11-02-07, 06:28 PM
Trouble pulling codes. realtime help appreciated
I have a 95 fzj80. I've been getting a CEL for the last 1000 miles or so. It comes up and I clear it and about 200 miles later it comes up again. So I decided to try and pull the codes. I'm pretty sure that I have an OBD1 equiped truck cause my OBD2 scanner doesn't fit on the diagnostics port.
So I jumpered the E1 and TE1 and nothing happens (I've done this many times before on my 89 mini so I know what to look for). The problem is nothing happens. The CEL does not flash it only stays on.
I'm at a bit of a loss as to what to do.
95 FZJ80, lifted, locked and rockin the driveway.
11-02-07, 06:30 PM
Pretty sure from 1995-1997 is OBDII. Others will confirm. My 1994 is OBDI and I can pull the codes with the jumper technique.
Sorry not much more help than that.
Robert Callaway
'03 LX470 52k mi. - The Smooth Ride
'94 FZJ80 212k mi. - Locked, OME 861/862, less the OE roof rack, add a D31M
'85 FJ60 - Sold
11-02-07, 06:33 PM
Some 95s were OBD1 and others OBD2.
11-02-07, 06:40 PM
Robert Callaway
'85 FJ60 - Sold
11-02-07, 07:03 PM
Aah now I get it. Problem solved! Thanks.
11-02-07, 09:05 PM
Sharesies!?
What was the deal?
11-02-07, 10:47 PM
my truck is OBD2
11-02-07, 11:11 PM
So where did the scanner plug in, since you said you couldn't figure that out?
Curtis
91FJ80, OBDI (OBDII ignorant...)
11-02-07, 11:20 PM
Fuse box in cab.
07-20-08, 07:18 PM
#10 (permalink)
I have a 94 too, What's the jumper technique you guys are talking about because I'm getting really frustrated with the CEL on my dash every 50 miles, I just replaced the O2 sensors last week with two brand new Walker Sensors but the light keeps appearing. I want to check for the codes but I have no clue how.
If you guys that knows this technique can give me some pointers and let me know what tools I need to do it I'll sure appreciate it!
 Toyota Rocks!!!
Exercising my Second Amendment Right Every Single Day!!!!
07-20-08, 07:56 PM
#11 (permalink)
livin a poor college life
I can't believe this technique isn't in the FAQ...
1. With the key OFF, jump the E1 and TE1 terminals in the underhood diagnostics box with a paperclip.
2. Turn the key to the ON position, do NOT start the engine.
3. Count how many times the CEL blinks, I.E. code 25 would be two flashes, a pause, then five flashes, repeat. If there is more than one code, there will be a longer pause between codes.
4. To clear the codes, remove the EFI fuse for 15 minutes, then replace it.
Lane Anderson
'91 TRD FJ80 "Katie" - 265k, 3FE, 3H4, 860+1/850J+1, locked, 33's, Taco rims, custom front bumper, custom roof rack, LineX'd, Dual batts, CB, HIRs, OBA, GPS, aux lights, aux fan, desmogged, pintle hitch, ROTF
'63 VW Type 1 - 43k, 1600cc, Anthracite, 100% restored, Blog
'04 Crate 4-string bass, Ernie Ball Slinks, stock
"VWs and Cruisers... How can you go wrong?!?" -CreeperSleeper
07-20-08, 08:01 PM
#12 (permalink)
Awesome, thanks so much, you have been the only one with a straight answer to this technique. I just did it and it reads code 71. Do you know what this code means??
 Toyota Rocks!!!
07-20-08, 08:10 PM
#13 (permalink)
EGR malfunction.
Here's the site I use: Album: 80 trouble codes
You're welcome
Lane Anderson
07-20-08, 08:15 PM
#14 (permalink)
Lane, Thanks so much man, I appreciate your help. Sorry for asking so many questions, I'm kinda green but I'm learning fast. Once again thanks for you help, you save the day man! I was so worry that the O2 sensors were bad being that I replaced them last week, I don't know anything about the EGR but I'm glad it wasn't the O2 sensors.
Now I'm gonna have to look into what to fix and how, because to tell you the truth I don't even know where the EGR is located in my 80, LOL.
Thanks bro, thanks for your help!
 Toyota Rocks!!!
07-20-08, 08:27 PM
#15 (permalink)
Any time.
