o ring fix solved high idle
So I went ahead and tried the o ring fix on my iac valve to cure very high rpm's on startup. It would rev up to 1800+ rpm and slowly drop to normal in about 4 minutes. I had read that the fix works for some, but not for others, and I have an idea why.
I initally tried to remove the valve with the TB still on, but immediately stripped the lower screw. I then sourced two bolts to replace the screws, and removed the TB to get at the stripped screw. A vise grip solved it, and I am glad to have bolts in there instead of soft headed phillips head screws. Anyway, I pulled the valve off and disassembled it per the article here: http://web.archive.org/web/200106271...fast_idle.html I noticed when I put the two o rings on the shaft, and reassembled the valve, that the spring wouldn't seat right on the o rings and would try to push over them. Upon inspection I noticed the spring is supposed to be seated back farther than where the o rings sit in the below picture. ![]() Once I stretched the o rings and seated them where the red arrow shows, the spring sits where it is supposed to and the o rings effectively space the spring out. This has solved my high idle, it now revs to about 1200 for a second, and quickly drops to about 900 for a minute or so, then to around 700. I can now actually get in and drive without waiting for 4 plus minutes for the idle to lessen. The startup rattle is also gone. I think that a lot of people were placing the o rings where the picture in the article shows, instead of further back on the shaft. __________________ 94 LC, 110K, FOR 3" lift, Nitto TG 315's 86 LC, 150K, OME Medium, ARB front, custom rear bumper, Warn 8274, BFG 33" Muds And a silly little VW TDI Jetta Wagon that does 50mpg |
Yo soy El Cucuy
Did that more than 2 years ago. Been working great. I went from 1600-1700 startup RPM down to 1200 at startup with one oring. I tried 2 orings and it went down to something like 700-800 and I wasn't comfortable with that so I went back to 1 oring.
__________________ Alvin 00 XTerra slightly modded-Wifey's 07 AT Horizon Trailer "Turtle"-Ours 94 FZJ80 "Tortuga" +4", 315's, 4:88's, locked, armored and scratched to hell-Mine Copper State Cruisers 13 You're like a breadstick, you got no rhythm I don't know what I don't know, and I won't know what I don't know until I know it! |
Cool. Planning to do this one. O rings taped to my tool box since, um - Fall of '06 or so...
Thanks for the input! DougM __________________ Buy Head Gasket DVD for you OR for your mechanic HERE '93 FZJ since new, 2.2kw starter, Revo 275s, locked, big Hellas, rr fog, rr flood, rr Airlift, synthetics, ARB bullbar. 97 FZJ - exact same stuff but Michelin Alpins in winter "Slicker than owl shit on a wet log." - Carter |
it is a very worthwhile fix in my opinion. The high idle and 4 minute wait until I could put the rig in drive was getting really old. I forgot to mention that the three screws that hold the valve together can be a bugger. They are loc tited in from the factory. Make sure to get a proper sized screwdriver and have the valve in a vise for stability. I still managed to mangle one of the screws, and had to put it back on with a vise grip and a good dab of loc tite.
Yo soy El Cucuy
I recall having some trouble with the screws also. I had to use a hacksaw blade to cut a slot in the head of one so I could use a large flat head screwdriver to remove it.
#6 | |
__________________ '95 FZJ 80 locked, OME 2.5" heavy lift, caster correction drop brackets, stainless steel brake lines, DBA slotted front rotors, odyssey battery, CDL button, scangauge II '93 4x4runner stock (sold) '85 4x4 mini truck/22re stock (sold) '80 4x4 Chevy P.U. Snowplow '86 4x4 MasseyFerguson 1045 |
Unfortunately I don't know the correct size. I stopped at a specialty fastener store, popped open the hood, and took out the top screw. Had the parts guy bring me up two bolts of the same size. The top screw is really easy to get at, so you should be able to match it in size by stopping at a fastener store.
Yo soy El Cucuy
I watched mine this a.m. to refresh my memory.
With one oring, mine starts up at 1200 for a couple seconds, then drops to just a hair under 1000 until its all warmed up. After that, it's sits around 500-600 stopped at a red light in drive. __________________ Alvin 00 XTerra slightly modded-Wifey's 07 AT Horizon Trailer "Turtle"-Ours 94 FZJ80 "Tortuga" +4", 315's, 4:88's, locked, armored and scratched to hell-Mine Copper State Cruisers 13 You're like a breadstick, you got no rhythm I don't know what I don't know, and I won't know what I don't know until I know it! |
Yo soy El Cucuy
I dug up my original thread when I did this mod Sept 05.
