LinkBack (13) Thread Tools Display Modes
Old 12-10-08, 04:07 AM   #121 (permalink)
Resident Newb
p8nt's Avatar
This is what I get for procrastinating. I gather these brackets are long long with no plans on returning?
97 TLC, 176k, Locked, CDL/7pin, 285 MTR, yellow box, ARB, slee headlights, so much more I want.......
01 Honda Civic LX - 42mpg baby!
Originally Posted by ed97fzj80 View Post
Alternatively, God reserves a certain luck for fools, children, and the criminally insane.
WTB: OME 850 & 860 springs!!!!
p8nt is offline   Reply With Quote
Old 12-10-08, 04:36 AM   #122 (permalink)
Photoman's Avatar
I still have some and am trying to keep making them for folks that want to do this upgrade. PM me or use the email in this link if you are interested.
Bill
If it ain't broke, fix it until it is.
97 40th
Photoman is offline   Reply With Quote
Old 02-01-09, 09:35 PM   #123 (permalink)
I finally had a chance to install the bracket and alternator this weekend since I'm not really a football fan. I just wanted to emphasize how great the quality is on Bill's bracket. From fitment to hardware and finish - it's all top notch. The directions were clear and install was straight forward. Thanks Bill.
The most time consuming for me was removal of everything: battery & tray, old alternator and tensioner assy.
In a close second was having the bushing sit flush on the top mount. What worked best for me was a 1/4" brass drift and a 22oz hammer. It really helped removing the oil filter and moving the oil dipstick - it gave me enough room to swing the hammer.
Anybody know if the pulley can be ordered new? I'd like to get a spare alternator and fit the correct pulley to it.
Mark Lachica
1995 Fzj80
Mlachica is offline   Reply With Quote
Old 02-02-09, 02:56 PM   #124 (permalink)
Parts Geek, M1 Mechanic
cruiserdan's Avatar
TLCA# 11332
27411-66040. Current published list price $40.10.
http://i487.photobucket.com/albums/r...Gastrap063.jpg
http://i487.photobucket.com/albums/r...frifles004.jpg
Old 02-27-09, 06:44 PM   #125 (permalink)
bad luck
Dammit...
Sorry, I just need to vent a little.
I bought the 150a alternator from one of the car-parts.com dealers, got it installed and everything was great. Not for long though. Shortly after my voltage started spiking at 16+ volts and dropping down to 12 volts. So I figure I got one with a bad regulator. No big deal - lifetime warranty from the seller. However the only one they have has 140000 miles.
I ordered a replacement from somewhere else in the meantime with 40k miles on it. It arrived today with a cracked plastic case with some jumbled insides - the result of UPS and poor packaging.
I want the 150a in my truck but I'm getting a little frustrated here.
Rant off....
Mark Lachica
1995 Fzj80
Old 02-27-09, 06:50 PM   #126 (permalink)
NLXTACY's Avatar
TLCA# 19015
Dammit...
hate to say it but I've been in your shoes several times now. I have the new 150A alternator but I have NOT put it back on yet even though I've had it for months now. So I feel your pain.
ふざけんなよ!
Old 03-05-09, 07:45 PM   #127 (permalink)
EricE's Avatar
I have problems with my "new" alternator. I am trying to get the pulley off the Alt I just bought off Ebay. While holding the pulley with a pipe wrench I can get the nut to turn but the pulley is spinning on the shaft while the Alt turns. The nut is not loosening. Is there any safe way to stop the Alt from spinning so I can remove the nut?
Edit: I couldn't see a way to get that nut off so I am trying to take the Alternator apart in order to find something to grab onto to keep the shaft from spinning. But I cannot get any further than the attached photo. Any place I pry is causing plastic to flex. I can't see how the rest of it comes apart.
'94 1FZ-FE
200K on chassi, 82K on long block, USA, WA
OME medium springs/shocks; Slee Short Bus Front Bumper; Cabinet drawers in back; CarComputer sound system. York OBA.
EricE is offline   Reply With Quote
Old 03-05-09, 08:45 PM   #128 (permalink)
Photoman's Avatar
A ½” impact wrench works the best. There is just a tin fan behind the pulley which might bend if used to keep the rotor shaft from turning. The pulley has no key so it can rotate on the shaft as you found out.
