Home Forum Gallery Wiki CruiserFAQ Tech Links Store
IH8MUD Forum
Go Back   IH8MUD Forum > Toyota Tech Forums > 80-Series Tech
80-Series Tech Tech regarding the 80/81-series Land Cruiser, including the Lexus LX-450 -- FZJ80.com
Old 09-13-04, 05:52 AM   1 links from elsewhere to this Post. Click to view. #1
concretejungle's Avatar
P.S. Resevoir
I really need to flush my power steering fluid. tried to tackle this on Sunday to no avail. I couldn't for the life of me get the return hose off the resevoir fitting. I pulled the clamp way down the hose and then for 30 minutes tried to pull the hose off the fitting. Used a screw driver but just started tearing up the hose. I guess it's sorta dry rotted on there or something. I guess i will just get two new hoses and cut them in half, then try and get them off. Any suggestions?
95' FZJ80 OME med./J lift, ARB rack, ARB Bull Bar w/tmax 12,500, 35" truxus, Aussie locker-rear, Center Diff Lock, Sliders, IPOR Skid, IPOR rear bumper, upgraded slee sticker, custom dents, more to come. . .
Go 80, or go unsatisfied
concretejungle is offline   Reply With Quote
Old 09-13-04, 09:23 AM   #2
WolfpackTLC's Avatar
Take some pliers and grasp the hose tightly at the point where it's still engaged on the fitting... Twist back and forth.
One of two things will happen.
A. It will loosen, and you're good to go.
B. It won't loosen, and it will tear up the hose.
1995 80 Slee'd, ARB'd, Warn'd, Snorkel'd, Locked, S/C'd, Lined, Dented and WHEELED.
WolfpackTLC is offline   Reply With Quote
Sponsor 09-13-04, 09:44 AM
Sponsored Link
advertisement
Old 09-13-04, 09:44 AM   #3
Gubpimp
Landpimp supports the BlueRibbon Coalition!
Landpimp's Avatar
there is a hose removal tool that works great but anything pointy(like a pick) will work, just slide it bewteen the hose and metal and work it around. Also there is a lip(can't think of the right word) on the metal tube under the hose.
Truth is a torch that shines through the fog without dispelling it. Always be true to your work, your word, & your friends, & you will never live a day without peace
Landpimp is offline   Reply With Quote
Old 09-13-04, 10:48 AM   #4
Rookie2's Avatar
I do the same as Wolfpack. Get the BF'n pliers and rotate the hose end back and forth to break the seal, and then pull it off.
Rookie2
1997 LX-450, Basically stock.
Rookie2 is online now   Reply With Quote
Old 09-13-04, 11:24 AM   #5
Doc
Jawa Jedi
Doc's Avatar
Garage
I use the LandPimp method, but have yet to master it, as I keep jabbing myself with the pick!
Eric, Utah operations commander- Tall Corn Cruisers.
1993 FZJ80, 197K miles. Lifted, Locked, Slidered, Slee'd, Snork'd, Winched, bobbed. Daily driver. ROTW
1975 FJ55 Pig. Awesome edition. LPG/Petrol.
Doc is offline   Reply With Quote
Old 09-13-04, 12:23 PM   #6
Parts Geek, M1 Mechanic
cruiserdan's Avatar
Hmmm,
Jeeze Doc,
I'm not real sure that poking yerself using the "Pimp" method is such a great idea.....
Original owner 93 FZJ80,locked,blown,water/methanol injected(like a WWII fighter aircraft),lifted,winched,snorkeled,slidered,Sleeed ,moneypit. Balanced on a pin head. 95 FZJ80 trail truck (hers), 94 FZJ80 320K with a knock. 2009 Dodge Challenger SRT8, 425 horse HEMI, 6 speed manual trans, cop-attracting-red.
Old 09-13-04, 12:36 PM   #7
I did shove a small flat-head screw driver down between the fitting and the hose. All that was happening is the hose was tearing up. So i stopped. I really was pulling on the hose all i could, and i aint no . Still thinking about stopping by NAPA on the way home for some more hose so i can just cut the damn thing off. I almost pulled a bone-head move and spray some lube on the hose, but then i realized it would get into the power steering fluid.
Old 09-13-04, 12:53 PM   #8
turbocruiser's Avatar
Hi folks, I took Junk's advice and got vacuum hose pliers from Snap On. They work on a range of hose sizes from the smallest vacuum lines up to 1/2 inch inner diameter which should work well with the PS hose. They look like a hybrid between pliers and scissors and they put equal and opposite pressure on the hose and the metal tube where the bead or flange is. They work really well. HTH.
97 FZJ80, Locked & Loaded, Safari Turbo, Safari Intercooler, Ceramic Coated Custom Exhaust, Ron Davis Racing Radiator, OME HD 2.5" Suspension, DBA Slotted Rotors, New Toyota Calipers All Around, Toyota Pads, 33" Revos, ARB Front Bumper, Center Diff Switch, Slee Stuff: Roof Rack, Step Sliders, Skid Plates, SS Brake Lines, DC Drive Shaft. HG PM'd, 9.5psi and climbing, My Rocky Mountain Mojo Mobile!
turbocruiser is offline   Reply With Quote
Old 09-14-04, 09:14 AM   #9
took the cruiser by the stealer to have the inspection done and front end aligned. Priced the two hoses for the power steering resevoir, they told me that the return hose was sold as a total package including all the metal hoses that it connects to. Crap i tell you. I will try one more time to muscle the hoses off, then it's going under the blade!
Old 09-14-04, 09:31 AM   #10
Gubpimp
Landpimp's Avatar
just get some stuff at the parts store I forget the size but thats what I used on my 40 and 60. return hose is low presure. For the high presure have one made(don't tell the hose shop it for PS.........it hygraulic hose for your wood spliter ) or buy new OEM or maybe(like a 60) there is a aftermarket hose for $35.
Old 09-14-04, 07:37 PM
Sponsored Link
advertisement
Old 09-14-04, 07:37 PM   #11
medtro's Avatar
I used the hose pliers from here, and return hose from Car Quest.
medtro is offline   Reply With Quote
LinkBack to this Thread: http://forum.ih8mud.com/80-series-tech/22151-p-s-resevoir.html
Posted By For Type Date
'97 Lx450 Power Steering Fluids - Lexus Owners Club (USA & Canada) This thread Refback 04-27-09 06:23 PM