Numbers are a little different, but it's working great. Very little startup rattle and not very often anymore. http://forum.ih8mud.com/80-series-te...ing-trick.html __________________ Alvin 00 XTerra slightly modded-Wifey's 07 AT Horizon Trailer "Turtle"-Ours 94 FZJ80 "Tortuga" +4", 315's, 4:88's, locked, armored and scratched to hell-Mine Copper State Cruisers 13 You're like a breadstick, you got no rhythm I don't know what I don't know, and I won't know what I don't know until I know it! |
#10 |
The article states to "Be sure that the three small phillips head screws are secure. A drop of loctite is good insurance. Should one (or more) come loose, it/they can be ingested by engine with catastrophic results." I'm not seeing it. How could these screws get inside the engine? The valve would suck them in?
I'm having this problem and it worried me when I first got my cruiser. I posted up and I was told this high idle is normal as you or the article have also stated. It looks simple enough but the thought of loctite and little screws has me a little nervous. I wonder how much a new ISC would cost? __________________ 94 FZJ80/FJ80 mutt 315 Maxxis Bighorn Quote from Willy T. Payne "I'm f*cking this goat, you just hold the horns." (no goats were actually molested during the making of this comment) |
#11 |
It would seem hard to me for a loose screw to getr sucked in via the small valve hole, and travel the length of the throttle body and into the engine. Might be possible though. Put a drop of red loctite on each screw, and tighten them all down with a good bit of force. As long as they all seat flat and are tight, I don't personally see them going anyhwere.
#12 |
Somebody brought up the question of where do you get these O-rings. Aren't they already on there and you just need to move them?
I read the article again and see that you must get these O-rings and they are not already on there. __________________ 94 FZJ80/FJ80 mutt 315 Maxxis Bighorn Quote from Willy T. Payne "I'm f*cking this goat, you just hold the horns." (no goats were actually molested during the making of this comment) |
#13 |
the article does list the correct size. They are not already on there, and I actually found mine at Home Depot.
#14 | |
__________________ 94 Land Cruiser, 182k, LOVED the almost new brown cloth interior and carpet, new OEM radiator Teal 91 Honda Civic Hatch DX/SI Orig. owner, 160k, lowrd on 17" rims, DD. |
#15 | |
Yo soy El Cucuy
I got one off the shelf at my store (plumbing wholesale). I don't recall the size, but you can get little orings like that pretty much anywhere. __________________ Alvin 00 XTerra slightly modded-Wifey's 07 AT Horizon Trailer "Turtle"-Ours 94 FZJ80 "Tortuga" +4", 315's, 4:88's, locked, armored and scratched to hell-Mine Copper State Cruisers 13 You're like a breadstick, you got no rhythm I don't know what I don't know, and I won't know what I don't know until I know it! |
#16 |
Did mine tonight. One o-ring brought the idle down from 1800 rpm to around 1200 rpm. I tried two o-rings but that brought the idle down to around 500 rpm, which I felt was too low. Perhaps a thin washer and an o-ring would get it back to normal.
__________________ -OK gang, you know the rules, no humping, no licking, no sniffing hineys. 1994 FZJ80 |
#17 |
did mine last night- used 2 o-rings, this morning rpm shot right up to 1800. anyone else had this "fix" not resolve the issue?
#18 |
what year is your 80? And, are you certain you placed the o rings all the way back on the shaft as shown in the picture above?
#19 |
the truck is a 1994- and yep i pushed the o-rings up as specified in this thread- drove it today at lunch and sat in the parking lot 5 minutes while it "warmed up"...
__________________ 1994 LC |
#20 |
I have high start up RPMs but my idle is about 500-600 RPMs after engine is hot. Will the O-rings lower my RPMs after the engine is hot too? I hope not.
#21 |
***Update***
As I mentioned yesterday, I tried one o-ring which made my idle way too low, and two still kept it around 1200rpm for a few minutes. This morning I went and disconnected the battery and then started it. After a few starts, all is normal. Now, with one o-ring, it idles around 1000 rpm and settles down to 650 in short order. Looks like resetting the ECU's memory did the trick.
#22 |
oh well- maybe ill try 3 or 4 o-rings
#24 |
ECU reset worked- FYI
#25 |
well shoot- reset ecu, worked like a charm last night and this morning. tonight when i left work I started up the truck "vvrrrrroooommmm" up to 2000rpms! its like the dang thing reset itself. unplugged the battery and re plugged it in tonight after i got home, let it sit for a few hours and its fine again- does this ecu try to correct itself or something? anyone else had this happen?
#26 |
Mine starts out at about 1800 then quickly to 1600 but when it is warm it runs so great that I hate to screw it up. I am very interested in what you guys come up with here.
__________________ Ron 1978 FJ40 - Restoration project with 58K miles 1994 FZJ80 129K miles Locked with 295 Terra Grapplers and OME heavies 1994 FZJ80 with 43k miles. Tons of Parts for Sale 1983 FJ60 - Rear Locked with SROR sliders Nice Interior (For Sale) 1984 FJ60 - Rustfree Texas Truck Rebuilt Engine with 5K (For Sale) 1984 Harley FLTC |
#27 |
anyone know if the ecu will try to "correct" itself? i hate to have to unplug the battery every day to keep the idle down- by any chance has anyone just replaced the IAC?
