10-28-08, 12:04 AM
#61 (permalink)
Originally Posted by MoGas
I have had one of these harnesses sitting around for over a year. I need to get after it.
Slacker! It actually goes in pretty darn quick.
ふざけんなよ!
10-28-08, 12:21 AM
#62 (permalink)
Originally Posted by azrider
I would have to say the Slee harness wont help. the only thing you are eliminating(by installing) is the wire run to the passenger headlight, and the original bulb sockets for the headlights. When you say you fiddled with the bulb socket, which bulb? that got it working right. Another question, does the running light and brake light function properly on the right side all the time?
The bulb I messed with was the left brake light bulb. As for the right side, it works properly all of the time.
`97 LX, locked, BFG's, OME, ARB, 4X4Labs rear, and some sliders.
`91 FJ80, grocery getter/wife's, (Sold)
`90 3VZE Turbo, SAS 4Run, (Sold)
`88 Turbo FJ62, (Sold)
`73 FJ40, (Sold)
10-28-08, 12:40 AM
#63 (permalink)
hey akarilo,
i had the exact same issue you are having. it turned out to be the rear light harness was jammed down into the fender and was being pinched. i ended up having to replace the rear harness.
good luck
Stocked '94 FZJ80 CDL - 7 PIN'D
03-08-09, 07:17 PM
#64 (permalink)
Resident Newb
Just installed today following your write up. Perfect instructions, had it done in under an hour. Thanks again!
97 TLC, 176k, Locked, CDL/7pin, 285 MTR, yellow box, ARB, slee headlights, so much more I want.......
01 Honda Civic LX - 42mpg baby!
Originally Posted by ed97fzj80
Alternatively, God reserves a certain luck for fools, children, and the criminally insane.
WTB: OME 850 & 860 springs!!!!
03-08-09, 07:22 PM
#65 (permalink)
Awesome!
ふざけんなよ!
03-12-09, 10:27 PM
#66 (permalink)
Central Scrutinizer
I have had one of these harnesses sitting around for over a year. (In the same box as a set of panhard bar adjusters, a TruSpeed, and the speedometer drive o rings) I need to get after it.
I still need to get to this...
What are the differences between the "New" Slee harness and the "Old" one?
Dave
Mine: 1993 FZJ80, Classic White.
ARB Commercial, Warn 8274, Aussie Locker, Hanna Sliders, CDL, P7, JD HIRs, Slee harness, Dual Batteries, 850/863, Slee 25mm spacers, SS brake hoses, Norcold 60.
Hers: 1988 FJ62, Red, OME Dakar, Norcold 45, "El Rojo Grande"
1986 4x4 Hilux 22RTE
1965 M416 Trailer.
Copper State Cruisers Member #85
"I would remind you that extremism in the defense of liberty is no vice. Let me remind you also that moderation in the pursuit of justice is no virtue."
Barry Goldwater
03-12-09, 10:38 PM
#67 (permalink)
Dave
From what I remember reading some of the units were prone to failure. Headlights stop working.
ふざけんなよ!
03-12-09, 10:44 PM
#68 (permalink)
Central Scrutinizer
Hmmmm, I wonder, A) When the changes were made, B) If I can easily identify if I have the old or new, and C) when I actually got mine. I think it has been a couple years at least.
Dave
1965 M416 Trailer.
Barry Goldwater
03-12-09, 11:49 PM
#69 (permalink)
I believe the new harness has a 5-pin relay vs the 4-pin on the old. Apparently the old relay is prone to failure and hard to source. Luckily the pins can be removed from the connector that plugs into the relay, so it may be possible to convert from the old to the new by finding a new relay and connector. This is still on my list of things to do
94 FZJ80, Factory Lockers.
 CDL Switch | pin 7 mod | OME 850/863 | Kaymar w/ Duals | BFG AT 295s | 150A Alternator | Odyssey PC1700MJT | Yaesu FT-8800R Ham w/ Comet SBB1
K6EPS
Need a left side swingout for a Kaymar rear bumper - Any condition
03-13-09, 07:28 AM
#70 (permalink)
If you call Slee they can tell you. It was an intermittent failure due to manufacturing issues on some of the early ones.
1996 FZJ80 not-locked, Emu 861/862, ARB, Slee sliders and skids, 285 Nitto TGs, hopefully exploring somewhere in North America.
www.purplelizard.com
03-13-09, 07:39 AM
#71 (permalink)
From my experience with the old-style Slee harness, it was not a manufacturing problem on Slee's part (it was well-made like all of Slee's stuff), but rather the relays themselves that seemed to have problems. The new harness uses automotive-style relays which (in my experience thus far) are much more reliable.
03-13-09, 09:13 AM
#72 (permalink)
Central Scrutinizer
I'll go dig it out at lunch today to see how many pins are on the relay.
1965 M416 Trailer.
Barry Goldwater
03-13-09, 10:54 AM
#74 (permalink)
Supporting Vendor
The old harnesses had a relaly with the number 804-1A-C1 on it. It looked like this.
It was a automotive relay, just not a very common one. We decided to replace them with a more traditional 30amp relay that is easily found. The old harnesses can be depinned and the sockets changed. It is just a matter of how comfortable you are with figuring the circuits.
The new one uses a more traditional style that can be replaced with a Bosch or Tyco unit, rather than the generic one we supply. The reason for the generic one is cost. Tyco or Bosch relays are a lot more than generic ones.
All new harnesses that started shipping this week is easily identified by the black sheathing vs yellow on the older harnesses. Auxiliary light harnesses always had the more traditional style relay.
PS, Hayes, you were have the types swapped in your post above.
03-19-09, 07:59 PM
#75 (permalink)
Central Scrutinizer
I must have a very old one. It takes the early relays and it has some funky little black box that has a blue, grey, and a white wire going to it in the area of plug "G" and it has no plug "H"
Dave
1965 M416 Trailer.
Barry Goldwater
04-05-09, 02:18 AM
#76 (permalink)
Can anyone tell if the plugs have been upgraded on the new harnesses, as opposed to the old ones that could encounter corrosion problems? I would like to do this upgrade to boost my HIRs brightness a little more, but like others have expressed, not if reliability takes a hit due to worse-than-oem
'95 FZJ80 / Locked / Moonglow Pearl
04-05-09, 07:43 PM
#77 (permalink)
I have only ever seen the new ones so I can't really comment other than to say I love this mod and I've had zero issues with it myself.
ふざけんなよ!
04-05-09, 10:26 PM
#78 (permalink)
sounds good !
LinkBack to this Thread: http://forum.ih8mud.com/80-series-tech/218349-installing-slees-new-style-headlight-harness.html
| Posted By |
For |
Type |
Date |
| slee harness | BoardReader |
This thread |
Refback |
01-05-09 11:00 AM |
