Okay front axle gurus...
I broke two Pass side birfs before I got my Longs. Then I lost a stud from my pass side steering arm. I ended up rebuilding my front axle and regearing to 5.29. The problem now is I keep blowing inner axle seals on my pass side.
i'm afraid that I may have bent my axle housing. Please tell me that I'm overlooking something... |
Howdy! Maybe you have a bent axle rod? John
__________________ 76 FJ55, Safari Grade. 350 SBC, Lockrightx2, SO, SR, PS, York on board, 35" Krawlers, and way too much junk in the trunk!!!! ![]() 85 Toyota mini truck for chase/support!CSC #41 |
rust and moth consumables
Is it the seal that's blown or could it be a worn groove in the axle shaft where the seal rides?
__________________ -Peter Mac- 1990 HDJ81 1997 40th 1967 Norton Atlas 1986 Yamaha RZ350 1996 Ducati 900SS SP Ya...it's like crack to me... www.bestinshowexhibits.com |
ThinkTank Waterboy
maybe a worn spindle bushing allowing the birf to run off center.
__________________ Rick Bigelow '96 215k Groveland MA 01834 If you're not the lead dog, the view never changes |
It sounds like the seals are fine but the axle is moving laterally and breaking the seal. Or perhaps you have a groove on the axle where the seal rides on?
__________________ TLCA # 15941 KE5LED Currently working in Danville, PA until Aug. |
Since you are still blowing seals after going to the longs, I might rule out worn groove in the axle. Of course that would depend on the mileage you have on the longs.
I think Landtank has hit the nail on the head. Buck Buchanan __________________ 97 LX450 OME 2.5, 1" spacers, CDL w/pin7, Toyo 315's, cup holder, Bullbar, Hannah Sliders & Rear Bumper. TLCA# 13863 |
#7 | |
IH8MUD Tour Guide
I don't have leaking yet and i pulled the wheel to make sure the wheel bearings were tight, and they were. Sorry to hijack chad.... ![]() __________________ 95' FZJ80 OME med./J lift, ARB rack, ARB Bull Bar w/tmax 12,500, 315 Nitto, stainless brake lines, Center Diff Lock, Sliders, IPOR Skid, IPOR rear bumper, upgraded slee sticker, custom dents, more to come. . . Remember it's a gateway drug, so it will actually lead to "crystal meh". |
No worries, I need all this info. I know that the axle shaft isn't bent or groved. I have about 1000 miles on my Longs... However, I did not replace that brass bushing because it looked good. Is there any way to check that?
Chad,
Simple to diagnose, actually, if you've been noting what happens to the seals. A bent axle shaft would wear the inner seal around its entire perimeter as it wobbles round and round. A bent axle housing or other mechanical issue allowing the axle to run offcenter will produce an inner seal with obvious wear in one spot such as at 12 oclock, or 6 oclock, etc. Mine wore at the 12 position slightly and I used shims to perfectly align it as noted on the next repack. The 80s are not designed for this (all prior models are) but I was able to achieve the change. As for the speed bump sound, all 80s I've ever had/driven will make a clunk on the perfect frequency bump that I've always assumed was the longer left side shaft nipping the bronze bushing. Goes away after a fresh repack due to the grease deadening the sound - then returns shortly. No big deal. I'd be sure to check your knuckle bottom 4 nuts though. DougM __________________ Buy Head Gasket DVD for you OR for your mechanic HERE '93 FZJ since new, 2.2kw starter, Revo 275s, locked, big Hellas, rr fog, rr flood, rr Airlift, synthetics, ARB bullbar. 97 FZJ - exact same stuff but Michelin Alpins in winter "Slicker than owl shit on a wet log." - Carter |
#10 |
ThinkTank Waterboy
The only way I know of to check the brass bushing is to pull the spindle and mic it. I have two new bushings and when I replace a birf I'll be putting a new bushing in as well. It's kind of hard to visually see any wear but I did do a front axle job were it was obvious. You could see a depth difference in the grease groves as they went around the inside of the bushing.
