Old 03-27-08, 02:55 AM   #61
I was an owner of a Foers Ibex for 7 years, just sold it earlier this month
I had the vector winch system - and it was great. Ran it with an 8274 and syntheic rope no problems.
One thing to bear in mind, it puts the chassis under tremendous compression loads. The Ibex is way stronger than the equivalent Land Rover it was based upon, but it still needed plenty extra reinforcement.
If your chassis isn't strong enough - good way to shorten your wheelbase
Hope it helps
Andy
moglite is offline   Reply With Quote
Old 03-27-08, 06:22 AM   #62
Walking Eagle's Avatar
Originally Posted by Beowulf View Post
Not to quibble, but the Foers system will do this and much, much more.
-B-
Not quibbling, correcting - I was uniformed, ignorant if you will, truely impressive system
'97 LX450 - locked, Mickey Thompson MTZ 315's, J's, Rancho RS9000XL 14" shocks, RSC remote shock control 3" front drop brackets, 1" body lift, FOR custom front bumper, and a plethoria of rock lights
Owner fabed rotating slider steps, rear bumper / winch and hitch, front and rear extended shock mounts, front spring spacers 1.375", front swaybar drops, rear bumpstop drops, rear swaybar extensions - 'If I can fab it, I won't buy it!'
Walking Eagle is offline   Reply With Quote
Old 03-27-08, 07:26 AM   #63
Overlander 80's Avatar
TLCA# 17132
I was just out in western Colorado driving through some small town and saw a white 80 with a rear winch mount bumper that looks a lot like this one - must have been one of Lukes kits/creations. I need to find the pics I took and compare.
Great bumper~!
Overlander 80 - No Brush Marks
'97/80 ~4" lift - Bull Bar w/Warn 9,500 lb. - 35" MUDS - Sliders - Ext. Diff Breathers - Bulletproof PHH - 20# Co2 w/ built in tool box - Custom Exhaust/Hi-Flow Cats - Flareless - Line X'ed - Rear/Spare/Hilift Unit (7 year W.I.P.)
Overlander 80 is offline   Reply With Quote
Old 03-27-08, 07:47 AM   #64
Whitey
FJBen's Avatar
TLCA# 15530
Originally Posted by Nay View Post
Nope. A 35x10.5x16 (yes, that is 10.5) SSR fits behind the 3rd row perfectly. It stays pressed between the lower hatch and seats, doesn't touch the glass, and the stock cargo tie downs prevent any rolling side to side, leaving room for tool bags, first aid kit, etc. on each side, with the hi lift residing on the floor between the tire and 3rd row. My spare rear driveshaft will sit on top of the hi-lift.
Same visibility issues (minimal) as a tire carrier. No extra weight, no swing out, wrapped that sucker up in plastic so it doesn't stink. Free. Perfect
Pic shows the tire offset, which you could do, but I have it centered now so it will strap down tight.
Not bad, that solution wouldn't work for me tho. We are usually packed to the gills when we go camping/etc and use all the space behind the second rows. Good thinking tho.
93 FJZ80 Slee 4"/OMEJ, 35's, 4.88's, ARB's, Metal Tech sliders, ARB with M12000, On Board Air, caster plates, DC drive shaft, Pin7, CDL, adjustable rear uppers, A, homemade rear, Slee Skid Plate, extended brakelines, backup camera, Conferr Rack, Hella's,
96 FZJ80 285's OME 's ride
FJBen is offline   Reply With Quote
Old 03-27-08, 09:28 AM   #65
Nay
The New Avocado
Nay's Avatar
TLCA# 16030
If I didn't need the third row for kiddos, I'd lay it flat behind the second and build a platform over it. I did this to free my roof rack for camping
1995 FZJ80 - F.O.R. 3.5" lift - 35" trxus MT - 5.29's - Custom SROR Tube Bumpers - De-plasticized - Dented - Dieted
Nay is offline   Reply With Quote
LinkBack to this Thread: http://forum.ih8mud.com/80-series-tech/211835-best-rear-bumper-out-there.html
Posted By For Type Date
New Wheelin Rig - YotaTech Forums This thread Refback 08-25-08 05:00 PM
Babb Fest | Debt | MPAA | Credit | Repair Bad Credit
