80-Series Tech Tech regarding the 80/81-series Land Cruiser, including the Lexus LX-450 -- FZJ80.com
Old 06-20-04, 10:36 AM   #1 (permalink)
scottm's Avatar
Tie rod ends
I need tie rod ends, don't mind a few extra $ for cdan quality and service. I'll be ordering an OME steering damper (or two), should I just get the tie rod ends that way too? Probably Slee for OME.
'03 UZJ100: wife's ride; '97 FZJ80: Traded in; '97 FZJ80 40th: Totalled; '03 4R; '06 Specialized Epic Comp Disk: Daily Driver; B-737: company vehicle
"if thou would have peace, be thou then prepared for war".
"Except for ending Slavery, Fascism, Nazism and Communism, WAR has never solved anything." - Ronald Reagan
scottm is offline   Reply With Quote
Old 06-20-04, 05:50 PM   #2 (permalink)
I've never ordered 80 series tie/relay rod ends, but if they are like all previous TLCs, each end will come with a rod. Dan can tell you.
SOR indicates the tie rod ends are $45 each, which is probably list price. The relay rod ends are $50 and $54.
1972 C2500 long bed, 2005 Odyssey, 2008 Tundra double cab
Idaho
cruiserman is offline   Reply With Quote
Old 06-20-04, 06:18 PM   #3 (permalink)
Tooth Fairy's Avatar
I just picked up the whole heavy duty kit from Slee and I would do that again.
Hardcore stuff at a good price. Plus the rods are galvanized so they look really kewl.
'93 80 w/340k and I think it's got one fender and one door that aren't rock enhanced. All the other mods were done with tools.
'77 40 - mental project at this point.
Tooth Fairy is offline   Reply With Quote
Sponsor 06-21-04, 12:47 PM
Sponsored Link
advertisement
Old 06-21-04, 12:47 PM   #4 (permalink)
Charismatic Megafauna
Jomama's Avatar
Question Help?? Need Part Numbers?
So I tore the two rubber boots on the Tie rod ends, passenger side, where they attach to the knuckle arms, when I was doing my front axle service....
Can I replace just the rubber boot part?? Or do I have to replace the whole tie rod end? (which means having to go thru the whole alignment process as well???)
How do you reinstall a new boot?
How do you get it full of grease? I cant believe these things don't have zerk fittings?
Cdan? can I get a part #?
2008 Tacoma Dbl Cab 4x4 Long Bed SR5, 265/75R16 Bridgestone APT, Leer Shell.
*sold* /cry....... 1993 FZJ80, 160k, ARB Bullbar, OME J's, Slee Castor Plates, 285/75R16 BFG AT/KO's, HIR's, Slee Headlight Harness, Belli Horns.
1996 Triumph Tiger
"Nature is not more complex than we thought, it's more complex than we can think"
Jomama is offline   Reply With Quote
Old 06-21-04, 01:24 PM   #5 (permalink)
Parts Geek, M1 Mechanic
cruiserdan's Avatar
Gotta buy the end to get the boot, sorry. The ends are greased during assembly and are not greased thereafter.
Original owner 93 FZJ80,locked,blown,water/methanol injected(like a WWII fighter aircraft),lifted,winched,snorkeled,slidered,Sleeed ,moneypit. Balanced on a pin head. 95 FZJ80 trail truck (hers), 94 FZJ80 320K with a knock. 2009 Dodge Challenger SRT8, 425 horse, 6 speed manual trans, cop-attracting-red.
http://i487.photobucket.com/albums/r...Gastrap063.jpg
http://i487.photobucket.com/albums/r...frifles004.jpg
Old 06-21-04, 02:15 PM   #6 (permalink)
Jomama's Avatar
Question
Ok, that kinda stinks...
Can I get the P#'s for this? Much obliged, thanks
Do they only come in a set of 4?
Or can I get the two I screwed up? that go on either side of the PS knuckle?
Yr truck 1993.
1996 Triumph Tiger
Old 06-21-04, 02:32 PM   #7 (permalink)
Chris_Geiger's Avatar
I have about 100 FJ80 tie rod end boots in stock. These are all new Boots.
We are giving these away free. All I ask is you pay our $10 shipping fee.
Call me at the shop and I will send you a few.
559-252-7295
Chris_Geiger is offline   Reply With Quote
Old 06-21-04, 03:02 PM   #8 (permalink)
Jomama's Avatar
Question
Chris.
I thought that we'd arranged a similar deal just a few weeks back when I originally tore up the boots. I then PM'd you again when the forums changed, but never heard anymore from you. No worries, I just wasnt' gonna bug you about it, I need to get this done.
With that little spring inside there? how do you install a new boot and get the grease inside it? It doesn't even look like I can take the end apart with standard tools? So if thats necessary me thinks I need the whole end?
1996 Triumph Tiger
Old 06-21-04, 03:18 PM   #9 (permalink)
Jomama's Avatar
Question
Got your PM Chris thanks.. You folks a Marlin are really top notch..
Mabey this can be added to the FAQ?
I'm sure I wont be the last one to take that stupid tie rod fork to those poor rubber boots...
Am I going to be able to put the new boots on the old end, full of grease, with the little spring actually holding it on correctly?
I still need to check the FSM...
Just concerns me that toyota only sells it as the whole complete TRE...
1996 Triumph Tiger
Old 06-21-04, 03:26 PM   #10 (permalink)
Your boots are on their way.
Just fill them with grease, slide the boot in place, then slide the spring on. Now your ready to bolt on the rod end.
Old 06-21-04, 05:09 PM
Sponsored Link
advertisement
Old 06-21-04, 05:09 PM   #11 (permalink)
scottm's Avatar
I just did a couple oil changes. The boots on my wife's '97 are all shot, and the joints are loose. The boots on all mine look good, and the joints are tight. Same mileage. I suspect the joints will go bad about when the boots are in need of replacement. Sound reasonable?
