Old 07-21-04, 12:18 PM   #1 (permalink)
Wink Transmission Fluid Exchange Writeup
So I finally got around to swapping out the tranny fluid in my '96 80 with the A343F. I bought twenty quarts of Amsoil Universal ATF and called every shop in the area to find one with a transmission powered fluid exchange machine like the one used by Christo and American Toyota. Unfortunately no shop had one of these and most did not even know these things exist. So after much reading I decided to try another approach. I ran the truck to warm up the transmission and then went through all the gears before I simply disconnected the bottom line going to the transmission cooler (near the radiator) and used two pieces of tubing to extend the this line and the male end of the tranny cooler itself. I put both of these tube ends in a clean five gallon bucket and started the engine with the transmission in park. Fluid then flowed quickly out of one of the tubes and into the bucket. As soon as it started to sputter and blow air I shut the engine off and refilled the transmission with approximately the same amount of fluid that was pumped into the bucket. I refilled through the transmission fluid dip stick with a very narrow tipped funnel. I then started the engine again and repeated this process several times until I could visibly see and smell the clean Amsoil flowing into the bucket. In the end the five gallon bucket was almost full (five gallons = twenty quarts) and I had gone through eighteen quarts of Amsoil Universal ATF.
Observations:
I bought the truck used with 70K and now have 90K. I do not know if the transmission fluid was ever changed before but it was extremely clean if it had 90K on it.
Be sure that the hose clamp for the cooler line is seated properly as these tubes sometimes need to heat up to re-create their initial seal.
I've only driven short distances so far but I swear that the truck shifts smoother. In fact I could not even feel the shift into overdrive and had to repeat this shift several times as it was so subtle.
Overall this procedure was very simple and according to my research much better for the tranny than a flush. For those of you without access to a fluid exchanger ala Christo, I would recomend this simple process.
------96-FZJ80 the snowchasing, gear hauling, mountain machine--------
snowcruiser is offline   Reply With Quote
Old 07-21-04, 12:48 PM   #2 (permalink)
20 qts. of Amsoil? That must been hella expensive.
'97 landcruiser: oem lockers, slee sliders, ome med rear and heavy front, speedo correction, arb winch bumper, alpine amp and hu, koda components, 2 12" jl audio subs, tuffduck seat covers, spare tire mod, Engel 43 qt., Milford cargo barrier.
97cruiser is offline   Reply With Quote
Old 07-21-04, 12:55 PM   #3 (permalink)
Expensive...yes. But so is a new tranny and as I said I do not know the history. A tranny crapping out on you 3000 miles from home is expensive...the Amsoil seemed like a deal to me and not as bad as I thought at $5.90 a quart. I just won't be drinking that expensive beer for a while. Cheers
Old 07-21-04, 01:00 PM   #4 (permalink)
Junk's Avatar
Thanks - added it to the FAQ list.
BTW, anyone looking for Amsoil, look around at some of the clubs. There are a few guys that offer dealer pricing to fellow members.
Junk is offline   Reply With Quote
Old 07-21-04, 02:04 PM   #5 (permalink)
Ih8mud stalker
mabrodis's Avatar
Just curious why did you extend both lines? Just so it could drain either way? Or did you not know which way the fluid flows (I don't), just curious.
My dad did this same thing on his Ford van he just drove across the country WAY overloaded. The tranny pan on that has no drainplug, so it was either pull the pan or disconnect a hose, we did the hose and same start/shutoff thing, worked great.
Did you try to shift through any gears while you were spewing fluid and the engine was running? I'd try to get as much as out as possible, but not damage it during the swap, I guess a fine line there.
Good job though!
