LinkBack (10) Thread Tools Display Modes
Old 04-11-08, 01:08 PM   10 links from elsewhere to this Post. Click to view. #1 (permalink)
jditom's Avatar
Install Eclipse AVN6620 Navigation etc.
Please also refer to original post by NaterGator who started us on this wonderful path! http://forum.ih8mud.com/80-series-te...e-avn5510.html
I wanted to summarize the install in a focused post so here goes.
I bought the AVN6620 ($860), iPod adapter ($45) and backup camera ($159) from cartronixplus.com and they matched e-bay prices. Yes you can also do Bluetooth phone, satellite radio and TV tuner, which I did not. Do not get a amp harness or front trim bracket; you do not need these extra items.
The bracket from the OEM head unit (HU) screws off and goes right on the AVN HU. And will screw in the same location using OEM hardware (nice!) You need a Toyota harness off e-bay, which cost about $5-6. See here IH8MUD.com Forum - View Single Post - New navigation headunit, Eclipse AVN5510
Get stared by taking off your dash section, glove box and passenger kick panel. 4 screws and the OEM head unit is out. Unplug it from the back and you will not use that plug any longer. Notice in the same cord as the OEM plug there are 2 other plugs that plug right into your aftermarket Toyota harness and bypass the amp (sweet Jesus how nice is that). Now go to the right of your glove box above your tweeter and you will see the OEM amp. Unplug it since you will by pass it. Two screws and the amp is out and that space makes for a perfect location for the iPod adaptor.
Put the OEM brackets on your AVN HU and start putting together the wires to the Toyota harness. All the colors are a perfect match so not much thinking. There is a remote amp wire that I did not use. Everything worked great with the exception of the wire that was the Red ACC power supply so I bypassed that one from the HU to a power source. Everything else was plug and play.
The AVN comes with a lot of extra wires that you do not need to use and will save you some room when installing since it is a tight fit. I did not use the external video and internal video cables or the amp cable with steering wheel remote.
I also did not like the screen going into night mode when I turned my lights on since I like to have daylight running lights on certain situations. So I connected the orange illumination wire to a simple switch that I can control nighttime mode when I want it.
Now connect your VSS (red wire with orange strip) and reverse signal wire (red with black strip) Follow the yellow box install IH8MUD.com PRODUCT REVIEW: Yellow Box Electronic Speedo Correction to find the VSS wire and the reverse is right next to it on the same harness. Just ground the parking brake signal and you will have full control of your HU while driving! Make sure everything is working before you install!
Run all you wires from the glove box to the HU now push the HU in and pull excess wires from the rear of the HU into the glove box space. There is not enough room to just push all those wires behind the HU. Screw in the HU and zip tie everything out of the way.
I did the back up camera a bit different. If you have a aftermarket rear bumper with spare tire holder putting the back up camera under your license plate lights is not going to work since you tire will obstruct your view. Many folk just put it on the top of the rear hatch outside. I put mine inside since I did not want to worry about it getting hit etc. It makes for a cleaner install. I just ran the wire along the passenger kick panel all the way back to the rear and up to the camera. The camera is not centered because the rear brake light is in the way but it is such a wide-angle camera that it does not make much difference. It is a great wide view of everything back there. If you want the perfect install you should screw the camera to the bottom of your brake light and run the wire through the rear hatch gromet but maybe next time!
What do I like!
Tilting head since that location is not ideal for a screen. A bit to low but the tilt feature makes it very good to view. Sound is much improved even with OEM crap speakers and no OEM amp! GPS is spot on. Ipod adaptor is to die for. Back up cam is a true safety feature and you can also have it on any time you want to look back there.
A great mod and many thanks to NaterGator, Vin-barrett, MF34Inc, Jrob80 for helping me do the right thing!
Toyota harness to AVN HU.
Nighttime mode switch!
Rear panel for excess backup cam wire.
Money shot
1996 TLC, Cooper D. STT 305/70/16, CDL, 7 PIN, OME steer & 850/863, Bilstein HD, IPA fog. Slee's front bumper, skid plate, CC bushings, SS brake lines x 7, light/aux harness & speedo gear. Warn XD 9000, Hanna sliders. 4X4labs rear bumper. OEM sub tank & overhead console. Projection headlamps, clear lenses, rear tail LED, George's inside LED's. MagnFlow exhaust (cat back). Eclipse Nav.
