Old 03-27-08, 09:03 PM   #1
91Cruizer's Avatar
TLCA# 16728
Temp gauge readings off???
A problem just crept up on my 91 cruiser. The temp gauge creeps up to a little below red then drops while sitting in gear. The funny thing is that it shows no under hood symptoms of being overly hot. The fan clutch even dropped in rpm once when it showed over mid point. I don't think it is the clutch because it seems to be moving a lot of air. I am thinking it was my low budget repair of the bypass hoses with unformed hose that is somewhat kinked. Would this cause excessive heat around the temp. sensor and give false readings? I have a new radiator as well, so that is not an issue.
91 fj80, ome low lift, Bilsteins, 180k
72 fj40, 350 chev, 3 speed
65 VW Beetle
91Cruizer is offline   Reply With Quote
Old 03-27-08, 10:55 PM   #2
CJF
Not sure what you're trying to say there...
"Seems"?? NEVER trust an old fan clutch. How many miles on yours?
Curtis
CJF is offline   Reply With Quote
Old 03-28-08, 08:00 AM   #3
cptmud's Avatar
not sure what the prob may be, but never trust a toyota temp gauge. Apart from a big flat spot in them, may be a bit of steam build up near the sensor
"Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote." - Benjamin Franklin, 1759
cptmud is offline   Reply With Quote
Old 03-28-08, 09:45 AM   #4
that is exactly what mine did. replaced the guage and sensor just to be safe. no more problems
Pogue is offline   Reply With Quote
Old 03-28-08, 11:38 AM   #5
Lka1988's Avatar
The "flat spot" is contained to 93-97 FZJ's. The OP has a 91.
Lane Anderson
1991 TRD FJ80, Red, 249.9k, 3FE Powa
Lifted, flareless, LineX, 31" BFGs, Slee stuff, Dual batts, HIRs, OBA, GPS, headlight buzzer, couple lights, clear/tinted lenses, 100 Series emblems, NLXTACY's garage opener, air horns, custom 3FE sticker
__________________________________________
"If Chuck Norris drove a Land Cruiser, the resulting unstoppable force would destroy the earth."
Originally Posted by ed97fzj80
We are not the base, we are the 2% lunatic fringe.
Lka1988 is offline   Reply With Quote
Old 03-28-08, 12:01 PM   #6
CJF
You sure about that?
I know Raven's temp gauge observations and resulting mod apply to 93-97, but I'll bet 91-92's have a pretty big dead spot in the center as well. I've never checked though...
My '84 Cressida has a "real" gauge, and it's amazing how much it moves. For example, just opening the heater valve and letting that cold coolant into the system will even register slightly/temporarily. Whereas on the Cruiser, it simply warms up to the center of the gauge and then just sticks.
Curtis
Old 03-28-08, 12:05 PM   #7
Lka1988's Avatar
Curtis
90% sure.
I've watched my temp gauge move up from the center and not overheat. It was a hot day.
Also during cold mornings, it reads lower than center until I've driven around for a while.
But I could be wrong.
Lane Anderson
Loans | vShare YouTube Clone | Refinance | Credit Card | Personal Loans