If you don’t have access to an impact wrench there is a trick you can try. Put a 10mm ¼” drive socket inside a 22mm socket. Stick a ¼” drive extension through the ½” drive socket opening into the 10mm socket. Connect a ¼” drive breaker bar or ratchet to the extension. Use this on the 10mm hex on the end of the rotor shaft to keep it from turning (set to tighten direction). Use a pipe wrench, vise grips, channel locks, whatever to get purchase on the outside of the 22mm socket and turn to loosen. If worse comes to worse you might have to rough up the socket to get a bite on it.
Hope this helps.
Bill
97 40th
Old 03-05-09, 08:48 PM   #129 (permalink)
NLXTACY's Avatar
TLCA# 19015
Both times I just took it to my mechanic and had him do it. He didn't charge me for it even though he's already lost tons of business because I do my own stuff now
ふざけんなよ!
Old 03-25-09, 03:03 PM   #130 (permalink)
Photoman's Avatar
Eric, did you ever get the pulley off and if so how did you do it?
Bill
97 40th
Old 03-25-09, 06:16 PM   #131 (permalink)
lt1fire's Avatar
Am I correct in thinking this is only an upgrade for the 1FZ engines and not a 3FE??
Al
92 fj80: full 6 in slee lift, electric fans, 37" Goodyears, custom sliders, custom front bumper, slee ss extended brake lines, Bud built tie rod/relay rod, XRC 10 winch
Olde North State Cruisers
lt1fire is offline   Reply With Quote
Old 03-25-09, 06:19 PM   #132 (permalink)
96r50's Avatar
TLCA# 18726
Unfortunately so.
Adam - 96 LC
96r50 is online now   Reply With Quote
Old 03-25-09, 08:04 PM   #133 (permalink)
lt1fire's Avatar
Originally Posted by 96r50 View Post
Unfortunately so.
Well I'll just let myself back out of this thread then
Al
Old 03-25-09, 08:55 PM   #134 (permalink)
96r50's Avatar
TLCA# 18726
And stay out of our headgasket threads too
wait...
Adam - 96 LC
Old 09-01-09, 08:14 AM   #135 (permalink)
alaskacruiser's Avatar
Just finished rereading this thread as I'm thinking of tackling this project soon (got a bracket a while ago, just now getting around to it). I'm wondering if anyone has found a smaller-than-stock pulley to increase idle output and make the stock belts fit easier. If so, please post up! CDan- any recommendations on other Toyota pulleys that might fit the bill?
Ex-'93 LC Owner; Now w/ '97 LX, no lockers. Bought 7/02 stock w/35k mi. Now at 113k mi w/ARB bar, OME 850/860, Revo 285s, 150A Alt, SS brake lines, Silicone PHH, Breather Ext, PCV Catchcan, CDL, ScanGauge2, Aux Fan, landtank-fanclutch-mod, Slee Speedo, Mobil 1. Soon: sliders, TJM locker
alaskacruiser is offline   Reply With Quote
Old 09-01-09, 09:23 AM   #136 (permalink)
Corbet's Avatar
TLCA# 15340
I got a bracket a long time ago and have yet to do the mod, however has anyone had any issues to date with their fusable links and the higher output on the upgraded alt? It seems to me that if you had a high enough current draw from something connected directly to the battery like a winch you could create a situation where more power than was origninally designed to flow through the links could cause them to pop. But I don't know at what level the fusable links are supposed to fail?
Rising Sun 4 Wheel Drive Club Member
1976 FJ40, A project with little progress.
1985 FJ60, wife wants me to sell it, you want it?
1997 FZJ80 40th Anniversary, daily driver
Corbet is online now   Reply With Quote
Old 09-01-09, 10:13 AM   #137 (permalink)
cruiserdan's Avatar
TLCA# 11332
I have no idea re a smaller diameter pulley. Toyota does not publish pully dimensions so it would be a very long research project that I do not have the time to spend on. There is more to it than diameter. You also have to deal with center-bore and groove spacing.
It may be possible to chuck it in a lathe and cut it down but it's cast and I don't know if that's possible.