2005 GX470, KDSS, Revo's, running boards off!
jditom is offline   Reply With Quote
Old 04-11-08, 01:09 PM   #2 (permalink)
jditom's Avatar
A few more pics!
iPod money shot
Fit is perfect with no trimming etc.
Backup cam location.
Back up cam view with tilt head!
Old 04-11-08, 01:34 PM   #3 (permalink)
NLXTACY's Avatar
TLCA# 19015
Sweet! This is the unit I have my eyes on. Can't wait to get back from Vegas/Frisco so I can order this bad boy.
ふざけんなよ!
Old 04-11-08, 03:44 PM   #4 (permalink)
jditom's Avatar
They are real nice and the GPS has all the national forest roads on there. They are better marked then the NF map I have.
Prices are coming down and you can get a 6610 or a 5510 for several hundred less if you keep your eye on e-bay.
Enjoy
Old 04-12-08, 07:39 AM   #5 (permalink)
Resident Newb
p8nt's Avatar
Nice install! Do all models have the tilting head?
97 TLC, 176k, Locked, CDL/7pin, 285 MTR, yellow box, ARB, slee headlights, so much more I want.......
01 Honda Civic LX - 42mpg baby!
Originally Posted by ed97fzj80 View Post
Alternatively, God reserves a certain luck for fools, children, and the criminally insane.
WTB: OME 850 & 860 springs!!!!
p8nt is offline   Reply With Quote
Old 04-12-08, 09:35 AM   #6 (permalink)
jditom's Avatar
I think the 6610 is the same. The 5510 is almost the same with the exception of having a CD drive instead of a DVD drive. I do not know if it tilts. But I think that tilt feature makes viewing maps etc while driving so much easier and safer that it is worth the extra$.
Old 04-12-08, 11:35 AM   #7 (permalink)
Jrob80's Avatar
TLCA# 18932
Great install I am sure you will be very happy with it just like I have been with my AVN. That is really interesting with the night mode and the switch, I guess on my CD player you can put in day mode whent he lights are on. I wish I would have taken the time to install my stuff but with everything I had done (navigation, 4 speakers, amp, & viper remote start/alarm) I thought it was better to have the experts do it all and get it all done in a day! AWESOME set up thought!
-Next for me the back up camera!
jr
-1996 Unlocked -Arb Front bmpr -AVN 7000, Rockford Fostgate Amp, Viper remote start/alarm, & Boston Speakers -Auto dimming mirror -Husky liner -Waterproof seat covers (and a list of mods to long to list)
Be good or be good at it
Jrob80 is offline   Reply With Quote
Old 04-12-08, 10:02 PM   #8 (permalink)
jditom's Avatar
Just checked and the AVN5510, 6610 and 6620 all have tilt heads.
Old 04-12-08, 11:33 PM   #9 (permalink)
Poseidon, look at me
NaterGator's Avatar
TLCA# 18767
Correct, the AVN5510 and up all tilt. The major difference is in what is accepted in the 'extra' optical slot (IE not the one with the map disc) and I think one comes with an internal HDD?
Also, you can effectively override the night mode by holding the green "menu" button until the display options come up and just tap "day". It will toggle on/off the day mode override.
'96 LX450, 33" Revos, OME lifted, etc, etc
Love the life you live, live the life you love. -Bob Marley
Selfishness is not living as one wishes to live, it is asking others to live as one wishes to live. -Oscar Wilde
Right-click image transloading made blindingly easy.
Originally Posted by fsusteve View Post
What are you talking about bro, I'm a long time gator fan.......
WFC: 0473-9763-9112
NaterGator is offline   Reply With Quote
Old 04-13-08, 01:38 PM   #10 (permalink)
jditom's Avatar
Damn I should have RTFM
Old 04-13-08, 01:42 PM   #11 (permalink)
i'm about to pull the $859 trigger. The ipod is essential and then the wiring adapter. Bluetooth and backup cams are unneccessary for my needs, they would be icing. How much am I looking to spend for the accessories and other basics for self install. What am i missing?
Ps talk me into it, and don't tell my wife.
