Old 10-16-07, 01:14 PM   #1 (permalink)
DTAYLOR's Avatar
USPS power seat won't move back
Just developed this issue last night. The US passenger front seat won't move back, but moves all other directions.
Search no help.
DTaylor
96 FZJ80, Performance Engine Overhaul; (crank worked; head shaved & flowed) Injectors flowed; Intake polished; Exhaust polished. PS Cooler; CDL switch; Cup holder. Silicone heater hoses, green coolant, Rustoleum ft bumper paint, Powdercoated engine junk.
03 Harley Davidson Road King
DTAYLOR is offline   Reply With Quote
Old 10-16-07, 01:22 PM   #2 (permalink)
bkgiii's Avatar
...it's the 'plug', I'll betcha'
I think it's the nylon gear assembly on the RF of the seat frame. I've had this happen twice - once per seat. In both cases, the little nylon threaded male 'plug' works its way out of housing, and the seat won't move back.
Dan's got 'em.....but you have to buy the entire nylon assembly.
Check your DS - LF of frame. The threaded 'plug' will be pointed at the door. Once you locate it..see if that same plug is present (or absent) on the PS.
'96 LX450 w/the Landtank Gen II MAF and the amazing ashtray mod.
bkgiii is offline   Reply With Quote
Old 10-16-07, 01:38 PM   #3 (permalink)
on the water
fishwater's Avatar
my PS seat did the same thing. i found that nylon plug in the floor...but only after i replaced the gear assembly with a new one from dan. D'oh!!
bkgiii, if he finds the plug and puts it back in, will the seat work? just curious.
'96 with ~230k, OME 850/860's, BFG 315 MT's, ARB front bumper, warn M8000, slee drag link/tie rod, scanguage, CDL/pin-7
fishwater is offline   Reply With Quote
Old 10-16-07, 04:41 PM   #4 (permalink)
Mine 96 is the same since the day that I bought it. I've always thought it was a issue with the contacts since I can get it to move back after playing with the switch. I'm gonna check this weekend if the plug is off.
96 LC - lock'd & stock
92 Lexus SC400
92 MR2 Turbo
87 MR2 - Hi-Comp
86 Corolla GTS
06 530i Sport
Rondawg is offline   Reply With Quote
Old 10-16-07, 07:49 PM   #5 (permalink)
If it's the missing plug then sure it will work after the plug is screwed back in. This happened to my DS seat the other day!
'97 LX450, 148k miles, stock
Options20002001 is offline   Reply With Quote
Old 10-16-07, 07:55 PM   #6 (permalink)
Arya Ebrahimi's Avatar
Yup, mine fell out, I screwed it back in and it worked just fine again.
HOKIES UNITED
Mobile Base Camp Trailer Build
Arya Ebrahimi
'94 FZJ80 220k miles, locked, 4.88s, 285 Revo's, ARB Bullbar, Hella 4000's, homemade drawers
'86 Toyota Pickup SAS'ed, welded, 4.88s, 38 TSLs, and lots o' tube
Arya Ebrahimi is offline   Reply With Quote
Old 10-17-07, 02:36 PM   #7 (permalink)
DTAYLOR's Avatar
Seems I saw a rogue plug laying on the RF floor a week or so ago..
Now if I can just remember where I stashed the damn thing....
DTaylor
Old 10-17-07, 02:41 PM   #8 (permalink)
DTAYLOR's Avatar
Does it literally screw back in?
DTaylor
Old 10-17-07, 03:19 PM   #9 (permalink)
Yup. I had to remove the seat(4 bolts and a plug or two) to figure out where it went and to be able to have screwdriver access, but it was as simple as screwing it back in and bolting the seat back down.
HOKIES UNITED
Arya Ebrahimi
Old 10-17-07, 06:00 PM   #10 (permalink)
concretejungle's Avatar
TLCA# 14646
hahaha, yep, i bet it's the plug!!
Mine popped out and my seat wouldn't move back. I ended up putting a piece of duct tape over the plug to keep it in. Worked so far.
95' FZJ80 OME med./J lift, ARB rack, ARB Bull Bar w/tmax 12,500, 35" truxus, Aussie locker-rear, Center Diff Lock, Sliders, IPOR Skid, IPOR rear bumper, upgraded slee sticker, custom dents, more to come. . .
Go 80, or go unsatisfied
concretejungle is offline   Reply With Quote
Old 10-18-07, 09:44 AM   #11 (permalink)
DTAYLOR's Avatar
Got it. Fortunately, I didn't have to remove the seat. I just used a flat blade tip from a variable tip screwdriver and turned it with a small cressent wrench. 5 minute job, all is fine now.
Thanks to all.
D
DTaylor
