Home Forum Gallery CruiserFAQ Tech Links Store
IH8MUD Forum
Go Back   IH8MUD Forum > Toyota Tech Forums > 80-Series Tech
Follow IH8MUD on Twitter Visit IH8MUD on Facebook
80-Series Tech Tech regarding the 80/81-series Land Cruiser, including the Lexus LX-450 -- FZJ80.com
LinkBack (13) Thread Tools Display Modes
Old 01-07-08, 03:46 AM   13 links from elsewhere to this Post. Click to view. #1
Brian894X4's Avatar
Power window repair w/pics
Like many folks, my driver's side power window stopped working one day. At first it wouldn't go back up at all, then with some help it would. It started out doing this only once and a while. The culprit seemed to be the window runs as everyone talks about.
But then the power window really stopped working to the point that it sounded like the motor gears were turning, but not moving the window, like the motor gears had stripped out.
After pulling it all apart, I couldn't figure out the problem. The motor worked fine and the regulator and external tracks and gears looked just fine.
Then I tore into the motor and found that the internal gearing in the motor had stripped out.
1995 FZJ80, modified for regional expeditions. Click here for more...
My main website:
In Search of History Expeditions
Foreign Toyota 4x4s
Military Toyota 4x4s
Brian894X4 is offline   Reply With Quote
Old 01-07-08, 03:51 AM   #2
Brian894X4's Avatar
The power window system uses all metal gears both externally and internally, except for this one plastic gear, which I assume is plastic to be a controllable failure point without damaging other parts of the system, particularly the window.
After tearing it apart, I found further damage with the motor that preceeded the gearing stripping. This picture shows the motor taken apart, but partly cleaned so you can't see all the rust and crap and was inside the internal gearing mechanism.
What it looked like to me was that somehow water got inside and rusted all the metal parts, causing the c-clip to fail, when caused the gear shaft to become loose. This shaft fits in a rectangular hole which keeps it nice and solid, but the hole became rounded and the gear was now wobling around.
It could also be that wear from normal use caused the rounded hole, which caused the gear shaft to become loose, which allowed water inside, which destroyed the c-clip making it worse and rusting everything out.
I suspect this is the root cause of all 80 series power window failures and almost all 80 series driver's side power window motors look like this to one degree or another.
My main website:
Foreign Toyota 4x4s
Sponsor 01-07-08, 03:54 AM
Sponsored Link
advertisement
Old 01-07-08, 03:54 AM   #3
Brian894X4's Avatar
So, I went about looking for a way to repair it. A new motor is something like $285. I had hoped, against hope, that the rear door window motor would fit as a replacement since I don't roll down the rear driver's window (no seat there).
When I tore into it, I found that the motors were different (no surprise) but not much different. They were indentical, except for different plugs and the motor gear arrangement was simply reversed for some reason. I found that I could in fact swap out the internal gearing mechanism between the two motors.
Here's a picture of the rear door gear motor with the gear mechanism cap popped off. Notice how nice and pristine it is inside? I can only guess this was due to it's lack of use and wear.
My main website:
Foreign Toyota 4x4s
Old 01-07-08, 04:00 AM   #4
Brian894X4's Avatar
So, I basically just popped out the better condition gears from the rear motor and put them into the front window motor and then swapped in the old worn and stripped gears into the rear window motor.
Here's a picture of the front motor with the "new" rear motor gears in place, dust cap read to reinstall.
After swapping gears, the rear motor with the bad gears was reinstalled and the door put back together with the window in the up position. Power to the motor was disconnected, so I don't accidently roll it down and all is good. I never roll down that window anyway, so it's no problem.
The new "rebuilt" motor was reinstalled in the front door and the tracks were readjusted to factory specs. The window runs were thoroughly cleaned and lubed and now the whole thing works perfectly.
I plan to replace the runs as soon as I can order a set from C-dan, since they were probably a major cause of the failure.
However, one major lesson learned here is that the window gear mechanism in all these 80 series windows that are slow or stop working is probably the major culprit. I've read mention of the gear being loose and folks wondering if that was normal. That answer is no, it's not normal at all. The gear should be rock solid. It's loose, because the gear shaft is worn and/or the C-clip has come loose.
The best thing about this fix is that it didn't cost me a dime and my front window works good as new!