97 Lx450 Locked
2.5" OME Heavy
3/4 Ramp rack on roof w/ frt porch
Adj. length platform
Tailgate reinforcement
BFG AT's
ARB frt bumper
Gratuitous lighting on bumper
Radio Crack CB
RTT
4xinnovation kick out sliders!!!!
Custom Laptop Mount
womacje is offline   Reply With Quote
Old 04-13-08, 04:20 PM   #12 (permalink)
jditom's Avatar
If all you want is the iPod then add $45 to your HU and $5-6 for the harness and that is it. You will need some wire crimping things to make your harness, black tape and zip ties which are all cheep items at radio shack etc.
You will be just over $900 and last year it would have cost about $1500.
Old 04-13-08, 08:58 PM   #13 (permalink)
Grounding Question
Not completely on topic but can I ask where you connected the main ground? I have tried everywhere (have an Alpine W205) and the best spot is a bolt connected to the round tubing behind the head unit. I get a constant whine, gets louder when the headlights are on, and a bit of a pop when it's shut off. Thoughts?
mrbav8tr is offline   Reply With Quote
Old 04-14-08, 07:13 AM   #14 (permalink)
jditom's Avatar
I did the main ground through the harness so it goes to the frame somewhere. You may want to try a ground loop isolator for the noise? Cheep at Radio Shack.
Old 04-29-08, 10:04 PM   #15 (permalink)
Guy Fawkes Lives!
Miescha's Avatar
TLCA# 8094
Awesome setup - and I really love those white cotton european driving shoes in the last pic of post #1
1996 FZJ80 (original owner) Less Stuff than WFD175
Miescha is offline   Reply With Quote
Old 04-29-08, 10:16 PM   #16 (permalink)
jditom's Avatar
Old 04-29-08, 11:15 PM   #17 (permalink)
Salue's Avatar
What is that black knob(?) below the ignition? My '97 has the hole there but I just assumed it is where the older 80's have their e-brake. That's where my '94 4runner's e-brake is.
Salue
Salue is offline   Reply With Quote
Old 04-29-08, 11:58 PM   #18 (permalink)
NLXTACY's Avatar
TLCA# 19015
Hand throttle
Per Slee: "Keeping rpm's up when winching can be a challenge when you are outside the vehicle. The Toyota factory hand throttle is an ideal addition to any trail vehicle. Being a factory part, it installs in minutes to any 1991-1997 80 Series."
ふざけんなよ!
Old 05-28-08, 12:00 PM   #19 (permalink)
TLCA# 15158
Does this unit have a USB port for a Zune MP3?
Ron
1978 FJ40 - Restoration project with 58K miles
1994 FZJ80 129K miles Locked with 295 Terra Grapplers, OME heavies, ARB front bumper, Warn 9000
1994 FZJ80 with 43k miles. Tons of Parts for Sale Thread and pics here: http://forum.ih8mud.com/parting-out/316462-1994-43k-plus-3-other-80s-%40-pick-part.html
1984 FJ60 - Fairly Rustfree Texas Truck, Rebuilt Engine with 5K (For Sale)
1984 Harley FLTC
toyman317 is offline   Reply With Quote
Old 05-28-08, 12:40 PM   #20 (permalink)
jditom's Avatar
I do not think so but the iPod interface alone would make me dump the Zune and get an iPod. The iPod interface for the Eclipse is about $50.
Good Luck
Old 06-02-08, 10:06 PM   #21 (permalink)
#1 Super Guy
TOY350's Avatar
TLCA# 4939
Installation of Nav unit and back up camera starts tomorrow! Thanks again for the write ups guys.
GARETT
67 FJ40
- 350 - SM420 - SOA - ALL PRO HY-STEER - 4.88 - ARB F/R - 30 SPLINE LONGS - 35 MTR's - WARN XD9000
95 FZJ80 - 3 LOCK - LONGS - 4.88 - 315 KM2's - OME J & L - LT CC & MAF MOD - ARB/WARN XD9000 - HANNA SLIDERS - 4X4 LABS REAR - SLEE SKIDS & MORE - ECLIPSE NAV - RUBICON TESTED!
