Old 05-03-08, 06:45 PM   1 links from elsewhere to this Post. Click to view. #31 (permalink)
NLXTACY's Avatar
TLCA# 19015
Hey THUG, is actually the same size bolt that you need to take out to add the grounds for the harness. Its a standard Toyota 10MM body bolt
ふざけんなよ!
NLXTACY is online now   Reply With Quote
Old 05-14-08, 02:33 AM   #32 (permalink)
NLXTACY's Avatar
TLCA# 19015
One ADDITIONAL word of caution to anyone doing this install, when re-installing the hood latch make sure you hand tighten all of the three bolts first. Then pull up as hard as you can on the latch. Yes, pull up to get it as high on the slots as you can. Then tighten the bottom bolt first then the two up top. The reason for doing this is to make sure that your hood closes completely. If not you will be driving yourself nuts trying to figure out why your hood isn't closing correctly.
I will be adding this note to the last of my images.
ふざけんなよ!
Old 05-14-08, 06:31 PM   #33 (permalink)
livin a poor college life
Lka1988's Avatar
Garage
Along these lines... Make sure you don't pinch the latch-release cable when you bolt down the X-member. That will cause MAJOR headaches.
Lane Anderson
'91 TRD FJ80 "Katie" - 265k, 3FE, 3H4, 860+1/850J+1, locked, 33's, Taco rims, custom front bumper, custom roof rack, LineX'd, Dual batts, CB, HIRs, OBA, GPS, aux lights, aux fan, desmogged, pintle hitch, ROTF
'63 VW Type 1 - 43k, 1600cc, Anthracite, 100% restored, Blog
'04 Crate
4-string bass, Ernie Ball Slinks, stock
"VWs and Cruisers... How can you go wrong?!?" -CreeperSleeper
Lka1988 is offline   Reply With Quote
Old 05-14-08, 07:08 PM   #34 (permalink)
Carnivore
Fly Rod's Avatar
TLCA# 18855
Thanks for the write up. I did my install with confidence after reading your slam dunk write up. I already have the jd's in place, now I need to figure out my high beam options.
Total time for me was @30 minutes. I still need to mount the relays. I just left them sitting in the battery box for now.
Fly Rod
'95 FZJ80 with stuff.
I have a double handed rod...
Jefferson State Cruisers
Fly Rod is offline   Reply With Quote
Old 05-14-08, 07:38 PM   #35 (permalink)
NLXTACY's Avatar
TLCA# 19015
Awesome FLYROD, thats was the hope because I know there have been a few people who have been on the fence about doing this because there were no clear instructions. Maybe Romer will deem it worthy to add to the FAQs
For the HI-Beams, I would recommend Daniel Stern Lighting.
Daniel Stern Lighting Consultancy and Supply
ふざけんなよ!
Old 06-05-08, 11:55 AM   #36 (permalink)
walleyefisher's Avatar
I did the Slee harness and new HIR lamps last night and WOW....major improvement. Maybe the best mod I've done next to the Landtank seat extension.
Definitely worthwhile!
1997 FZJ80 factory locked, OME 850/863 N73/N74E, Landtanks seat extension,slees light harness, HIRs, HID off-roads, slees off road light harness. rebuilt front axle 11/28-30/08
Future projects; Bushing replacment, 150amp Alt....
walleyefisher is offline   Reply With Quote
Old 06-05-08, 12:01 PM   #37 (permalink)
NLXTACY's Avatar
TLCA# 19015
Awesome, hope the instructions helped.
ふざけんなよ!
Old 06-05-08, 02:20 PM   #38 (permalink)
TLCA# 18056
I have the HIR, but I can't adjust the lights. I turn the screws but nothing change the bubble. Any tips on the "adjusting the lights"?
One vertical screw turn easy but does not change anything, the other side vertical turn very hard, but does not change anything. I can't find my horizontal adjustments.
Rami
96 LX450; Locked; 2.5" OME; 4.88; Nitto 295/75/16 TerraG; CDL Pin 7; Second battery; Slee's light harness and sliders; IPOR skid, ARB, M12000.
rhyary is offline   Reply With Quote
Old 06-05-08, 02:27 PM   #39 (permalink)
NLXTACY's Avatar
TLCA# 19015
This may be a good place to get info about adjusting your lights....and read a said story about Chico:
http://forum.ih8mud.com/80-series-te...ger-tires.html
I had no issue adjusting lights myself.
ふざけんなよ!
Old 06-10-08, 12:44 AM   #40 (permalink)
Hulk's Avatar
TLCA# 4189
Step Seven: In the little baggy you get with the kit is three useless zip ties, a bolt, a nut and an "L" bracket. Now this was a real head scratcher. Mainly because the instructions failed to mention this and I had no idea what to do with it.
I just did the Slee light harness this weekend, and I couldn't figure out what the bracket was for either. I hung both of the relays on the inside fenderwell with sheet metal screws. Wish I'd seen your write-up before this!
