Old 05-11-08, 03:22 PM   #1
walleyefisher's Avatar
walleyefisher is on a distinguished road
Differential Lockers & CDL
I've done a TON of reading on here to try and determine why my lockers wont kick in. However, I haven't been able to find my exact situation so here goes....
My 97 has factory locks that only flash and never lock in..I've done the CDL lock test by going to a gravel area and putting it in low and doing the figure 8's and circles. I'm convinced the CDL is locking because of the amount of tire slippage. However, I dont get any light or any indication that I'm in 4-low or ABS or anything.
Can someone please tell me if there is a light that is supposed to illuminate when you're in 4-low? and when the CDL is locked?
I think that my problem is probably that my lockers dont know the CDL is engaged..(I'm hoping)
Thanks for the help.
walleyefisher is offline   Reply With Quote
Old 05-11-08, 03:37 PM   #2
I <heart> Wagons
Lka1988's Avatar
Lka1988 is on a distinguished road
When the CDL is locked, the CDL light on the dash will come on.
Is the CDL light coming on?
Lane Anderson
1991 FJ80, Red, 247k, 3FE Powa - flareless, LineX, 31" BFGs, Slee stuff, Dual batts, couple lights, clear lenses, GPS, 100 Series bling, HIRs, OBA, headlight buzzer mod
Coming soon: custom LOUD air horns
________________________________________________
1963 VW Bug, Anthracite, 1.6L - Undergoing Restoration
(\__/)
(O.O)
(> < ) <--This is Bunny. Copy Bunny into your signature to help him on his way to world domination.
Lka1988 is offline   Reply With Quote
Old 05-11-08, 03:40 PM   #3
NO....no light at all of any kind. My cruiser doesnt have a CDL button though.
Old 05-11-08, 03:50 PM   #4
I <heart> Wagons
Lka1988's Avatar
I see.
When you put it in Low range, the CDL *should* automatically lock, which will kick off the ABS. This will turn on both the CDL and ABS lights. However, the CDL light will not come on until the CDL is engaged, and THAT is when the F/R lockers will be able to engage.
The CDL is probably still sticky. Keep at those figure-8s until that light pops on.
Lane Anderson
(\__/)
(O.O)
Old 05-11-08, 03:53 PM   #5
I <heart> Wagons
Lka1988's Avatar
You could also crawl under the truck and have a buddy lock the CDL (put it into Low Range) while you listen for the CDL actuator.
Lane Anderson
(\__/)
(O.O)
Old 05-11-08, 04:45 PM   #6
Are you certain that a 97 cruiser has this CDL and ABS lights? 2nd question, can you see these lights on your cluster when you turn the key all the way forward without starting the vehicle??
Old 05-11-08, 05:10 PM   #7
I <heart> Wagons
Lka1988's Avatar
Absolutely 100% positive that it has the lights.
I know the CDL won't show up when the key is initially turned, but I'm not sure about the ABS light. I don't have ABS...
Lane Anderson
(\__/)
(O.O)
Old 05-11-08, 05:31 PM   #8
OK, well that helps. Thank you.
I guess I'm thinking that if the activation sensor is not working then the rest of the stuff wouldnt know it was activated and therefore not engage. I've read about jumpering the activation sensor with a paperclip....I think I'll give that a go.
Old 05-11-08, 05:47 PM   #9
TLCA# 14008
anderaa13
The ABS light and f&r diff lock lights should light up when you turn the ignition on. The CDL light does not.
You'd probably notice other stuff not working, but have you checked for a blown fuse?
1993 FZJ80, 180k, 3 diff locks, OME, ARB, Warn, Lightforce, Hankook MT, Part-time 4wd, Technitop.
Never owned anything but a Land Cruiser.
anderaa13 is offline   Reply With Quote
Old 05-11-08, 05:51 PM   #10
96r50's Avatar
TLCA# 18726
96r50 is on a distinguished road
The ABS light will come on when you turn the key to ON.
I would try shifting the transfer from high to low repeatedly. Like 50 times repeatedly. Some of the contacts in the system (not sure which ones/where) may be gunked up from lack of use; shifting a lot should clean them off. Good luck!
Adam
96 LC, OME 851/860, BFG AT 285, Metaltech sliders, IPOR skid, Yellowbox, Landtank seat brackets & MAF, ScangaugeII, Slee harnesses with HIRs & Hella 500s, CDL & Pin 7, George's LEDs, Slee-located washer bottle, 'MUD sticker
96r50 is offline   Reply With Quote
Old 05-11-08, 07:32 PM   #11
Ante up to an 80 series!
Bear80's Avatar
TLCA# 14779
Bear80 is on a distinguished road
Your CDL is locking, it just doesn't know it's locking. There is a sensor/switch on the t-case that tells the diff lock ecu that the t-case is locked. It's easy to pull out and all it takes is to push the contact ball in a bunch of times to get it working. It just hasn't been used enough in a long time.
40th FZJ80 - Range Rover Recovery Vehicle
Alamo City Land Cruisers
-Benjamin-
Bear80 is offline   Reply With Quote
Old 05-11-08, 07:44 PM   #12
Now we're talking
Thanks Bear80 That exactly the info I was looking for....
Thanks all for input
Old 05-11-08, 07:53 PM   #13
TLCA# 53652550
chocruiser is on a distinguished road
I have a 96,when I shift in 4low the cdl and the abs ligt up.You can feel the high torque and ready to craw.In your case,I think it could be the bulbs in your instrument panel or the fuse.If you can feel the high torque and want to craws.Hope this help.
chocruiser is offline   Reply With Quote
Old 05-11-08, 08:01 PM   #14
TLCA# 14008
anderaa13
Not sure how much experience you have with 4wds, but does it feel like its locked when you shift into low and turn? Can you feel the tires breaking loose?