"The pessimist complains about the wind; the optimist expects it to change; the realist adjusts the sails." -William Arthur Ward
'96 4runner, 3.4L, 5sp, E-locker, 242K miles
'85 Mini, 2nd owner...add-ons: 31" MTRs, oil & dirt stains, 190K miles
'00 Echo, 255K miles, 1.5L of FURY!
mabrodis is offline   Reply With Quote
Old 07-21-04, 03:27 PM   #6 (permalink)
Montana Cruiser's Avatar
What exactly were you asking the tranmission shops when you called them. I recently towed a heavy load cross country and need to replace (not flush) my fluid, but dont think I will have the time to do it myself in the near future. If I can find a shop with the right equipment, then I would have them do it, but I'm not positive what I am asking for. An exchanger that is powered by the transmission itself? Thanks for the input!
2000 4Runner Sport Edition PP 1" Lift Coils / 32" Tires / Norcold / RTT / ARB coming soon!
SOLD! 97' FZJ80 "Junior" Black/ARB winch bar/OEM Lockers
Montana Cruiser is offline   Reply With Quote
Old 07-21-04, 06:10 PM   #7 (permalink)
Mabrodis
You are correct, I disconnected both lines as I was not sure which way it flowed. Its hard to trace the lines over the tranny. I did not shift through any gears while pumping the fluid.
Montana
This is a really, really simple procendure. 45 minutes tops. I would recomend doing the procedure yourself as I was not impressed with any shop I spoke with. If you still insist on going to a shop, I would ask around for one with a fluid exchange machine like Christo's. It uses no external pressure and only relies on the tranny pump to do the exchange. It is basically the same procedure that I have outlined above but the new fluid is sucked in through the second tube instead of added through the dipstick. If you have no luck finding a shop with one of these machines, (I called about 15 places and not one had one), at least find a shop that is familiar with the above procedure. I must emphasize again that you should do this yourself. By the time you call around and drive to and from the shop you will have been able to do this along with a oil, lube, filter.
I forgot to mention that I also removed the metal guard plate held on by four bolts directly behind the radiator. Cheers
Old 07-21-04, 06:48 PM   #8 (permalink)
medtro's Avatar
Which tubing actually pump out ATF? Tubing to the cooler or tranny?
medtro is offline   Reply With Quote
Old 07-21-04, 08:17 PM   #9 (permalink)
The fluid came out of the tubing that ran to the cooler from the tranny, but aim both hoses at the bucket just in case.
Old 07-21-04, 08:37 PM   #10 (permalink)
Uber Lurker
wingnutter's Avatar
couldn't you have done this with your method? Once you figured out which was the drain hose, couldn't you have had the other suck up the new fluid?
'94 FZJ80 - locked, lifted, snorkeled
'83 FJ60 - "What's with the bricks"
wingnutter is offline   Reply With Quote
Old 07-21-04, 08:41 PM   #11 (permalink)
TLCA# 4268
Shortly after I purchased my '94 I asked a friend that operates a repair shop to give me a flush quote. His normal price for a tranny flush for trucks and SUV's is $150. I asked about using full syn and he mentioned that if you replace the fluid every 50k there isn't really any reason for it.
Something to consider is that shops make their $$ on parts/supplies. That being said most are not open to customers bringing in their own fluid. Try a tranny overhaul shop, one that has old crusty wrenches working there. They are usually more open and more informative that the kids at Aamco.
cheers
Kris
1994 80 - Some stuff
1988 4runner - cute little brown thing affectionately known as "sh*t stain"
Those who can, do; those who can't, criticize - Unknown
Strive for perfection in everything.
Take the best that exists and make it better.
If it doesn't exist, create it.
Accept nothing nearly right or good enough.
Sir Henry Royce
Co-founder, Rolls Royce
IBCRUSN is offline   Reply With Quote
Old 07-21-04, 08:44 PM   #12 (permalink)
Probably...but I went with the fill tube/dip stick to be sure.
Old 07-21-04, 10:34 PM   #13 (permalink)
Mabrodis
Montana
SnowCruiser - 45 minutes doesnt sound bad at all, I was initially thinking that it would be more involved then that. I'll have to crawl up under there and see if I can identify the tubes that need to be disconnected, and I am sure I can consult my FSM right? By the way, how did you dispose of the old fluid? There is sure alot of it.
