Old 03-11-08, 12:54 PM   #31
SF80's Avatar
Toyota part number for the bulb?
Brian
'95 FZJ80 | Emerald | locked | Slee 4" & BFG AT 315's | Hellroaring Dual Battery | 150 amp-ed | MAF-ed | Scion-ed
'08 BMW 135
SF80 is offline   Reply With Quote
Old 03-11-08, 12:55 PM   #32
177mph's Avatar
Ha! My climate control lights up depending on which airflow button i hit. Feet only - the whole thing is lit. Feet and defrost - the panel goes out. Never did try to figure out why...
Rich
95 Land Cruiser - stock except for damage multiplier
97 Porsche Carrera 4S - not so stock
NJ
177mph is offline   Reply With Quote
Old 03-11-08, 01:26 PM   #33
96r50's Avatar
TLCA# 18726
I had the same problem. Replaced the bulbs and now its all lit up!
Adam
96 LC, OME 851/860, BFG AT 285, Metaltech sliders, IPOR skid, Yellowbox, Landtank seat brackets & MAF, ScangaugeII, Slee harnesses with HIRs & Hella 500s, CDL & Pin 7, George's LEDs, Slee-located washer bottle, 'MUD sticker
OME CC bushings for sale
96r50 is offline   Reply With Quote
Old 03-11-08, 02:41 PM   #34
4x4CPOSEADOG's Avatar
Originally posted by 96r50
I think the only buttons that don't light up are the mirror control and the dimmer knob.
The items above and the rotary diff lock switch don't light up.
Noel
97 LX450 (lockers retro 50%), CDL, Pin 7, HIRs, Cup Holder, 100 pads, George's LEDs, OEM grab bar, sidemarkers, ARB winch bar, PIAA 520, 295/75R16 NTG, Kaymar Deluxe with tire carrier, Slee speedo gear, ARB fridge, silicone PHH/FHH, Xantrex 1750 inverter. Awaiting installation: OEM subtank, OME850J/863, slee SS brake lines, 3* blue bushings/caster plates, BIC 95300B dual batts. ....
94 4Runner, OEM 4.88 gear, V6 3VZE
04 Taco Ext Cab SR5 V6 TRD RR DIFF LOCK, groucho sliders
4x4CPOSEADOG is offline   Reply With Quote
Old 03-12-08, 03:45 PM   #35
The aerial switch did not light on mine (95 LC) when I bought it. I was fine with that until I read this post.
Pulled the dash apart to make sure the bulb was in all the way. No dice. Called local toyota dealer (out of curiosity mainly and did not want to bother CDan). Local guy said it would be like 8 bucks and he had to order it.
Thought about converting to a small LED bulb, but those bulbs were like 6 bucks including shippping.
Went to radio shack and found a two pack of bulbs for under $2 bucks.
Tech:
Carefully removed old bulb from socket, threaded new bulb leads into plastic socket. Trim excess leads as appropriate.
Radio Shack #272-1092
Rated Voltage: 12.0V
Rated Current 60mA
Lamp type 7219
Bulb type T-1
Brightness 0.15MSCP
Average life (hours) 10,000
Most of that means little to me other than 12 Volt.
I used the other bulb in the pack to do my hazard button.
What matters is when I turn on the lights, the antenna and hazard switch lights work and seem to be comparable in brightness to the radio etc.
Now speaking of radio, I noticed some of the buttons there do not light up....Hmmmm.
Hope this helps someone else.
rolnblok is offline   Reply With Quote
Old 03-12-08, 04:05 PM   #36
Rogue's Avatar
Mine was lit in my '94 before I removed it. It's been in the center console now for almost 5 years. Thanks for helping me remember that the antenna used to be powered.
1994 6M1 FZJ80 - "Elsie" - 37th Anniversary Edition
2008 8M6 NHW20 - "Cosmo"
"DEMOCRACY IS TWO WOLVES AND A SHEEP VOTING ON WHAT'S FOR DINNER. LIBERTY IS ONE VERY WELL ARMED SHEEP CONTESTING THAT VOTE."
DON'T TREAD ON ME
Rogue is online now   Reply With Quote
Old 03-12-08, 04:52 PM   #37
On the Golf Course!
Brentbba's Avatar
TLCA# 13420
Yes - I've replaced both bulbs on my '94.
Brent
'94 White LC; Kaymar Rear Bumper w/tire carrier; Hanna Sliders; ARB winch ready Front Bumper; Slee Transfer Case Skid Plate; Revo 285's, OME 850/863 Heavy 2" lift, INTI Rack; Warn M12000 Winch, Snorkel; Sputnik!