Old 09-01-09, 12:33 PM   #138 (permalink)
concretejungle's Avatar
TLCA# 14646
I upgraded my fusable links when i installed the larger output alternator. No issues so far and we are going on about a year in use.
I have yet to upgrade some of the "other" wires. I can't remember which ones they are, but if you go to the long thread detailing the install of photoman's bracket, it's suggested to upgrade a few of the other wires in order to get the full upgrade effects. I would like to do that when i have time.
95' FZJ80 OME med./J lift, ARB rack, ARB Bull Bar w/tmax 12,500, 35" truxus, Aussie locker-rear, Center Diff Lock, Sliders, IPOR Skid, IPOR rear bumper, upgraded slee sticker, custom dents, more to come. . .
Go 80, or go unsatisfied
concretejungle is offline   Reply With Quote
Old 09-01-09, 02:02 PM   #139 (permalink)
Corbet's Avatar
TLCA# 15340
I've already greatly upgraded the main + cable from the alt to the fusable link as a result of my electrical failure at CM09 this spring. However the fusable links have really prevented me from doing this mod. Mr. T had to choose the size they did for a reason. But, I have not had the time to try to determine that reason. Was it to limit the OEM alt's output or protect other parts of the electrical system? If anyone kows please chime in. I hate chasing electircal gremlins so I'm reluctant to make mods to the OEM system without doing my homework first.
Old 09-02-09, 08:45 AM   #140 (permalink)
Photoman's Avatar
I don't know of any Toyota pulleys but a year or so ago I had considered machining a smaller diameter pulley. It was not so much to aid in the fit of the larger alternator; but to increase the alternator rpm’s at lower engine rpm’s. I made some quick pulley groove angle gauges, did a bunch of measurements, and it can be done. This is all from memory so take it for what it is worth. If I remember correctly, the best way was to reduce the hole size where the flange nut goes in. This leaves more material that can be removed to reduce the pulley diameter. The stock pulley size can be reduced but it is taking away from the thickness that is left at the bottom of the belt grooves. Reducing the flange nut access hole size this way might require using a regular socket to remove the flange nut as opposed to an impact socket. The other thing iirc, is the maximum rpm’s that an alternator is rated at is 18000. So it probably would not be good to exceed this, especially for prolonged periods. At the time I ran some calculations from my measurements and iirc at least a 10 or 20 percent diameter reduction would not be a problem. I have the paper work and a machining drawing I started somewhere. If I find it I will post up some of the figures.
Bill
97 40th
Old 09-02-09, 08:52 AM   #141 (permalink)
Photoman's Avatar
The fusible links and fuses are sized to protect the wires and components in that circuit. There also are unprotected wires on a vehicle. For example the wire from the battery positive to the starter has no fuse so there can always be problems. Fusible links are now mostly outdated and have been replaced with mega fuses. The 2003-2007 Toyota Sequoias where many of the upgrade alternators are coming from use a 140 amp fuse on the alternator circuit. See 2 in picture. In this upgrade it has been recommended that the charging wire from the alternator be increased in size and the fusible link replaced with a mega fuse. This is basically duplicating the Toyota Sequoia alternator “B” terminal to battery positive charging wire. .02 worth.
Bill
97 40th
Old 09-04-09, 12:27 PM   #142 (permalink)
Originally Posted by Ivan80 View Post
I replaced the B+ and the ground to the engine block, along with running a new ground to frame with 2/0 wire.
Ivan80- This may be a dumb question, but I'm working on the wiring upgrade now, and while I changed the ground to the engine block, I can't seem to find where the ground to the frame is. Would you (or someone else) mind describing or preferably posting a pic of this ground wire?