Lane Anderson
08-19-09, 08:53 PM
#16 (permalink)
the link doesn't work anymore. Anybody know any other links to CEL codes? Thanks in advance!
edit: just tried to go directly to birfield.com and got "site under construction". Hopefully be back on later.
88 fj62 w 209k
94 80series 167k
09-01-09, 07:17 AM
#17 (permalink)
-As-
Interesting. I had that codes link bookmarked and I need it this morning and then come here to find it on mud and find your post. it's got to be on here somewhere... I'll keep digging, but someone care to share a link?
Eric Hagan - Auburn, AL
94 - Scallywag (noun) a deceitful and unreliable scoundrel
09-01-09, 08:48 AM
#18 (permalink)
Search here on mud. There is tons and tons of threads RE EGR troubleshooting and removal if you wanted to take that route.
My EGR isssue was a broken EGR modulator. Picked up a new one from CDan and have been CEL clear for 4k miles.
GL
09-01-09, 09:00 AM
#19 (permalink)
On the Golf Course!
Code 22 (opps 21 per Land Speeder below) and 28 are the O2 sensors. Code 26 is rich fuel mixture. All I can remember.
Brent
'94 White LC; Kaymar Rear Bumper w/tire carrier; Hanna Sliders; ARB winch ready Front Bumper; Slee Transfer Case Skid Plate; BFG MT KM2 285's, OME 850/863 Heavy 2" lift, INTI Rack; Warn M12000 Winch, Snorkel; Sputnik!
TLCA Member #13420; KI6SGO
09-01-09, 09:08 AM
#20 (permalink)
-As-
Trouble Codes
OBD1 Codes
1 Normal Condition.
2 Air Flow Meter signal.
3 Ignition signal.
4 Engine Coolant Temperature Sensor signal.
5 Oxygen Sensor.
6 RPM signal (Crank Angle Pulse).
7 Throttle Position Sensor signal.
8 Intake Air Temperature Sensor signal.
9 Vehicle Speed Sensor signal.
10 Starter signal.
11 Switch signal.
11 ECU/ECM.
12 Knock Control Sensor signal.
12 RPM signal.
13 Knock Control CPU (ECM).
13 RPM signal.
14 Turbocharger Pressure.
14 Ignition signal.
21 Oxygen Sensor.
22 Engine Coolant Temperature Sensor signal.
23 Intake Air Temperature Sensor signal.
24 Intake Air Temperature Sensor signal.
25 Air-Fuel Ratio Lean.
26 Air-Fuel Ratio Rich.
27 Sub Oxygen Sensor signal.
28 No. 2 Oxygen Sensor signal.
31 Air Flow Meter signal (Vacuum Sensor signal).
32 Air Flow Meter signal.
34 Turbocharger Pressure signal.
35 Turbocharger Pressure Sensor signal.
35 HAC Sensor signal.
41 Throttle Position Sensor signal.
42 Vehicle Speed Sensor signal.
43 Starter signal.
51 Switch signal.
52 Knock Sensor signal.
53 Knock Sensor signal.
54 Inter-cooler ECM signal.
71 EGR System.
72 Fuel Cut Solenoid signal.
78 Fuel Pump Control signal.
81 TCM Communication.
83 TCM Communication.
84 TCM Communication.
85 TCM Communication.
09-01-09, 01:35 PM
#21 (permalink)
Since we're doing this, may as well add the image of the Check Connector (from a 1991):
To obtain an output of diagnostic codes, proceed as follow:
1. Initial conditions
(a) Battery voltage 11 volts or more
(b) Throttle valve fully closed (throttle position sensor
IDL points closed)
(c) Transmission in neutral position
(d) Accessories switched OFF
(e) Engine at normal operating temperature
2. Turn the ignition switch to ON. Do not start the engine.
3. Using SST, connect terminals TE1 and E1 of the check connector.
SST 09843–18020 (Or, you could use a paper clip)
4. Read the diagnostic code as indicated by the number of
flashes of the ”CHECK” engine warning light.
1991 FJ80
2.5" Medium lift, .50" spacers in front (still uneven) 33's on black steel, snorkel, de-smogged and some other stuff.
2005 Sequoia 2wd (for the wife & kids).
66 FJ40 (Sold on MUD!)
3F-E De-Smog Thread
Originally Posted by Tofudebeest
We would get along like peas and carrots. He'd fish while I drank all his beer and puked on his deck. We would laugh, I'd get punched in the face. We'd laugh some more. I'd swim ashore. Good times.
Reason: added description