Old 07-22-04, 09:23 AM   #14 (permalink)
There have been many post on bobistheoilguy.com about using this method of draining. As someone suggested, you get a second five gallon pail and draw fresh fluid in throught the one hose while the other pumps it out. Just keep and eye to make sure that you don't run the pail dry of fail to pump new oil in (if it stops comming out the one hose you need to stop and figure out why.
Cary
You know your life is screwed up when you are getting divorced, fighting over custody, watching all of your money getting pissed away, being treated by her and her family as the anti-christ, and yet, finding your life has drastically improved.
cary is offline   Reply With Quote
Old 07-22-04, 10:46 AM   #15 (permalink)
Rookie2's Avatar
A picture indicating which tube draws the fluid and which discharges it would be very helpful ::.
Thanks for the info. Sounds doable.
Rookie2
1997 LX-450, Basically stock.
Rookie2 is offline   Reply With Quote
Old 07-22-04, 10:56 AM   #16 (permalink)
Photoman's Avatar
I had always thought the trans fluid was pumped through the cooler with no suction. The pump picks up fluid through the filter/screen in the pan.
FWIW, when I did mine I would just run the motor for maybe 10 seconds, then add more fluid. This way the pump was never run dry. From heavy equipment it was never a good idea to run a hydraulic pump dry (even for a short time) or to have the pump cavitate by having a low fluid level or running on a steep grade.
Bill
If it ain't broke, fix it until it is.
97 40th
Photoman is offline   Reply With Quote
Old 07-22-04, 11:15 AM   #17 (permalink)
Rainy Day FZJ's Avatar
Talking ATF line removal
I have performed this exact replacement 5 months ago. The line that you need to remove is the upper rubber line comming off of the cooler, you need a pair of plyers to remove the OEM hose clamp off of the cooler, but you first remove the grill, phyllips screw driver to remove the front grill. You don't even half to crawl under the rig to ID the exact line, a longer 3/4 hose is needed to "extend" the upper hose to the 5 gallon bucket, it will be a loose fit but just keep it pointed twards the bucket and have your helper sit in the drivers seat and start and stop the vehicle on your command. I used the dipstick tube for the refill, I think that the fluid gets pushed thru the cooler as apposed to sucked thru. Use caution for the refill process, the vents for the trans are attached to the tube and could leak on the floor causing you to actually crawl under your rig for this. I just made sure that there wasn't 3 quarts in the funnel pushing down the tube, 1 at a time. If this doesn't make sense let me know, it is as easier than changing the engine oil.
95 FZJ80 -sold
2004 Dodge 2500 Cummins tow rig
1997 BMW M3 sedan
2005 21' Rampage toy hauler to carry the Honda ATV's
Rainy Day FZJ is offline   Reply With Quote
Old 07-22-04, 11:28 AM   #18 (permalink)
You want to do what...?
e9999's Avatar
Does this trans-own-pump-push-out-old-fluid procedure result in minimal mixing of old and new fluid, or is each new quart simply mixed up with whatever is in there still?
Perhaps IOW, can you see a sharp change in color when it comes out at some point or is this very gradual?
thx
E
: '97: 90K, 3xlock, 285 MT/Rs on steelies, Hanna sliders, 851+1.5"/863/N73/N74E/SD24, ARB bull with M12, Kaymar with duals, Kaymar rack, Slee TC skid, 2m/440, more stuff, loose nut behind the wheel!). Custom HD roo bar for sale!
: '03: 115K
DDs: Accord, Prius
: souped-up DR650
Old 07-22-04, 11:30 AM   #19 (permalink)
Rookie2's Avatar
This part confused me. Are you talking about the tranny and transfer case breather tubes that are attached to the tranny dipstick/fill tube? If so, why would fluid spill out of the breather tubes?
