Old 05-05-08, 08:30 PM   #1
cool breeze's Avatar
Truck Down! cdl will not dis-engage...need pros.
I had to make a new thread because my other with a mis leading title is not getting any help. My truck is down and out, please help.
http://forum.ih8mud.com/80-series-te...-30a-fuse.html
this is also related
http://forum.ih8mud.com/80-series-te...cdl-issue.html
-Josh-
'94 FJZ80 2nd owner 175k
OME 2.5", Bumper'd: Dusty Made & custom front, TSL radials 36x12.5, Aussie locked rear and a really cool Soco magnet on the bumper!
"If Chuck Norris drove a Land Cruiser, the resulting unstoppable force would destroy the earth."
cool breeze is offline   Reply With Quote
Old 05-05-08, 09:54 PM   #2
CJF
Oookay; how about some Cliff's Notes?
What exactly's the issue?
Oh, and you can drive on pavement with the CDL engaged if you really need to (DD, etc.); you won't hurt anything. (See recent controversial thread on this).
Curtis
CJF is offline   Reply With Quote
Old 05-05-08, 10:07 PM   #3
Really, everything ive read so far was against it but must have missed that thread. WHen i did jack up one wheel to verify the tcase was locked the wheel did about half a rev.
Cliffs:
Went wheeling yesterday, now cdl is locked in low AND high
drove in circles, pavement, grass, forward, reverse, h/l....still locked
the two related fuses are good
cdl relay is good.
cdl is good but doesnt matter becasue my dash hasn;t been in the truck for over a week
next is to verify cdl actuator motor is bad but not sure if im testing the right harness(see other thread)
umm, yeah
-Josh-
Old 05-06-08, 06:44 AM   #4
(pronounced rod-ree)
Ruadhrigh's Avatar
TLCA# 16603
could you clarify this?
Originally Posted by cool breeze View Post
cdl is good but doesnt matter becasue my dash hasnt been in the truck for over a week
Ruadhrigh is offline   Reply With Quote
Old 05-06-08, 07:34 AM   #5
jonheld's Avatar
TLCA# 5980
Your truck is not "down". Remove one driveshaft and go about your business until you have time to properly diagnose the issue at hand.
Remove both driveshafts and manually rotate the transfer case output flanges. You will know right away if they are locked together.
From that position you will easily be able to troubleshoot. Start from the actuator motor and work backwards. If the motor is not getting lock/unlock voltage then the problem lies upstream.
If it is getting voltage then pull the actuator assembly off the top of the transfer and have at it. There are finger contacts on a rotating gear that are the limit switches (full lock/full unlock) and they can be probematic.
Follow along in your FSM and EWD.
Jon Held
1991 FJ80 "Lumbering White Rhino"
Times Square, New York, USA
TLCA# 5980
http://gclcny.com/jh/
Buy your FJ80 FSM here:
http://gclcny.com/jh/fsm.html
jonheld is offline   Reply With Quote
Old 05-06-08, 08:25 AM   #6
meant cdl SWITCH
-Josh-
Old 05-06-08, 08:35 AM   #7
Hate that mud...
TrickyT's Avatar
TLCA# 14435
Cliffs:
cdl relay is good.
umm, yeah
You say your CDL relay is "good", but it doesn't appear to pass all the tests to me. (See reply to post in your other thread.)
You need to do the actuator motor tests suggested in another reply in your other thread.
Tom Ferrin
N6TEF - 2m and 70cm
1989 FJ-62 - 200K, 3" OME lift, recent engine overhaul, my daily driver
1997 FZJ-80 - 85K, lifted, bumpers, sliders, lockers, and Moab-trails tested
TrickyT is offline   Reply With Quote
Old 05-06-08, 10:16 AM   #8
Hate that mud...
TrickyT's Avatar
TLCA# 14435
meant cdl SWITCH
Wait, are you saying you removed your CDL dash switch a week ago, then went wheeling yesterday and your CDL locked when you put the transfer case in 4WD low, and now it won't unlock? If this is true, you need to put the CDL switch back in, turn it off, and shift out of 4wd low. You can't just remove the CDL switch and still have the center diff lock work. For the CDL to function properly without the dash switch, you need to add a jumper between pins 7 and 10 on the switch connector.
Tom Ferrin
N6TEF - 2m and 70cm
Old 05-06-08, 11:54 AM   #9
WEll, that's a GREAT thing to know! Guess last time i wheeled i dodn't put it low so this didn't happen and make me think about the cdl button.
Cliffs: CDL will not function properly without all components attached
-Josh-
Mortgages | Cheap Magazines | Daily Horoscopes | MPAA | Loans
