Old 10-12-08, 12:49 PM   #31 (permalink)
Ebag333's Avatar
TLCA# 18864
Originally Posted by asher z View Post
hey.
im doing a 1" lift by my self. can you tell me what are the bolts mesurments?
thanks.
You can reuse the front and rear factory bolts. I believe that the center three can be reused, but I'm not 100% sure on that as I used the ones that came with the kit.
Be sure to get some strong locktite as you will not be able to double nut them.
'97 LX450
'96 LX450
315 General Grabber AT2, OME Medium, 1" body lift, 30 mm spacers, Pro Comp ES9000 12.5"/14" travel shocks, belly skid plate, grey wire mod.
Jefferson State Cruisers
(A subsiderary of OR/CA TACO)
(Disclaimer: Anything said above is merely my world view. I am not a doctor/lawyer/mechanic/<insert profession here>, nor do I play one on TV. I did not stay at a Holiday Inn Express last night. I take the Hipocritic Oath very seriously.)
Ebag333 is online now   Reply With Quote
Old 10-19-08, 10:19 AM   #32 (permalink)
what about the radiator ?
hey.
i find the right bolts, and finished the job.
your post helped me a lot.
but! the engine is 1" lower now from the body, and the fan is tuching the plastic atached to the radiator. also the fan is not at the center of the radiator. it might efect the cooling system???
any ides?
asher z is offline   Reply With Quote
Old 10-19-08, 11:21 AM   #33 (permalink)
IronYuppy's Avatar
TLCA# 17705
hey.
any ides?
I cut a section out of the bottom of the fan shroud. Just enough that the blades don't hit it.
No cooling issues.
'94 lockered FZJ80
"Fish and plankton and sea-greens and proteins from the sea" - BOX
IronYuppy is offline   Reply With Quote
Old 10-19-08, 01:23 PM   #34 (permalink)
Ebag333's Avatar
TLCA# 18864
any ides?
No cooling issues.
I don't recommend cutting it.
You can do one of two things:
1) Trim the bushings between the radiator mounts (on the side, middle) to drop the radiator approx 1/2". Your radiator won't be perfectly centered on the fan, and you will need to redrill the top mounts (trim the bushings first and then you can see where to drill new holes for the top mounts). This is what I did.
2) Redrill the side mounts (the metal itself) or make new ones (pretty simple). You'll still need to redrill the top mounts unless you make new ones.
Moving the radiator is extremely simple (IMHO easier than cutting the shroud even) and will help maintain the cooling effectiveness of the fan at lower speeds. If you just cut the shroud the fan is extremely off centered, and this will decrease the effectiveness of the fan.
'97 LX450
'96 LX450
Old 07-06-09, 12:24 PM   #35 (permalink)
Ebag333's Avatar
TLCA# 18864
Stumbled across this link while browsing an Aussie forum, and thought I'd share for those considering a body lift.
80's Series Lift
This addresses a 2" lift, but there are some things to watch out for on the 1" lift as well. Useful information either way.
Another link folks may find useful: Outer Limits 4x4 Board :: View topic - Manual 80 Series Body lift
'97 LX450
'96 LX450
LinkBack to this Thread: http://forum.ih8mud.com/80-series-tech/206908-product-review-4crawler-roger-brown-1-body-lift.html
Posted By For Type Date
Korin korotus hdj. - Offipalsta.COM This thread Refback 11-03-09 11:58 AM