Matt Farr, TLCA #4189 · WØRDY
Webmaster, Rising Sun 4WD Club of Colorado · my Facebook page
1981 FJ-40 "The Hulk" + 1996 FZJ-80
Hulk is offline   Reply With Quote
Old 06-10-08, 12:53 AM   #41 (permalink)
NLXTACY's Avatar
TLCA# 19015
Hehe, well you actually did what I was about to do if I couldn't figure it out. Its exactly what I was worried everyone would go through. I really think the kit itself is really good and the effect is just soo needed. Glad it worked out.
ふざけんなよ!
Old 06-10-08, 10:39 AM   #42 (permalink)
maybe_a_80...'s Avatar
subscribed.
96 FZJ80 FACTORY LOCKED, OEM mechanical and fluids baseline and tune-up, DIY PHH "BlueHose", DIY Front Axle rebuild
planned mods: Cooper ST 255/85R16, Slee headlight harness and low beam bulbs, OME stock height suspension (maybe 2.5"lift)
maybe_a_80... is offline   Reply With Quote
Old 06-10-08, 03:35 PM   #43 (permalink)
hntashdjian's Avatar
TLCA# 18812
My first major upgrage on my newly aquired 94, and I couldnt have done it without this thread. Like you said, Slee's intructions are imcomplete on this. Maybe whoever wrote the instructions has installed this enough times that he left out many obvious steps for him but not so obvious for us.
Harry
hntashdjian is online now   Reply With Quote
Old 06-10-08, 03:46 PM   #44 (permalink)
NLXTACY's Avatar
TLCA# 19015
I was contacted by Slee when I first did the write up so my guess is that they are already re-working the instructions/pictures. Glad you got it going ok!
ふざけんなよ!
Old 06-10-08, 04:57 PM   #45 (permalink)
corsair23's Avatar
GREAT job on the writeup. I've been holding off on doing the upgrade but now, I've got exactly what I need. I know Christo very much appreciates feedback to his instructions to make them more "idiot" proof. I say that because I have done my part to help "idiot" proof some of them myself cuz, well...sometimes I am an idiot when it comes to mods .
Compared to instructions from say ARB, Christo's are great. With the additional information you provide they can REALLY be top notch
'97 LX450 aka "The Whale" with a winch called Damien
'97 FZJ80 40th AE, Antique Sage, #267
'74 FJ40, 2F, SM420, 4" Lift, ARB locked front and rear, 33" MTRs
'76 FJ40, 2F, 4-speed, 4" Lift, 33" BFG ATs (SOLD)
corsair23 is offline   Reply With Quote
Old 06-10-08, 05:26 PM   #46 (permalink)
NLXTACY's Avatar
TLCA# 19015
Thanx CORSAIR!
ふざけんなよ!
Old 06-10-08, 05:31 PM   #47 (permalink)
Hulk's Avatar
TLCA# 4189
Now that I've done this, I bet we could knock it out in under an hour. Come on over this weekend, Jeff!
Old 06-10-08, 05:38 PM   #48 (permalink)
NLXTACY's Avatar
TLCA# 19015
An hour, jeez how many beers you opening during the install?
ふざけんなよ!
Old 06-11-08, 07:12 AM   #49 (permalink)
Jrob80's Avatar
TLCA# 18932
!!!Stupid Q? Alert!!!
Okay I have been on Slee a number of times and have orderd a few things off there website but I cannot find this headlight harness... HELP
Very nice write up I actually just got some of the projector headlights and will be getting the harness as soon as I can find it
jr
-1996 Unlocked -Arb Front bmpr -AVN 7000, Rockford Fostgate Amp, Viper remote start/alarm, & Boston Speakers -Auto dimming mirror -Husky liner -Waterproof seat covers (and a list of mods to long to list)
Be good or be good at it
Jrob80 is offline   Reply With Quote
Old 06-11-08, 07:23 AM   #50 (permalink)
thugmusk's Avatar
TLCA# 3842
Slee - Light Harness
Under "Lights" in the left menu.
Rich
'87 FJ60 (10/09 - present)
'97 FZJ80 (03/08 - 08/09, crashed)
'83 FJ60 (11/99 - 12/00, sold)
'85 FJ60 (11/98 - 3/08, rusted, dismantled, parted)
'78 FJ40 (03/98 - present)
'76 FJ40 (10/94 - 11/97, stolen, not forgotten)
thugmusk is offline   Reply With Quote
Old 06-11-08, 10:57 AM   #51 (permalink)
hill's Avatar
i keep having issues with the relays....
1997 FZJ80 - Supercharged w/ F&R lockers, 285/75r16, ARB w/ Warn9000, 2.5" Slee Lift
1973 FJ40 - Soft top, 2" lift, 33x10.5 BFG, Pwr Str, H4 Lights, Warn 9000
Calgary, Alberta Canada
hill is offline   Reply With Quote
Old 06-11-08, 11:07 AM   #52 (permalink)
NLXTACY's Avatar
TLCA# 19015
What issues are you having?