Old 05-11-08, 08:47 PM   #15
pound3151's Avatar
TLCA# 14748
pound3151
Walleye, I've got the same problem from not driving it for a while, even with the cdl switch and 7 pin mod. I'd follow bear's advice, then possibly look into a bad light or fuse.
Brad
96 FZJ-80
pound3151 is offline   Reply With Quote
Old 05-12-08, 06:59 AM   #16
TLCA# Unknown
campoj2 is on a distinguished road
I have been down this road, as a matter of fact, I am still on that road, and I still haven't cracked the code.
I shifted the transfer case back and fourth 50-75 times - that didn't work.
Drove figure 8s until I got vertigo - that didn't work.
Bought and installed a new transfer case switch from CDan - that didn't work.
I grounded the connection at the CDL switch and -That worked, ie both the ABS and CDL light illuminated. - I don't know what to do at this point, it may time to take it to the dealership and let them figure out. I don't want to go down that road, but I'm running out of options. Is my center diff fried?
John
1994 Green FZJ80
Locked - But not currently Locking
EZ Pass
Son of Moose
http://www.carrfuneralhome.net/?p=146
campoj2 is offline   Reply With Quote
Old 05-12-08, 10:08 AM   #17
I'm going to rip that sensor out tonight and see if I can get it unstuck? Is it OK to use pb-blaster on it?
1997 FZJ80 factory locked, OME 850/863 N73/N74E, Landtanks seat extension,slees light harness, HIRs, HID off-roads, slees off road light harness.
Future projects; rebuild front axle, 150amp Alt....
Old 05-12-08, 11:16 AM   #18
Bear80's Avatar
TLCA# 14779
Therer's no need for pb-blaster. You'll see how the switch works when you get it out. Simply press it on the work bench to push the ball in and do this at a rapid pace several times. Then check it with a multimeter to ensure it's working again. If this doesn't do it, a new one will be needed.
campoj2- The diff lock is a very simple system and your problem seems to be that the diff is NOT locking. The new switch you bought has nothing to do with this function, only to tell the diff lock ecu that the diff locked/unlocked. ToolsRus had a similar problem that turned out to be a broken wire near the locker motor. This sounds to be an area for you to check.
-Benjamin-
Old 05-12-08, 04:50 PM   #19
TLCA# Unknown
Is that wire easy to locate or see?
1994 Green FZJ80
EZ Pass
Son of Moose
Old 05-12-08, 07:52 PM   #20
Found the sensor...pulled the wire and jumpered it and Presto! ABS & Diff-Lock lights on. I have not tried lockers yet as I want to get sensor working first. OK, so now the question;
How the heck do you get a wrench on that sensor? It's like a 1 1/16 bolt....I couldnt get anything up there to get it loose.
Old 05-13-08, 02:58 PM   #21
Guambomb is an unknown quantity at this point
Did you figure out how to get it out yet? I'm about to do the same thing.
Guambomb is offline   Reply With Quote
Old 06-02-08, 05:33 PM   #22
Re-Visit
Can anyone tell me the proper ohm reading across the CDL switch? Mine works (sorta) its open when the ball is out and has like a 2.5 Megaohm resistance when pushed in. I suspect this is faulty as I would expect it to be minimal resistance when closed.
Old 06-02-08, 06:08 PM   #23
Bear80's Avatar
TLCA# 14779
zero when the switch is open and low resistance (dead short) when closed.
-Benjamin-
Old 06-02-08, 06:12 PM   #24
Great....$60 and hopefully I'm back in business.
Old 06-03-08, 05:03 PM   #25
Still hosed
Installed brand new switch from dealership and still no ABS and Center Diff lights.
The Center Diff is definitelty engaged by the switch.
Is it possible that whatever is supposed to push in the indicator switch on the transfer case is not working?
I suppose I could check it with a multimeter to see...
UGH!!! What a MFPITA
Old 06-04-08, 07:22 AM   #26
barCruiser's Avatar
barCruiser is on a distinguished road
Sounds like your CDL actuator motor is toast. if your indicator switch is working then it will light up when the cdl is activated. It may "feel" like the center is locking up but its probably not. One way to know for sure is to put it in 4lo (cdl locked) then jack up one front tire and try to turn the front driveshaft. If you can turn the front driveshaft then your cdl is not locked. If you can't turn it then it is locked. As far as a CDL actuator motor is concerned, they run around $500 new from cdan or you could do what I did and try to find one if a salvage truck in the mud classifieds.
1996 LX450 stock, lockers
1979 Jeep CJ7, 3" lift, 33" BFG m/t, sbc 350, front/rear lockers
barCruiser is offline   Reply With Quote
Old 06-04-08, 08:51 AM   #27
CDL definitely locked. I did the jack test and everything was good. Did a few more tests last night before the monsoon hit. I pulled the actuator and reconnected it to the wire. Had the wife turn the key forward and check for light as I cycled the switch in and out. NOTHING! So I checked the actuator with a multi and it works like a champ....So I jumpered the plug again and this time NO LIGHTS! I think this rig is like Christine or something.
The only thing that has changed since I last jumpered this plug with success is I did the 7-pin mod. Could I have screwed something up there?
Any help is greatly appreciated.
p.s. next is vacuuming out the 50 gallons of water in my floorboards and tackling that project. Does it ever end? LOL
