Old 05-06-08, 04:38 PM   #1
Question Wandering 80?
Hey fellas, does anyone have problems with their 80 wandering around at freeway speeds? This happens everytime I get on the freeway, regardless of the wind speed or the lack of. It just wanders from side to side, no shaking or wobbling of any kind. Tires are in good shape, pressures are all at recommended. It's getting annoying, it did this since I got this rig last year. It's a 96, bone stock and I mean bone stock. Any ideas or suggestions would be appreciated.
96 LC - lock'd & stock
92 Lexus SC400
92 MR2 Turbo
87 MR2 - Hi-Comp
86 Corolla GTS
Rondawg is offline   Reply With Quote
Old 05-06-08, 04:45 PM   #2
fishwater's Avatar
sounds like it might be a caster issue. tons of threads on this if you do a search. you say it's bone stock; stock suspension, i take it? what size tires?
'96 with >210k, OME 2.5" heavies, BFG 315 MT's, ARB, warn M8000, scanguage, scion 1806 HU w/sirius, garvin rack, CDL/pin-7, extended diff breathers, George's LED's, heated seats, Garmin GPS
fishwater is offline   Reply With Quote
Old 05-06-08, 04:47 PM   #3
tlcwagons.org
FirstToy's Avatar
you could have worn suspension components. check all the steering links (tie rod ends, relay rod ends) check the toe/caster
also check your wheel bearings for tightness
TLCA#14645
BRC#41798
I love cachapas!
my wip
I drink your milkshake!
Old 05-06-08, 04:54 PM   #4
Stock 275s, I'll read up on the caster issues.
92 Lexus SC400
92 MR2 Turbo
87 MR2 - Hi-Comp
86 Corolla GTS
Old 05-06-08, 04:55 PM   #5
I suppose it's time to put her on the hoist and take a good look.
92 Lexus SC400
92 MR2 Turbo
87 MR2 - Hi-Comp
86 Corolla GTS
Old 05-06-08, 05:13 PM   #6
fishwater's Avatar
might not be caster with those tires on stock suspension. i would take it to an alignment shop and get a printout and post the results (toe/caster/etc). but FirstToy's suggestion seems more likely if it's not lifted at all.
good luck!
Old 05-06-08, 05:33 PM   #7
Tapage's Avatar
I will add, control arms and panhard bushings ..
HJ-60 2H-T Intercooler Tencha
Originally Posted by pygpen
Tapage is online now   Reply With Quote
Novela historica | Homeowner Loan | McDonalds | Mortgages | Bank Accounts
