04-10-08, 01:27 AM
#31 (permalink)
grown up MOD
Originally Posted by FJBen
Riiiiight
I can't really point the finger at the  to hard.
After all it was me who backed over my at the time 3 year olds John Deere tri-cycle with the 80.
I must say John Deere makes some tough shit but not that tough.
"If it wasn't a Landcruiser and hadn't been built the way it was you do realize you would be DEAD." VA State Police Officer
04-15-08, 04:22 PM
#32 (permalink)
Since our 97 is frequently parallel parked, I got this one;
Boyo VTC461R Rear-view System Wireless rear-view camera and 6" color mirror monitor at Crutchfield.com
It sends the picture via wireless from camera to mirror and detects back up lights to turn on. I routed the camera wiring (power and reverse detect) along side the license plate light wiring so no holes were necessary. The monitor clips onto the mirror and is the right width to fit between the visors but it was too high so I lowered the mirror 1 1/2 inch with a block of wood and longer screws. I do get some video noise occasionally but I write that off to being wireless. If I get time, I may look into wiring it direct.
04-15-08, 04:28 PM
#33 (permalink)
You want to do what...?
Originally Posted by rostige
rear camera pic
clean install. But your license plate is still readable...
'97: 89K, 3xlock, Custom HD roo bar for sale, see Classifieds for SnT, 285 MT/Rs on steelies, Hanna sliders, 851+1.5"/863/N73/N74E/SD24, ARB bull with M12, Kaymar with duals, Kaymar rack, Slee TC skid, 2m/440, more stuff, loose nut behind the wheel!)
'03: 112K, the better half's...
DD Accord
souped up DR650
04-15-08, 04:32 PM
#34 (permalink)
Interesting timing, my dad just gave me a new Wireless one, the cheapy...but hell for free I'll try it
04-16-08, 12:39 AM
#35 (permalink)
rear camera
rear camera
06-05-08, 07:03 AM
#36 (permalink)
Rookie
Audiovox has a LCMR6CT Replacement Rear View Mirror with 4.5" Wide Screen (16:9) Color LCD with Compass and Outside Temperature. This is not a strap on. See Welcome to Audiovox
Kurt
Originally Posted by NLXTACY
Here is the mirror I was considering using after I read about CDan adding it:
Rear Camera Display Mirror by Gentex
But I like the Audiovox one better. I like being able to have dual inputs. The only thing I wish the Audiovox had was compass and temp. My wife said she is open to me adding this as long as it has those two things. Our S4 has it and she is hooked.
BRIAN, what was the need for using two rear cameras? Especially given the wide angle view? And also why did you decide to not mount up front?
06-05-08, 09:13 AM
#37 (permalink)
any more new feedback on the systems?
DD Accord
souped up DR650
06-05-08, 12:05 PM
#38 (permalink)
Just waiting for the finance department  to give the thumbs up
ふざけんなよ!
06-05-08, 02:07 PM
#39 (permalink)
Well....I'm almost emberrassed to say this......but....
I'm not sure it was worth it.
I intended to use the system in backing up, especially on rough trails where I needed a better view to see where I was going.
What I found after several months of use is that you can't rely on just the camera system in reversing, because a) the image is only 2D and you don't get an accurate depiction of what's really behind you and b) it's a bit distorted by the wide angle view, but has to be wide angle or you really wouldn't see anything at all and c) the resolution isn't all that great and d) when the camera lens get wet or dusty or muddy, which is pretty much all the time off road, you can't see anything without stopping and getting out to clean the lens.
You definately can't use it to judge how far things are behind you if you're backing into something, because of the inaccurate view...same as the mirrors.
The system does work very well in at least giving you a picture of what's behind you, so if there is something major like a huge hole, a person, child or vehicle if gives you an extra margin of safety. This is actually what these systems are meant for in the first place. I was asking too much from it and they aren't designed to be used in motion.
The night vision, or at least higher light sensativity is nice to have at night as well. Especially if you don't have good back up lights or don't want to kick them on, such as driving around in the city.
But to be frankly honest, the absolute best bang for the buck for reversing is the largest mirrors you can find. This system came with a larger rear view mirror than stock and mirror itself actually helps a lot. But more than anything, I've come to appreciate the large mirrors on the Land Cruiser 80. My mini-truck has small mirrors and I had major issues backing up. The larger mirrors of the Land Cruiser give me a better rear view and I'm able to more safely back using the edges of the road.
I would still recommend a system like this, especially for anyone who doesn't have a clear view rearward, such tire carrier or lots of gear in the back, but reconize the limitations and don't go overboard on buying a really expensive system like I did. Knowing what I know now, I'd probably opt for something much cheaper and simplier. This system is best used for a quick reference to see what is directly behind you in your blind spot as you use your side mirrors, a spotter or looking directly back yourself to do the actual backing up.
That said, I haven't used it on a major off road trail and I'm sure there are benefits to seeing directly behind you on a regular basis when back downa trail, where Land Cruiser swallowing holes might be outside the view of the mirrors, however, the 2D view makes it extremely difficult to judge the depth of holes and obsticals, but hopefully since you drove forward over them, you can rely on your memory of the trail and act appropriately once you know where they are.
06-06-08, 05:29 PM
#40 (permalink)
That´s why I went to Camping World and did a close look at those big RV whales, with expensive rear view camera/monitor systems as to learn how they managed and unfortunately found that their best wide angle cameras were enclosed in big ugly rear housings which I couldn´t imagine bolted in my 80 cruiser rear roof, breaking it´s nice, elegant and smooth body as to clear my rear tire carrier and had my desired more precise rearview
Brian: you made me cry because you were my last chance to find the perfect setup
Do anybody have an idea in how install a rearview camera housing with a windshield type wiper and liquid pressure cleaner as our rear wiper work but of course on a small scale to fit the camera housing and avoid Brian´s agony
1993 FZJ80, 2" OME, 305/70-16, Auburn Locker, F&R TJM bullbars,Long Range 150 ltr gas tank, 170 Amp alt, 240 amp 3 Battery Isolator & 3 Deep Cycle batt,4 DBA slotted rotors, Carbon/Ceramic pads, SS/Teflon brake hoses, Warn 9000, PIAA 80 Racing,Coil&Shock Dampened Front Seats.Engel 60 Qts Fridge.
