Old 01-17-08, 04:47 PM   #1
ArmyFJ's Avatar
TLCA# 17652
Brass Spindle Bushing Removal Tool
Well I have removed these before with a Dremel and Cut-off wheel. Very time consuming and unnerving.
I thought about trying to find a bearing puller to get them out and couldn't find anything at the auto parts stores here. So I looked at Harbor Freight. Then I found this little baby for $15.99 3-JAW PILOT BEARING PULLER I was a little worried that it wouldn't be up to the task due to its size butit literally took less than a min for each spindle plus it didn't leave any marring on the spindle. The tool didn't hesitate at all. Too easy.
Here of course are some pics:
Matthew
For Sale: '91 FJ80 - 3FE, CDL 7 Pin Mod, Part Time, 6" Slee Lift, Slee HD Tie Rod and Drag Link, Aussie Locker RR, 37" Toyo M/Ts, ARB Front Bumper, Warn 10K, Ultimate Air
Past Rigs:
'75 FJ40 - 350 TPI, SM465, NP205, High Angle Driveline, Ford 9" w/ Detroit Locker RR, Front Disk Conversion, 4x4 Labs High Steer, 4 inch M.A.F. Lift, 35x12.50 MTRs
ArmyFJ is offline   Reply With Quote
Old 01-17-08, 05:00 PM   #2
motorsargeT's Avatar
TLCA# 16985
Nice setup. I broke down and bought the new style spindles with the roller bearings at my last rebuild so no more bushing swaps for me! wish I had that when I changed them in the past.
Josh Thibeault
1991 FJ-80 OME 850/863, 1" Spacer , 35x12.50 coopers, 5.29s, ARB, Snork, GPS, 12000 lb. winch, Dual Batts, etc.
2002 WRX, not so stock either
2001 Audi TT Quattro, the wifes
Motor Sergeant 119 MP Company (finally out!)
motorsargeT is offline   Reply With Quote
Old 01-17-08, 05:08 PM   #3
Hong Kong Phooey
TOY350's Avatar
TLCA# 4939
Nice find Matt, might have to go pick one up.
How important is the brass bushing replacement? I didn't do mine when I rebuilt the front, it "seemed" fine and wasn't in my rebuild kit from CDan. I might be tearing into the front again to re-gear so I might want to look at these then.
GARETT
67 FJ40
- 350 - SM420 - SOA - ALL PRO HY-STEER - 4.88 - ARB F/R - 30 SPLINE LONGS - 35 MTR's - WARN XD9000
95 FZJ80 - 3 LOCK - LONGS - 4.88 - 285 TOYO's - OME J & L - LANDTANK CC & MAF MOD - ARB/WARN XD9000 - HANNA SLIDERS - 4X4 LABS REAR - SLEE SKIDS & MORE - ECLIPSE NAV - RUBICON TESTED!
JEFFERSON STATE CRUISERS
Originally Posted by cruiserdan View Post
That particular rock is a screaming bitch and if I had my way I would dynamite the sonofabitch and use the left-over pieces to fill up the hole.
TOY350 is offline   Reply With Quote
Old 01-17-08, 05:24 PM   #4
ArmyFJ's Avatar
TLCA# 17652
Well when I did my disk swap on my 40 I needed to replace them because they wouldn't hold the birfield flush. I cut those out with a dremel and replaced them but they were way tight so I honed them out with a brake cylinder hone. (A recommendation I found here in the 40 section).
When I was redoing these I had the same slop and I figured it must have contributed to my passenger side flange destruction.
However, I just replace my drivers side and it still wasn't as tight as I thought it was going to/should be. But when I got out to the flange I noticed that the snap ring was right on the edge of the flange, when I took it off there was a gap maybe 1 to 2 mm or so.
I am thinking that the bushing depth had been worn out through use. However, I also changed the birfields to the longer splines and had new flanges. So I cannot confirm this yet.
I am waiting on a b/o bushing for my passenger side and when it comes in I am going to check its depth against my old one.
Matthew
Past Rigs:
Old 01-17-08, 05:29 PM   #5
Rookie2's Avatar
Do you just tap the new ones in with a mallet or some such?
1997 LX-450, 109k, Stocker.
Shaa laa lalalala live for todayyy... and don't worry bout tomorrow heeeeyy hey eyyy.
Rookie2 is online now   Reply With Quote
Old 01-17-08, 05:46 PM   #6
ArmyFJ's Avatar
TLCA# 17652
I used another Harbor Freight purchase I have had for a little while...Bearing and Seal Driver Set. It rocks. Drivers are made of machined aluminum.
I just coat the bushing with a little grease to let it go in a little easier and tap it down in.
Matthew
Past Rigs:
Mortgages | Car Insurance | Loans | Internet Advertising | Mortgage