My main website:
Foreign Toyota 4x4s
Old 01-07-08, 04:12 AM   #5
flintknapper's Avatar
Just a question....but, did you check with C-Dan to see if the plastic gear is available separately?
'97 Land Cruiser, Moonglow Pearl
Chocolate Lab (Kota), I miss you.
ΜOΛΩΝ ΛΑΒΕ (come and take them)
flintknapper is offline   Reply With Quote
Old 01-07-08, 06:12 AM   #6
mainemike's Avatar
Thanks Brian for a great write up. So you're suggesting by replacing the window runs early (when the slow-role-up symptoms appear) we may prevent the plastic teeth from shearing under the increased resistance?
mike
1996 FZJ80 not-locked, Emu 861/862, ARB up front, Slee sliders and skids, 285 Goodyear Silent Armor, hopefully trying to get off the grid.
www.purplelizard.com
mainemike is offline   Reply With Quote
Old 01-07-08, 07:28 AM   #7
I would get a motor from a Toy vehicle in a junk yard and swap in the good parts to the rear motor.
1972 C2500 long bed, 2005 Odyssey, 2008 Tundra double cab
Idaho
cruiserman is offline   Reply With Quote
Old 01-07-08, 04:21 PM   #8
Brian894X4's Avatar
I haven't checked with C-dan yet to see if that gear is available, but I'd be extremely surprised if it was. The motor doesn't look like it's serviceable and the metal cover has to be pryed off. There's no screws, so I'm betting it's sold as a unit only. What I would need is the plastic gear, the round metal gear guide and the gear shaft as all were worn or destroyed.
I don't recall anyone else posting having stripped the gears, but I would definately replace the runs early based on the threads I've read as they are cheap and easy to replace. If the door is apart, it's not super difficult to pull the motor and track out to at least examine their condition. Most people may not have dug deep enough into why their window quit working to find that the plastic gear stripped out and this might be more common that we realize. Because mine only partly stripped, the motor would still partly work, but made a clicking noise and got hung up when the stripped part of the plastic gear hit the metal worm gear of the motor.
I will eventually permanantly fix the rear window, and junkyard parts are a good suggestion, but like I said, the driver's side rear seat is out of the car as I use that area for storage, so I don't have any need to roll down that window.
My main website:
Foreign Toyota 4x4s
Old 01-07-08, 06:09 PM   #9
Blue Phoenix's Avatar
Garage
Man, great write up and pics.
1997 LX 450- Rebuilt 4.5 @ 178K mi | OME Heavies | BFG KO 285s | DBA 4000 Series Rotors | OEM Lockers | MetalTech Sliders | ARB Onboard Air Compressor | Mule Expedition Rack | Hella 4000s
"I think they overrate sometimes in terms of difficulty, but then again they're in jeeps."
Blue Phoenix is offline   Reply With Quote
Old 01-07-08, 08:41 PM   #10
Rookie
You the man - well done!
Brian B.
Jumpmaster is offline   Reply With Quote
Old 10-01-08, 07:20 AM   #11
YOTAFAN's Avatar
On the same note, doesa nyone know if the rear passenger side motor is identical to the front driver's side?
JOHN
OLDE NORTH STATE CRUISERS
'96 FZJ80 (DD) 850+1"/863, LOCKED, SLEE BUSHINGS, ARB BULLBAR, WARN M12000, 315/75/16 BFG MT KM2, IPOR SKID, SROR SLIDERS, SNORKEL'D, HOMEMADE ROOF RACK, HOMEMADE REAR BUMPER W/ TIRE CARRIER & JERRY CAN HOLDER, SLEE S/S XTEND BRAKE LINES, XTEND DIFF BREATH, CB, HELLA'D
YOTAFAN is offline   Reply With Quote
Old 10-01-08, 09:10 AM   #12
AKcruiserfreak's Avatar
Garage
Cool writeup! Good job.
TK
1971 FJ-40
1985 FJ-60
AKcruiserfreak is offline   Reply With Quote
Old 10-01-08, 12:08 PM   #13
eingeist's Avatar
My motors have always been fine.. But the arms attached to the motor, and the rail that bolts into the door are all bent up practically beyond repair, and the rubber that holds the window is all dry and sticks to the window rather than letting it slide smoothly. Also, the rubber it sits in around the window sill is peeling out, and the sill on the outside of the door is pushed up and snapped the plastic retainers so it rains in the door. But it never seems to get wet.
