Old 03-23-08, 04:10 PM   #1
"Clunk Noise" from drivetrain
Hey everyone,
I test drove a stock 94 today. Everything seemed to be ok until i put the car in reverse and heard a loud "clunk" noise. Everything else was very smooth. Once i accelerated from a stop, i heard the clunk again. Also, if you let for of the gas while going around 5 mph and give it gas, you hear the noise again.
On my old 94, there is a screw that adjusts the idle(correct me if im wrong). You cannot see the screw unless you open the top part(drill through top hole). I think its part of the air sensor unit. On this car, it was opened and the screw is visible. What does this mean ? Ive seen many 80s with that covered.
Thanks in advance,
Harry
hntashdjian is offline   Reply With Quote
Old 03-23-08, 09:41 PM   #2
Vitesse_6's Avatar
TLCA# 8382
Could be the drive lines needing grease, Does it have rear disc brakes?
Mine clunks for a number of reasons.
Its a start.
Good luck
Enjoy
Brian Passey KE7TGH
wasatchcruisers
71 FJ40 Stinky
94 FZJ80 Ryoku Ryu
Cruiser ring's anyone
Stuff I've done...
My 40 work in progress
Vitesse_6 is offline   Reply With Quote
Old 03-24-08, 05:11 AM   #3
I have a similar problem.
When I'm stopped with the brake pressed and I change from reverse to D and from D to reverse, I hear the clunk. The same if I quickly press the accelerator. It looks like there is something loose down there. I think it could be a driveshaft, axle shaft or a birfield.
Most of the diesel 80 with manual transmission and powered engine have some kind of looseness down there because of the big torque of the engine and because they don't have a torque converter that smoothes the sudden power transfer.
What worries me is mine (and yours) are automatic. My engine is powered as well, so, what REALLY worries me is thinking about the chance that the looseness is in the transmission or in the torque converter.
If the problem comes from the shafts, I wouln't worry much, I know people that have run with them this way for years without problems.
I'll tell you when I find out where my clank is, so it can help you to locate yours.
Cañonero is offline   Reply With Quote
Old 03-24-08, 09:36 AM   #4
Squash's Avatar
Grease the d/s to begin with, whlie you are down there check the "U-joints".
I like standing the truck on jacks, this allows you to turn the drive train with your foot by kicking a wheel. A tight drive shaft will have no play between u-joints.
93 FZJ80 De-flared, de-bumpered and Aussied DD.
HZJ79L 5speed diesel LSD for work.
Squash is offline   Reply With Quote
Old 03-28-08, 01:07 PM   #5
I too suffer from this clunk in the drivetrain. When the truck is in park I can stand on the rear wheel and rock the truck foward and reverse at least an 1 1/2 inches. Awefull lot of slack in the drivetrain. Surely that is not a lack of grease. Anyway, mine is a 92 FJ80 and I am going to be setting her up on 33" with an OME J lift kit in the next couple of weeks. Parts are on the way. I plan on doing investigative work then. I will let you guys know what I find. In the mean time, I would love some suggestions of things to check, lube, etc while I'm in the break down and build back up stage. Example: I'm thinking of investing in a FZJ80 rear axel to gain full float and rear disc. Let me know what you think.
1985 Landcruiser FJ60
1987 Landcruiser FJ60
1987 4Runner 22RE
1992 Landcruiser FJ80
2005 Nissan Titan
2005 Mazda 6 (wife's car)
sicksixty is offline   Reply With Quote
Old 03-28-08, 01:42 PM   #6
jonheld's Avatar
TLCA# 5980
Guys,
There is a lot of slack in a 4WD drivetrain. You're driving a 6000 pound truck with 1 ton running gear. It's gonna make some noise. Simply count up the number of interfaces in the driveline.
FWIW mine has been clunking for the last 190K miles. Keeping the driveshafts properly lubed will help, but it will always have some clunk.
Jon Held
1991 FJ80 "Lumbering White Rhino"
Times Square, New York, USA
TLCA# 5980
http://gclcny.com/jh/
Buy your FJ80 FSM here:
http://gclcny.com/jh/fsm.html
jonheld is offline   Reply With Quote
Libros | Cingular Ringtones | Personal Loans | Pay Day Loans | Credit Cards