ふざけんなよ!
Old 09-11-08, 07:27 PM   #53 (permalink)
mainemike's Avatar
TLCA# 17772
NLXTACY - thanks for the great write up! I've had the Slee harness sitting around for a while, finally got the bulbs from daniel stern and put it all in. Huge improvement over factory lo-beams.
Your write up was fantastic, much appreciated.
1996 FZJ80 not-locked, Emu 861/862, ARB, Slee sliders and skids, 285 Nitto TGs, hopefully exploring somewhere in North America.
www.purplelizard.com
mainemike is offline   Reply With Quote
Old 09-11-08, 07:42 PM   #54 (permalink)
NLXTACY!!!! Thanks, I think Slee has your pictures. Have my harness, dielectric grease and cold beer in hand. With your write up and pictures I'm stoked and on my way to the shop!!
Thankyou
fokkersauras is offline   Reply With Quote
Old 09-11-08, 07:45 PM   #55 (permalink)
NLXTACY's Avatar
TLCA# 19015
Thank you MAINEMIKE. Its niec to know people are at least reading the thread
FOKKERSAURUS, go to town with it. Its cake!
ふざけんなよ!
Old 10-27-08, 01:33 AM   #56 (permalink)
NLXTACY's Avatar
TLCA# 19015
Just as an update, I've had two folks contact me about helping them troubleshoot an install. Unfortunately Slee was closed at the time so I was the next best thing
On both of these problematic installs, both turned out to be an issue with the wiring with the harness itself. Please contact Slee as soon as you can to remedy.
The problem is that the low and high beams are basically switched due to a reversed ground and can most likely be taken care of by reversing the pins but Slee will have the exact solution.
ふざけんなよ!
Old 10-27-08, 11:13 PM   #57 (permalink)
akarilo's Avatar
Been considering this harness because;
I have an odd ball problem that is intermittent on the left rear brake light. This problem only occurrs when the headlights are on. The left running light goes out and brake light does not come on when the pedal is depressed. Turn the headlights off and all functions properly. Don't know if I'm dealing with a voltage drop or what.
I fiddled with it a bit (bulb seating, etc.) and got it working properly but it has since resurfaced. Perhaps the harness setup could remedy the problem.
Thoughts
`97 LX, locked, BFG's, OME, ARB, 4X4Labs rear, and some sliders.
`91 FJ80, grocery getter/wife's, (Sold)
`90 3VZE Turbo, SAS 4Run, (Sold)
`88 Turbo FJ62, (Sold)
`73 FJ40, (Sold)
akarilo is offline   Reply With Quote
Old 10-27-08, 11:42 PM   #58 (permalink)
azrider's Avatar
I would have to say the Slee harness wont help. the only thing you are eliminating(by installing) is the wire run to the passenger headlight, and the original bulb sockets for the headlights. When you say you fiddled with the bulb socket, which bulb? that got it working right. Another question, does the running light and brake light function properly on the right side all the time?
97 locked green Lexus LX450
OME J's & heavy coils, L shocks, 35" tires
4.88 gears, Safari snorkel
Slee light harness/ John Deere HIR bulbs flushmount 750 watt inverter
2-Hella 5" and 2- 7' Checker Auto HID's
George's LED domes
custom sliders/ Viair onboard air
CSC #122
azrider is offline   Reply With Quote
Old 10-27-08, 11:59 PM   #59 (permalink)
NLXTACY's Avatar
TLCA# 19015
X2 solve the issue first before doing the install.
ふざけんなよ!
Old 10-28-08, 12:03 AM   #60 (permalink)
Central Scrutinizer
MoGas's Avatar
TLCA# 17188
I have had one of these harnesses sitting around for over a year. (In the same box as a set of panhard bar adjusters, a TruSpeed, and the speedometer drive o rings) I need to get after it.
Mine: 1993 FZJ80, Classic White.
ARB Commercial, Warn 8274, Aussie Locker, Hanna Sliders, CDL, P7, JD HIRs, Slee harness, Dual Batteries, 850/863, Slee 25mm spacers, SS brake hoses, Norcold 60.
Hers: 1988 FJ62, Red, OME Dakar, Norcold 45, "El Rojo Grande"
1986 4x4 Hilux 22RTE
1965 M416 Trailer.
Copper State Cruisers Member #85
"I would remind you that extremism in the defense of liberty is no vice. Let me remind you also that moderation in the pursuit of justice is no virtue."
Barry Goldwater
MoGas is offline   Reply With Quote
LinkBack to this Thread: http://forum.ih8mud.com/80-series-tech/218349-installing-slees-new-style-headlight-harness.html
Posted By For Type Date
slee harness | BoardReader This thread Refback 01-05-09 11:00 AM