I need to fix it but I'm not sure about all those little parts...
eingeist is offline   Reply With Quote
Old 10-01-08, 12:09 PM   #14
eingeist's Avatar
No it's not. I tried..
The motors are the same, but the arms and rails are different.
Old 10-13-08, 02:15 PM   #15
still solving problems...
NorCalDoug's Avatar
excellent write up!
a couple pairs of pink panties...
Another convert to the Church of Latter Day Swank, a sub-cult of Shahrislam
"...Opportunity doesn't knock, you have to kick the fuckin door in and drag the bitch out screamin." -- Ullr
"I have more respect for people who change their views after acquiring new information than for those who cling to views they held thirty years ago. The world changes. Ideologues and zealots don't." - Michael Crichton
NorCalDoug is offline   Reply With Quote
Old 10-13-08, 05:54 PM   #16
Clutchee's Avatar
Garage
Might be worth a PM to Nakman & see if he can have the gears re-made.....
Since he has remade the seat plugs & motor gears for the front/back motor he might be able to make these.....
Worth a shot
Great right up.
You can't fix Stupid
---CottonLand Cruisers-----
---White Trash of the Elwood Chapter----
We've been this close to death before, we were just too drunk to know it
Guess the price of being sobers being scared out of your mind
-Drive by Truckers-
Clutchee is offline   Reply With Quote
Old 10-16-08, 07:48 AM   #17
tlcwagons.org
FirstToy's Avatar
i don't have this problem but the windows are slow. do i need to replace the window runs?
nice writeup, good reference
SC'd, Water intercool'd, HQ'd, Slee'd, Norcal80'd
my wip
I drink your milkshake!
Old 10-16-08, 08:53 AM   #18
arndog123's Avatar
My driver side window was really slow especially when powering up. I replaced the run last weekend and problem solved.
Arnold
1997 CE Land Cruiser: 3x Locked, OME lift, 315 Duratracs, ARB w/ M12000
1996 LX450: 3x Locked, OME lift, 315 Duratracs, ARB w/ XD9000
1990 XtraCab 4x4 pickup: ARB w/ M8000
1986 Standard cab 4x4 pickup: 2x Locked, ARB w/ XD9000
1985 SR5 XtraCab 4x4 pickup: ARB w/ M8000
1995 Acura Integra: ARB w/...Just kidding(Daily Driver)
arndog123 is offline   Reply With Quote
Old 12-18-10, 08:37 AM
Sponsored Link
advertisement
MustangWilly
This message has been deleted by woody.
Trackbacks are Off
Pingbacks are Off
LinkBack to this Thread: http://forum.ih8mud.com/80-series-tech/198117-power-window-repair-w-pics.html
Posted By For Type Date
CRAAAAAPPP!, Chit-Chat & Trivia - Rollercoaster.ie This thread Refback 02-05-12 01:14 AM
Offroad 80's • View topic - URGENT Drivers window wont go up!!! This thread Refback 08-16-11 05:30 PM
Offroad 80's • View topic - Power Windows Fix Needed This thread Refback 05-17-11 02:26 PM
repair power window - Web - WebCrawler This thread Refback 04-12-11 05:06 PM
Offroad 80's • View topic - Power Windows Fix Needed This thread Refback 11-08-10 04:16 PM
Offroad 80's • View topic - Power Windows Fix Needed This thread Refback 10-17-10 03:17 AM
Offroad 80's • View topic - Power Windows Fix Needed This thread Refback 09-23-10 07:01 PM
Offroad 80's • View topic - Power Windows Fix Needed This thread Refback 08-27-10 03:46 PM
Tundra Window Motor, Tundra Toyota Motor North America Inc, Tune Up Specifications 1974 Volkswagen Super Beetle - Bmcprinceton This thread Refback 03-07-09 02:17 AM
Replacement Window Switches For 1988 Chevrolet, Replacement Window Review, Replacement Windows For 1995 240Sx - Floridalifestyle This thread Refback 03-06-09 12:37 AM
mbraly's landcruiser Bookmarks on Delicious This thread Refback 03-01-09 09:39 AM
MSN Shopping This thread Refback 02-08-09 11:54 AM
ExpeditionLandCruiserFZJ80 This thread Refback 03-04-08 02:09 PM
vBulletin® ©2000 - 2012, Jelsoft Enterprises Ltd.
©2000-2012 by IH8MUD.com - ALL RIGHTS RESERVED