Old 09-23-09, 11:11 PM   #143 (permalink)
superjuice's Avatar
i beleive the frame ground is about one foot of wire connected from the neg. batt. terminal to the drivers side wheel well, right next to the battery. this is what i have seen on my 97' setup. But of course I was wrong once before
1997 FZJ80 2.5"OME, 33" TOYO M/T's, E-Locked, georges LED's, LANDTANK seat mod, 150Alt. mod, group 31x2
1878 FJ40 3" OME, 33" BFG's
1984 FJ60 3" shackle lift, 33" tires, winch, electric hatch, dual yellows,
1987 4RUNNER
superjuice is offline   Reply With Quote
Old 09-23-09, 11:32 PM   #144 (permalink)
superjuice's Avatar
I would just like to thank PHOTOMAN for putting all the time and effort into making this sweet dream a reality. The bracket is amazing as well as the instructions and support. If anyone needs more amps this is the way to go! Thank you sir
1987 4RUNNER
Old 10-14-09, 02:46 PM   #145 (permalink)
96r50's Avatar
TLCA# 18726
Bump for a very nice piece of hardware. Photoman was kind enough to ship me one of these last week and it arrived yesterday. As others before me have said, it is a very nice piece of craftmanship. Thanks Bill!
Now to find an alternator... and some wire... and a fuse...
Adam - 96 LC
Old 10-15-09, 09:56 AM   #146 (permalink)
Aspiring Web Wheeler
TLCA# 4268
I worked with my alternator/starter guy on locating or fabricating a smaller diameter pulley when I accomplished my installation. We came to the conclusion that if we retained the V belts there wouldn't be a significant enough improvement to warrant the time or $$ spent.
If there were a means to replace the V belts with a serpentine or multi-rib belt, the diameter of the alternator pulley can be reduced with significant improvements in output. At one time I did ask Beno to research multi groove pulleys on other Toyota's that would fit the 1FZ. So far I haven't needed it so I never prodded him. I haven't had any issues winching with only one battery.
If someone has the sizes of the original pulleys you can easily determine alternator speed at the web site below.
Pulley And Belt Information Calculator
Use the calculator to determine what speed the alternator will spin at with various diameters. The Sequoia alternator is rated at 18,000 rpm which means there is a safety margin built in. Throw some numbers into the calculator and see how small of a pulley can be installed relative to the engine redline rpm. Bear in mind most people don't drive an 80 series on the rev limiter. I bet you'll find the pulley size that spins the alt to 18k - 20k at redline will be nearly as small as the nut.
1994 80 - Some stuff
1988 4runner - cute little brown thing affectionately known as "sh*t stain"
Those who can, do; those who can't, criticize - Unknown
Strive for perfection in everything.
Take the best that exists and make it better.
If it doesn't exist, create it.
Accept nothing nearly right or good enough.
Sir Henry Royce
Co-founder, Rolls Royce
IBCRUSN is offline   Reply With Quote
LinkBack to this Thread: http://forum.ih8mud.com/80-series-tech/206807-upgrading-stock-alternator-130-150-amp.html
Posted By For Type Date
vmnrao's Bookmarks on Delicious Post #0 Refback 10-27-09 01:23 PM
Bigger Alternator/Generator - Expedition Portal Forum This thread Refback 06-28-09 05:03 PM
Driving Lights Small Motorcycle For Crash Bars, Drivetrain Parts And Specs On 88 K5 Blazers, Driving Lights Small Motorcycle Harley Davidson - Cowboyboots This thread Refback 03-08-09 09:59 AM
Remove Dog Hair From Fabric Car Seats, Remove Dash 1999 Dodge Intrepid, Remove Front Window Motor 2001 Mustang - Savinggas This thread Refback 03-08-09 03:52 AM
Big T the T100 This thread Refback 07-22-08 08:33 AM
Big T gets the Bobb(and much more, new pix) This thread Refback 06-19-08 06:05 PM
Big T gets the Bobb(and much more, new pix) This thread Refback 06-19-08 04:42 PM
ExpeditionLCalternatorupgrade This thread Refback 05-01-08 02:42 PM
OEM 130/150 amp alternator upgrade for the 80. - Expedition Portal Forums This thread Refback 03-12-08 03:05 PM
OEM 130/150 amp alternator upgrade for the 80. - Expedition Portal Forums This thread Refback 03-12-08 02:48 PM
OEM 130/150 amp alternator upgrade for the 80. - Expedition Portal Forums This thread Refback 03-12-08 10:20 AM
OEM 130/150 amp alternator upgrade for the 80. - Expedition Portal Forums This thread Refback 03-12-08 08:47 AM
OEM 130/150 amp alternator upgrade for the 80. - Expedition Portal Forums This thread Refback 03-12-08 07:47 AM