#11 | |
IH8MUD Tour Guide
Hmmm... sounds logical enough. I have checked the bottom 4 bolts to ensure they are snug. It's almost time for another rebuild. Just noticed last weekend that the felt seals are starting to weep just a tad. I have been about 100,000 miles since the last rebuild. So, it sounds like it's about time to have fun again ![]() ![]() __________________ 95' FZJ80 OME med./J lift, ARB rack, ARB Bull Bar w/tmax 12,500, 315 Nitto, stainless brake lines, Center Diff Lock, Sliders, IPOR Skid, IPOR rear bumper, upgraded slee sticker, custom dents, more to come. . . Remember it's a gateway drug, so it will actually lead to "crystal meh". |
#12 |
Rick,
So you're thinking of pressing a new bushing in, eh? How much are those bushings? On my next repack I'll also be thinking new spindle and the upgraded needle bearing but the price for those has to genuinely hurt, ya know? I think the axle shafts tend to hit the brass bushing more often as the knuckle bearings wear and reduce the clearance. If I am visualizing things correctly, the knuckle would move slightly upward as the bottom knuckle bearing "sinks into" the race a bit. Of course, this would also provide a new clunk potential with loose knuckle bearings.... DougM DougM __________________ Buy Head Gasket DVD for you OR for your mechanic HERE '93 FZJ since new, 2.2kw starter, Revo 275s, locked, big Hellas, rr fog, rr flood, rr Airlift, synthetics, ARB bullbar. 97 FZJ - exact same stuff but Michelin Alpins in winter "Slicker than owl shit on a wet log." - Carter |
#13 |
When I did my repack and swapped out the old bushings I found that, unlike my previous cruiser (FJ40), new bushings in the 80 are not snug to the birfield, and do not require honing. I mic'd both sets of bushings and they came out exactly the same, which was interesting because my pretty complete maitenace records show no bushings every being replaced with 222K.
By the way this tool works great for pulling the bushings easily: http://forum.ih8mud.com/80-series-te...oval-tool.html __________________ Matthew For Sale: '91 FJ80 - 3FE, CDL 7 Pin Mod, Part Time, 6" Slee Lift, Slee HD Tie Rod and Drag Link, Aussie Locker RR, 37" Toyo M/Ts, ARB Front Bumper, Warn 10K, Ultimate Air Past Rigs: '75 FJ40 - 350 TPI, SM465, NP205, High Angle Driveline, Ford 9" w/ Detroit Locker RR, Front Disk Conversion, 4x4 Labs High Steer, 4 inch M.A.F. Lift, 35x12.50 MTRs |
#14 |
IH8MUD Tour Guide
Thanks for the link Matthew! I will probably be buying one of those.
#15 |
*sigh* I'm getting really sick of tearing this axle apart... I really hope it's the brass bushing. Otherwise there may be 5.29s and Longs for sale! "Screw this, I'm buying a Dana 60"
#16 |
That is reality given where you are headed with this rig. Might as well do it now and go straight to 39's.
Figure out a replacement rear while you are at it so you can go to 7's or so in the diffs. __________________ 1995 FZJ80 - F.O.R. 3.5" lift - 35" trxus MT - 5.29's - Custom SROR Tube Bumpers - De-plasticized - Dented - Dieted |
#17 |
I will buy them from you right now. Seriously. Give me those third members.
#18 | |
#19 | |
#20 |
I will make it work. but if its like that I will just send you my Taiwanese inner axle seals for your birthday.
![]() __________________ Matthew For Sale: '91 FJ80 - 3FE, CDL 7 Pin Mod, Part Time, 6" Slee Lift, Slee HD Tie Rod and Drag Link, Aussie Locker RR, 37" Toyo M/Ts, ARB Front Bumper, Warn 10K, Ultimate Air Past Rigs: '75 FJ40 - 350 TPI, SM465, NP205, High Angle Driveline, Ford 9" w/ Detroit Locker RR, Front Disk Conversion, 4x4 Labs High Steer, 4 inch M.A.F. Lift, 35x12.50 MTRs |
#21 |
Bwahahahahaha!
#22 | |
ThinkTank Waterboy
#23 |
BTW I think the bushings are $36 or $39 ea.
#24 |
Well, probably should call CDan.
