... My main website: In Search of History Expeditions Foreign Toyota 4x4s Military Toyota 4x4s Last edited by Brian894X4; 05-18-08 at 06:49 AM. |
#38 |
Is it true with the 10 % ethanol additive in gasoline today there is no need to use fuel injector cleaner ?
If so, there must be less and less carbon deposits as we drive with this ##it in the gas tank. __________________ Pat Doyle 1994 White FZJ 80, CDL switch. rear winch hitch attachment .-SOLD 1996 White FZJ 80, seats 7,leathered up, CDL,Locked,LandTanks MAF.2" OME lift/Shocks. |
#39 |
I've been under the impression that with ethanol, there would be no need to ever add a gas drying additive but I wouldn't think it would do much to clean up carbon deposits.
#40 | |
tlcwagons.org
A more complex system would pick up finer degrees of flux right? it is very interesting, brian, I hope you keep going with your thoughts. You think very differently than me! |
Mobile Phone | Credit Report | Mortgage Loans | Car Loans | 0 Credit Cards |
