Old 05-21-03, 02:50 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Rogue's Avatar
Spare Tire Lift???
I currently have my spare in the truck and have removed the spare carrier from under the truck. I need all the space I can get for an upcoming move. If this will work I will likely leave it as a permanent arrangement until I can afford a new rear bumper.
So the question is, will it work?
Rogue is offline   Reply With Quote
Old 05-21-03, 03:10 PM   #2 (permalink)
The quick brown fox .....
Beowulf's Avatar
Re: Spare Tire Lift???
Rogue,
That should work OK for tyre diameters up to 33". Not sure about larger. John Holmaas did something similar and posted pics. There is a lot of verticle room under the cargo floor.
Let me know and I'll try to dig up links to his mods.
-B-
Old 05-21-03, 03:15 PM   #3 (permalink)
ThinkTank Waterboy
landtank's Avatar
Well I'm completely lost here. Why don't you just reinstall the tire carrier?
Old 05-21-03, 03:18 PM   #4 (permalink)
Beowulf's Avatar
Rick,
Rogue removed the carrier from under the truck and he puts his spare in the cargo area for clearance when wheeling. Now he needs the cargo space for a move. His plans are to put it back under the truck but also to improve clearance by raising the spare the maximum amount.
-B-
Old 05-21-03, 03:41 PM   #5 (permalink)
Rogue's Avatar
Beo,
I think I have devised a way to raise the tire sufficiently. It looks as though it must go at least 4" and no more than around 5" up. What I worry about is how high the tire lowering doohicky will be once I relocate it. Any pictures of Holmaas' setup would likely help immensely. I already searched lcool and couldn't find anything there. Thanks.
Old 05-21-03, 08:19 PM   #6 (permalink)
Beowulf's Avatar
Rogue,
Not much help but this is the only image I have.
-B-
Old 05-21-03, 10:57 PM   #7 (permalink)
Rogue's Avatar
That is perfect Beo. Tonight when I realized the amount of work need to fab up the brackets I imagined something like this. Now I just need to figure out exactly how high I can go with it.
Thanks!!!
Old 05-22-03, 03:04 AM   #8 (permalink)
ThinkTank Waterboy
landtank's Avatar
If you go with the idea that Holmas did you might consider using cast iron pipe instead of the nuts. The pipe would probably install easier and can be cut to odd lengths as well.
Old 05-22-03, 09:15 AM   #9 (permalink)
Rogue's Avatar
I already have the nuts (I hope Junk doesn't read this). Yesterday I tried stacking 8 high and it was just a little too high to reach the lowering thingy. Today I will be trying 6. BTW the nuts are about 3/8" thick each so this should provide an adequate lift.
Old 05-22-03, 01:38 PM   #10 (permalink)
Junk's Avatar
No comment on the # of nuts Rogue 0 but yeah dude the pipe would be mucho easier. Of course if you had Christo's bumper you wouldn't need to worry 'bout it. I don't think that with Holmaas's design you need to worry about the lowering mechanism at all. Should still be reachable.
Junk is offline   Reply With Quote
Old 05-22-03, 05:57 PM   #11 (permalink)
Rogue's Avatar
It ended up looking just like the picture of Holmaas' setup. The bottom of the tire is at the same level as the recently re-installed reciever.
Junk,
I'd really like one of Christo's rear bumpers, but I am a bit short on cash and have bad credit. Want to give me some cash? :tear:
Old 05-22-03, 06:47 PM   #12 (permalink)
I would like to mimic this setup as it would be nice to have the extra clearance all the time. When you complete it, can you please post the lenght of bolts, thread, and number of nuts you ended up using? Also, if you can say if it created any rattles. I looked under the truck when I bought it because I couldn't believe it hung that low, and for the life of me cannot figure out why toyota put it down there (I am guessing crash performance).
cary is offline   Reply With Quote
Old 03-30-04, 01:17 PM   #13 (permalink)
Junk's Avatar
Re:Spare Tire Lift???
Hey Pimp,
How about adding a pic or two of your mod so this can be added to the FAQ's? I'm putting you to work dude
Old 03-30-04, 01:29 PM   #14 (permalink)
tucker74's Avatar
Spare Tire Lift???
Hey Junk,
Here's a pic Rogue had posted of his lifted in another thread -
Tucker
tucker74 is offline   Reply With Quote
Old 03-30-04, 01:42 PM   #15 (permalink)
sjpitts's Avatar
Spare Tire Lift???
This looks like a good and easy idea.
But I have a question. When you do this mod, can you still lower the tire with the handcrank in the original fashion?
Are there any downsides to this mod? Does it work with 285/75 tires?
Jared
sjpitts is offline   Reply With Quote
Old 03-30-04, 01:52 PM   #16 (permalink)
tucker74's Avatar
Spare Tire Lift???
Jared,
You can still lower the tire as long as you don't go to high w/ the spacers - several members have actually modified the mechanism to go even higher. If I remember right you can go up to a 315/75R16 with this method. Anything bigger than that has to go somewhere else .
Tucker
Old 03-30-04, 01:56 PM   #17 (permalink)
MoJ
MoJ's Avatar
TLCA# 14112
Spare Tire Lift???