JEFFERSON STATE CRUISERS
JSC FORUM
Originally Posted by cruiserdan View Post
That particular rock is a screaming bitch and if I had my way I would dynamite the sonofabitch and use the left-over pieces to fill up the hole.
TOY350 is offline   Reply With Quote
Old 06-02-08, 11:14 PM   #22 (permalink)
#1 Super Guy
TOY350's Avatar
TLCA# 4939
I just pre-tested my harness adapter to the Toyota stock radio plugs that were not previously used. I had power at the yellow wire and ACC power (with key on) at the red wire. You bypassed the red ACC wire and I don't see why I would have to unless it doesn't work once everything is hooked up. Did you test yours prior?
Garett
GARETT
67 FJ40
JSC FORUM
Old 06-03-08, 10:22 AM   #23 (permalink)
jditom's Avatar
Garett
For some reason my red wire did not work so I bypassed it. I think your should be fine. At the time mine was installed and easier to bypass it.
Good Luck
Old 06-04-08, 11:30 PM   #24 (permalink)
#1 Super Guy
TOY350's Avatar
TLCA# 4939
Thanks again for the write up, all in and working great!
All I can say is WOW this is one sweet upgrade Ran a couple of LCD headrest monitors for the kids too.
GARETT
67 FJ40
JSC FORUM
Old 06-05-08, 07:29 AM   #25 (permalink)
jditom's Avatar
Please share a pic of your headrest monitors.
Good work
Old 06-05-08, 09:15 PM   #26 (permalink)
#1 Super Guy
TOY350's Avatar
TLCA# 4939
Here are some shots. The monitors aren't the greatest but they were priced right and have a clear picture directly in front of them, which is where you would be viewing anyway. The Eclipse units display can be viewed from just about any angle which is nice.
GARETT
67 FJ40
JSC FORUM
Old 06-05-08, 09:30 PM   #27 (permalink)
#1 Super Guy
TOY350's Avatar
TLCA# 4939
It was a tight fit and I ran every harness but the Ipod connector, so you can get everything in there. I also soldered the harness adapter wires to the harness wires on the unit and put heat shrink tubing around each one. That kept me from having the large mass of butt connectors all together. I ran the backup camera wires down the passenger side along with a remote amp turn on and RCA cables for the sub low level input (I have a Bazooka 10" back there). I ran the GPS wire out the drivers side firewall and have the sensor positioned on the cowling in the center between the windshield and hood. I am an Apple hater so I have my Creative 20gb player hooked into the audio in so I can use it, although I must admit the Ipod interface is sweet if you have one. The video out wires are run down under the center console and split to each of the headrest monitors, these work great and display the DVD when the Nav unit is in navigation and backup camera modes (just like it should).
GARETT
67 FJ40
JSC FORUM
LinkBack to this Thread: http://forum.ih8mud.com/80-series-tech/215697-install-eclipse-avn6620-navigation-etc.html
Posted By For Type Date
Navigation 'parking' wire - ScionLife Home of the Scion xA, Scion xB, Scion xD and Scion tC owner and enthusiast This thread Refback 09-22-09 02:04 PM
ScionLife View topic - Navigation 'parking' wire This thread Refback 03-13-09 12:26 PM
Viper Sailboat Historydodge, Viper Motorcycle Exhausts, Virago 550 Yamaha Motorcycle - Wireshelf This thread Refback 03-08-09 08:48 AM
Install Eclipse AVN6620 Navigation etc. - IH8MUD™ Forums This thread Refback 12-24-08 09:09 AM
Untitled document This thread Refback 04-18-08 11:08 PM
I wanna talk about Harness Cleaners » Blog Archive » Fast Friday links This thread Pingback 04-18-08 10:10 AM
I wanna talk about Harness Cleaners » Blog Archive » 'harness cleaner' on the web This thread Pingback 04-17-08 10:11 AM
I wanna talk about Harness Cleaners » Blog Archive » Fast Monday links This thread Pingback 04-14-08 10:06 AM
I wanna talk about Harness Cleaners » Blog Archive » What others have been saying about harness cleaner This thread Pingback 04-13-08 10:06 AM
I wanna talk about Harness Cleaners » Blog Archive » What others have been saying about harness cleaner This thread Pingback 04-12-08 10:09 AM
