06-10-09, 11:08 AM
#91 (permalink)
OHV Trail Patrol
Or you can donate it to me...
Chad - Cascade Cruisers
KE7VSA - MetalTech
FZJ80 - 37's, lifted, locked, geared, cut and dented.
Originally Posted by bugsnbikes
Dewd- You would bend those spindles if I tucked them into the passenger seat  You are a candidate for a bobbed 80----not a high clearance bumper.
06-10-09, 10:29 PM
#92 (permalink)
I picked up a rear Taco DS and had it re-tubed. After inspecting it and lubing it, it is very smooth and easy to lube compared to the last one. I think this is the way to go had I known more about it when I first needed a DC DS. Total cost was about $300. Now if only I could make up some of that with the old one.
'97 FZJ80 "Blue Ox" - ARB Bullbar, ARB Lockers, OME J's, George's LEDs, Custom Drawer, Kaymar with Tire Carrier, Hanna Quality Sliders, Hellroaring Dual-Batt, 35" Toyo OC, and more!
2000 UZJ100 "Grey Ghost" - Outback Rack, Sliders, 285 Nitto Terra Grapplers, Norcal 80s Sticker
06-10-09, 10:35 PM
#93 (permalink)
Half the original price is a good starting point. Whether you get it or not is up to the MUD classified gods.....
1997 FZJ80 with and without lots of stuff.
2001 Honda Accord 3.0L V6 VTEC Coupe EX.
In and out of focus, time turns elastic.
06-11-09, 10:39 AM
#94 (permalink)
Jasper, I am glad u got ur DC SHAFT. Been reading on NORCAL E-MAILS. I too went to Toy Connection in Santa Clara and sourced an 04 rear Tacoma shaft.GREAT GUYS. Been working great ever since
Robert Muniz
TLCA#15132
1993 Toyota Land Cruiser 217K
3x locked+4.88's+315 BFG AT&MT+SAFARI SNORKEL+SLEE 4"LIFT+TACO FR DC DS+ARB FR+WARN M12000+HANNA RR+SLEE SLIDERS+SLEE SKID+AO DRAWERS+ARB FRIDGE+DUAL OPTIMAS+GARVIN RACK+IPF'S+OKOLE COVERS+HUSKY MATS+POLY REARS+
-LONG INNERS+NF BIRFS
06-22-09, 08:54 AM
#95 (permalink)
is the drive shaft out of a 2 or 4 wheel drive or does it matter?
auto or stick ? 4 or 6 banger?
Im having trubbel finding one .
The guys r telling me that year had a two part shaft, is this bs or not?
1985 4x4 pick up new build.
1991 fj80 4" lift , 35" bfg's KM/2 5.29's.locked. SOLD
1997 LX450 wife's ride ,all stock.
06-22-09, 11:55 AM
#96 (permalink)
ThinkTank Waterboy
for the Tacoma shaft all you are looking for is an extended frame. So either a extended cab or double cab truck. It makes no difference which drive train you have, And the stock shaft is a two part shaft and you only need the rear section.
Rick Bigelow
'96 215k
Groveland MA 01834
06-22-09, 05:14 PM
#97 (permalink)
My local wrecker has a 4 runner shaft for $100 will it work ?
06-22-09, 05:18 PM
#98 (permalink)
What year? See... I mean read post #1 and #2
06-22-09, 06:59 PM
#99 (permalink)
-250 Club
Rick Im pretty sure it also needs to be a 4wd or pre-runner model, the taller suspension requiring the dc shaft. The model i checked on the phone about was a basic crew cab and it did not have the needed shaft, luckily they had a 4wd ext. cab there which had the dc.
06-22-09, 08:14 PM
#100 (permalink)
ThinkTank Waterboy
I've bought about 7 of them so far and only looked for the extended frame. I should check the toyodiy site and see what's up.
Rick Bigelow
'96 215k
Groveland MA 01834
06-22-09, 08:37 PM
#101 (permalink)
It will on the REAR of the cruiser.
The Tacoma shaft needs to be from a 4x4 or prerunner without a doubt.
06-23-09, 06:47 AM
#102 (permalink)
Question for you guys running a DC rear shaft: Any issue with the rear pinion bearing not getting enough lube (without adding another filler higher on the diff)?
Modded '99 for overlanding/exploring: 35's, 4.88's, AO drawers, Slee rr, TJM fr, ARB fr locker, ear candy, Waeco CF-50, PowerGate with 2nd battery with custom home brew battery tray, home brew sliders & Slee belly and skid plates, 9.5XP/Masterpull, Solstice LEDs, OEM 864's, Foxes x 4, 12mm BL, Carl's UCAs, LT285/75R18 GY MT/R Kevlar, KK in tow... HAMified
ROTM: http://forum.ih8mud.com/100-series-c...pressomon.html
09-18-09, 07:47 PM
#103 (permalink)
A friend of mine just suggested that these, offered by Inchworm, might be a possible solution to make using the cv shaft from an earlier mini an affordable option.
Inchworm Gear - Toyota Rockcrawling Equipment
Thoughts? I have an email in to Inchworm to see what they think as well.
09-21-09, 10:28 AM
#104 (permalink)
Well, a little further along now. The non-cv end of the earlier cv front shaft bolts up to the FJ80 diff with no problem. I called Inchworm today to confirm that one of the three flanges offered would fit the front output of the FJ80 t-case - no help there. Apparently, they have no cross reference data on the FJ80??? Guy told me to pull my shaft and measure it.....thanks  . I'll try to get that done tonight unless someone has the bolt patern information on the 80's t-case handy.
09-21-09, 01:34 PM
#105 (permalink)
Addicted to MUD Porn
Just so you know, the "flange" on both the front and rear outputs on the 80 t-case isn't replaceable like mini t-cases are. The flange and shaft are all one piece on 80's.
Jack
KE7NCK
1996 FZJ 80 (explorer)
2002 F350, PSD, 6SPD,4X4,CC, LWB (hauler)
1995 Mazda MX-6 (speedster)
09-21-09, 01:48 PM
#106 (permalink)
Jack
Thanks Jack but if you had followed the link I provided you would have found flange adapters (not adapter flanges).  These do not replace the existing flange. They simply bolt on and the allow two other flange pattern choices to be used.
Granted, it would be preferable to find the appropriate Tacoma driveshaft and have to re-tubed as no adapter would be necessary. Unfortunately, in my part of the world there seem to be no Tacoma candidates in the wrecking yards. The earlier mini-trucks are everywhere and the cv shafts can be had cheap. This, for me, might be a cheaper option than the hard to fnd locally Tacoma shafts when shipping cost is factored in. Just trying to explore some options at this point.
09-21-09, 04:20 PM
#107 (permalink)
does anyone has pics of the "ball" grease fitting...I thought I had this figured out and this weekend while under the truck I could not find a Needle fitting zirk. I have had 2 slee shafts and the one on the truck now was purchased 1 year ago. I know that they both look very different...do all of the Slee ones have the needle zirk??
'96 LX 450 67K locked, ARB Bull Bar, Slee 6", Slee step sliders, Slee rear tire carrier, slee skid, CDL, 315/75-16 MTR's, etc. ROTW
'07 FJ Cruiser locked, 285/70-17 MTR's
Copper State Cruisers #38
TLCA #15560
Rob Clark