[quote author=sjpitts link=board=2;threadid=1921;start=msg129631#msg1296 31 date=1080679374]
Jared
[/quote]
1. Works with handcrank as long as you don't try to raise it too high, you'll see what I mean when you do the mod.
2. No downsides that I've found.
3. Yes, works with 285/75 as well as 305/70
MoJ is offline   Reply With Quote
Old 03-30-04, 01:58 PM   #18 (permalink)
Junk's Avatar
Kurt - I deleted your post since this is going in the faqs.
Old 03-30-04, 02:02 PM   #19 (permalink)
landtoy80's Avatar
Junk, your just MAD becouse you didn't think of it first.
landtoy80 is offline   Reply With Quote
Old 03-30-04, 02:38 PM   #20 (permalink)
Rogue's Avatar
Spare Tire Lift???
[quote author=tucker74 link=board=2;threadid=1921;start=msg129615#msg1296 15 date=1080678571]
[/quote]
As you can see in the picture, the hardware is rusting and it is getting worse pretty quick. I think I will be looking for another way this summer.
Old 03-30-04, 03:37 PM   #21 (permalink)
Safado's Avatar
TLCA# 14038
Spare Tire Lift???
I think TANK had the right idea with the cast iron pipe...kinda like one of those DIY body lift kits. Stick a fat washer up on top and run the bolt through.
Safado is offline   Reply With Quote
Old 03-30-04, 04:07 PM   #22 (permalink)
TLCA# 16520
I think stainless hardear and some aluminum sleeving would be ideal and solve the rust issue. otherwise mount it where you want and douse it in undercoating. just make sure you like it there prior to shooting as your threads will be shot.
Dave
PHAEDRUS is offline   Reply With Quote
Old 03-30-04, 04:10 PM   #23 (permalink)
sjpitts's Avatar
Spare Tire Lift???
Can't you just use galvanized bolts and nuts to stop the rust problem? Or is it zinc coated?
Jared
Old 03-31-04, 06:47 AM   #24 (permalink)
MoJ
MoJ's Avatar
TLCA# 14112
I've done that mod. Drug the spare tire pretty hard last night doing some light after work wheeling. The longer bolts and nuts I'm using for spacers held up well.
Old 03-31-04, 09:11 AM   #25 (permalink)
Merchant of Death
Landpimp's Avatar
TLCA# 5506
Sorry, this is the 1st time I read the thread. Dont know where my pics are. But I think I used 3 or 4 nuts(3/4"?) on each, raised it up as high as I could before I couldn't use the hand crank to get the tire down.
John H
[quote author=Junk link=board=2;threadid=1921;start=msg129604#msg1296 04 date=1080677861]
Hey Pimp,
[/quote]
Landpimp is offline   Reply With Quote
Old 04-01-04, 10:18 PM   #26 (permalink)
Riley's Avatar
Spare Tire Lift???
Does the spare tire crank suck for everyone?
I did this mod in the first few months of ownership and had never lowered the spare much beforehand (probably only once ) ..... but I find the crank thing really sucks. As I think ahead to running 2 sets of tires, I cringe everytime I think about changing the spare. The 4 wheels are easy compared to the spare
Any suggestions to getting the crank held in place?
Riley
Riley is offline   Reply With Quote
Old 03-13-07, 09:18 AM   #27 (permalink)
stevezero's Avatar
I used 2 1/2 inch x 1/2 inch cast iron pipe nipples with 90mm bolts to raise mine. I used 2 inch x 1/2 inch cast iron pipe nipples with 80mm bolts to lower the crank(the hardware store didnt have any more 90mm bolts). Home Depot and Lowes only went up to 60mm bolts.
You wont be able to go up over 2 1/2 inches. The rear part of the tire hits a brace in the back near the bumper. It does tuck the front up quite a bit though.
97 LX-450, 119k, Dual Batteries, Pin7/CDL mod, Slee harness/HIR's, LED's inside, no factory roof rack, some other homebrew mods, Airlift helper bags, and 285/75/16 geolander II's.
stevezero is offline   Reply With Quote
Old 03-13-07, 10:43 AM   #28 (permalink)
syrinxstar's Avatar
Thanks for dragging this up Steve - it's been on my list for a long time. How many of each length pipe do you need for this?
Mike
96 LX450, OME 861/862
San Diego, CA
syrinxstar is offline   Reply With Quote
Old 03-13-07, 11:14 AM   #29 (permalink)
stevezero's Avatar
6 for the bracket , 4 for the spare winch.
bolts will all be 8mm x 1.25mm x length
They did have the pipe nipples at Lowes.
Be prepared for a lot of crap to fall down from the bracket. It accumulates alot of dirt over the years.
Old 04-13-07, 10:23 AM   #30 (permalink)
Lugboot's Avatar
TLCA# 17677
Any newer pics of this to add to this thread? I either see nothing or the infamous red X.
Lugboot is offline   Reply With Quote
LinkBack to this Thread: http://forum.ih8mud.com/80-series-tech/1895-spare-tire-lift.html
Posted By For Type Date
Spare tire room This thread Refback 03-16-09 01:56 AM