TLCA Member #13420; KI6SGO
Brentbba is offline   Reply With Quote
Old 03-12-08, 04:55 PM   #38
jditom's Avatar
You guys got me going again!
My antenna, rear defoger and hazard were all out. So I took them out got the bulbs out and went to my local Toyota dealer to order them.
Hazard and rear defoger were the same except rear defoger had 2 bulbs, one with a white cap. The antenna was different and much smaller.
Will install tonight!
1996 TLC, Cooper D. STT 305/70/16, CDL, 7 PIN, OME steer & 850/863, Bilstein HD, IPA fog. Slee's front bumper, skid plate, CC bushings, SS brake lines x 7, light/aux harness & speedo gear. Warn XD 9000, Hanna sliders. 4X4labs rear bumper. OEM sub tank & overhead console. Projection headlamps, clear lenses, rear tail LED, George's insde LED's. MagnFlow exhaust (cat back). Landtank's MAF, Eclipse Nav. Columbus varient RTT.
2008 GX470, FOR SALE click here!
jditom is offline   Reply With Quote
Old 03-13-08, 09:42 AM   #39
On the Golf Course!
Brentbba's Avatar
TLCA# 13420
I hope you took a good lubricant with you to the dealer when you ordered bulbs there. Cdan's price with shipping was less that two local stealers wanted for the same damn little bulbs!
Brent
Old 03-13-08, 10:11 AM   #40
no bueno
Skillet's Avatar
TLCA# 16078
nope.
1993 FZJ80
1973 FJ40
oh no you didn't (updated)
"...mud is a hotbed of leftist chat/activity." - swank
Skillet is offline   Reply With Quote
Old 03-13-08, 10:17 AM   #41
breathed's Avatar
I hadn't even realized those switches went out until this thread. I need to r&r my valve cover and replace the washer diverter valve so I ordered the bulbs for my "D" light (I guess I'll have to post a retraction on the no "D" club thread), hazard, rear defroster and power antennae switches. There's still more to fix. Maybe one day I'll catch up, but not today.
97 LC 139k, lockers, cup holder, CDL w/ cdan pin 7 mod
NRA Life Member
breathed is offline   Reply With Quote
Old 03-13-08, 10:30 AM   #42
knorrena's Avatar
Wow, think of the luxuries we enjoy: we get to worry about our dash lights whereas a friend of mine with a new Mercedes E Class wont drive to Vancouver because there aren't enough Mercedes dealerships between Calgary and Vancouver.
Karl
1997 LX 450 190000kms, locked, 285 Revos, Supercharged.
You cant kill yourself on a pogostick. (Harry Parker, world famous geostatistician)
knorrena is offline   Reply With Quote
Old 03-13-08, 10:31 AM   #43
no bueno
Skillet's Avatar
TLCA# 16078
lights, shmites.
just buy a set of night vision goggles.
1993 FZJ80
1973 FJ40
Old 03-13-08, 02:32 PM   #44
Atoyot1031's Avatar
TLCA# 18402
Or save some money and wear a headlamp.
Atoyot1031 is offline   Reply With Quote
Old 03-13-08, 03:23 PM   #45
beside La Caja China
PabloVTA's Avatar
TLCA# 15996
this thread isuseless without pics!
LOL
half of my thermostat controls are out, the left side.
all the lights are out in the center of my gauge pod.
but my antenna works and so does the CDT button.... while unlit.
IF I put in new bulbs, can i run 37"s?
hahahahah
Pablo '94 FZJ80 215K 6M1,
Optima Red Top, Bilstien'd, Mobil 1,
DBA DnS front Rotors, 285/75 Revos,
George's LED's, MetalTech Sliders,
Slee Short Bus Front Bumper, OME 850/863
PabloVTA is offline   Reply With Quote
Old 03-28-08, 09:31 AM   #46
Where are my keys?!
treerootCO's Avatar
TLCA# 14133
http://forum.ih8mud.com/80-series-te...hread-80s.html
Type A - 9mm
aka Mike D.----->Bio Page
"Its better to be thought a fool rather than to speak up and remove all doubt." - Lincoln
Workin' on pimpin' the 80...
www.root45.com
www.risingsun4x4club.org
TLCA #14133
treerootCO is offline   Reply With Quote
Tags
led, skillet
Compare | Advertising | Credit Cards | Cheap Gas | Loans