Thanks,
Rookie2
Old 07-22-04, 12:17 PM   #20 (permalink)
It is a 2 part dipstick tube and if the middle seal is of questionable nature like mine was it will leak from that area a small amount. I could not tell if it was the breather tube connections or the o-ring it self.
95 FZJ80 -sold
1997 BMW M3 sedan
Old 07-22-04, 12:41 PM   #21 (permalink)
concretejungle's Avatar
TLCA# 14646
if someone could post a few pics, that would be grrrrrrrrrreat!
95' FZJ80 OME med./J lift, ARB rack, ARB Bull Bar w/tmax 12,500, 35" truxus, Aussie locker-rear, Center Diff Lock, Sliders, IPOR Skid, IPOR rear bumper, upgraded slee sticker, custom dents, more to come. . .
Go 80, or go unsatisfied
concretejungle is offline   Reply With Quote
Old 07-22-04, 12:54 PM   #22 (permalink)
Rookie2's Avatar
We've beat the engine oil thing to death, but haven't seemed to touch much on the ATF's. What are some quality non-sythetic products. Just want to weigh options since the $120 Amsoil exchange kind hits you in the anus.
Rookie2
Old 07-22-04, 02:16 PM   #23 (permalink)
Any Major brand Dextron III ATF is fine if you don't want to use Synthetic. Personally, I would just do the drain and refill procedure a couple of times with Synth, and then do the service every 15,000 miles. Then you are only out $40 per pop. FYI, I prefer Redline D4 ATF for trannies over Mobil. Mobil in the Motor, Redline everywhere else.
Old 07-22-04, 03:32 PM   #24 (permalink)
Supporting Vendor
sleeoffroad's Avatar
Mabrodis
Small correction here, the machine does have a pump to pump in the new fluid, however it is low pressure to equal the pressure of the fluid comming out. So you balance the outflow and the inflow so that the tranny never runs dray.
If you were asking shops, they probably call it flush machines. If you asked for a fluid exchange they would not know what you are talking about.
Christo Slee
www.sleeoffroad.com
sleeoffroad is offline   Reply With Quote
Old 07-22-04, 06:27 PM   #25 (permalink)
landtoy80's Avatar
Will changing to syn on a high milage trany cause any problems?
The fluid has been changed at least 3 times in its life.
kurt
94 FZJ80 316,000 mi
landtoy80 is offline   Reply With Quote
Old 07-22-04, 07:35 PM   #26 (permalink)
Damn
johnny4ever's Avatar
AT Oil flow to and from A440F
This is how the oil flows in an FJ62 up to 1990 so it will be similar to early FJ80.
The designation of the tranny is A440F. Someone tell me how many years the 3FE was used in the 80 series?
01001010 00110100 01000101 00100000
00110001 00111001 00111001 00110111 00100000 01000110 01011010 01001010 00111000 00110000 00100000
____________________________________________
johnny4ever is offline   Reply With Quote
Old 07-22-04, 07:36 PM   #27 (permalink)
Damn
oops HERE is the link to the Diagram.
http://forum.ih8mud.com/60-series-wagons/18878-oil-cooler-diagram.html
Old 07-22-04, 07:42 PM   #28 (permalink)
Damn
To explain: You can see that the forward most port is the outflow to radiator.
The rear most is the return. Seems like it would be easiest to tap in to the lines near the tranny pan.
Old 07-22-04, 09:13 PM   #29 (permalink)
Rookie2's Avatar
This flow direction seems opposite of what I would've expected from Rainy D's explaination. If you pull the top hose and fluid flows out, that would be the supply hose instead of the return. What am I missing here??
Rookie2
Old 07-22-04, 09:48 PM   #30 (permalink)
ppc
ppc's Avatar
I would guess residual oil remaining in the line draining as the result of gravity.
Phil
Supercharged 94
ppc is offline   Reply With Quote
