#121 |
(pronounced rod-ree)
Frank,
I let my truck warm up to 120 F this morning and drove on the freeway to work. It took me about 13 minutes to get there. In that time the water temp rose to 179F, and my Air Intake Temperature was 49F. I sat in drive for 10 minutes and the WT did not rise at all. The AIT rose to 55F. Outside temp was 31F. I might wait for this one. When I get out of work tonight it will be around 37F. |
#122 |
Thanks Ruadhrigh!
![]() I didn't know it was that cold where you are! ![]() Over here is it 30 degrees C which is 86 Degrees F I suspect that will have a big influence... Is there anyone else oin a hotter climate that might be able to give me their results? __________________ Regards, Frank 93 80 series 4.5L Twin Cam Petrol with lots of accessories and mods Check out the Digital Engine Temp Gauge w/Alarm to overcome OEM DEAD SPOT |
#123 |
Just got the OK to go ahead and purchase the Scangauge II - do I need the extra cable???
__________________ 1985 FJ60 Stock *SOLD* 1997 LX450 Locked and Stock 1973 VW Super Beetle 1987 Honda CMX250 2005 Subaru Impreza RS (DD) 2005 Subaru Forester (Wife's DD) |
#124 |
nope, I routed my and mounted it above the mirror and still had cable length left.
__________________ 97 fzj80 (black) , locked, CDL, PHH, inverter, ipod, spare tire mod. temp gauge mod. 305/70-R16 Toyo Muds, OME 850/860, Slee Shortbus, Warn Winch, LandTank MAF.
#125 |
I got mine yesterday, I love it. Anyone who is OBD2 should have one of these!
__________________ Fly Rod '95 FZJ80 with stuff. I have a double handed rod... ![]() Jefferson State Cruisers |
#126 |
I'm curoius. Do you guys think there would be some savings of fuel buy having one of these installed so you can keep an eye on mpg?
__________________ Pat Doyle 1994 White FZJ 80, CDL switch. rear winch hitch attachment .-SOLD 1996 White FZJ 80, seats 7,leathered up, CDL,Locked,LandTanks MAF.2" OME lift/Shocks. |
#127 | |
Anyone else been able to improve thier milage? __________________ Fly Rod '95 FZJ80 with stuff. I have a double handed rod... ![]() Jefferson State Cruisers |
#128 |
Dumbass rookie dough-head
I find that I keep my readouts as follows:
1 (top left) - instantaneous mileage 2 (bottom left) - "today's" mileage (xgauge) 3 (top right) - water temp 4 (bottom right) - varies (load, IAT, open/closed, volts, HP, TPS, LTFT are the usual suspects) Yes, I have changed my driving habits. Keeping freeway speed down helps a lot. Manual throttle control (and sometimes shift control) helps in borderline situations. However, cruise-control is VERY convenient. It's surprising to me that having cruise-control handle steep, high-altitude, grades and slowly losing speed garners better MPG than forcing the transmission to a lower gear, and higher RPM with less throttle. Mileage SUCKS around town, pretty much no matter what. __________________ 1997 LX450, 132K, Lockers, LEDs, Nak-o-matic mic holder, CDL w/ Pin 7, 285/75R16 BFG AT, Tool Sleeve, Slee armor, Slee speedo gear, OME 2.5" Heavy, Prophylactic HG, Line-X in place of LX trim KD0CXL "You don't get to vote on the way it is... you already did!" But you do get to vote on the way it will be."... but you have to compare it to the current political process where idiots elect liars to transfer wealth to crooks." -- Scott Adams "Damn you, Hants White!" -- Dan-The-Man ![]() |
#129 |
I hate when cruise control is on and the tranny shifts to low on a hill. I have the land tank redesigned MAF that helps a little.
__________________ Pat Doyle 1994 White FZJ 80, CDL switch. rear winch hitch attachment .-SOLD 1996 White FZJ 80, seats 7,leathered up, CDL,Locked,LandTanks MAF.2" OME lift/Shocks. Last edited by PDoyle; 05-14-08 at 11:37 AM. |
#130 |
Does the Scangauge report any info on airflow from the MAF sensor? I curious if its possible to show an increase in airflow with the MAF mod.
__________________ '96 FZJ80 Member Rising Sun Chapter TLCA KC0ZAC |
#131 |
I don't see anyway it can show airflow, but mpg feature has definately helped me reconsider my driving habbits. I've found that the best mpg is around 50-60. Above 60 is starts to drop rapidly. I like to cruise around 70 mph, but getting only 11-12 at 70 verses about 14-15 at 60 at today's prices is hard to ignore. Also, for really long trips, where gas is an issue, that's a major difference on range. About 275 miles verses 350. Obviously, when you combine some lower speed or city driving the range and average mileage goes down.
I also surprisingly found that low speed driving sucks major, major gas. Driving around the fire roads at low speed, I'm constantly seeing mid to high single digits. Which means a further reduction in average mileage and range. Basically, the heavy Land Cruiser, especially with my weight and mods, does not like low speed or very high speed driving. It's most effecient somewhere in the middle. __________________ 1995 FZJ80, modified for regional expeditions. Click here for more... My main website: In Search of History Expeditions Foreign Toyota 4x4s Military Toyota 4x4s |
#132 | |
I don't recall if the Scangauge shows it or not. __________________ 1997 LX450, 132K, Lockers, LEDs, Nak-o-matic mic holder, CDL w/ Pin 7, 285/75R16 BFG AT, Tool Sleeve, Slee armor, Slee speedo gear, OME 2.5" Heavy, Prophylactic HG, Line-X in place of LX trim KD0CXL "You don't get to vote on the way it is... you already did!" But you do get to vote on the way it will be."... but you have to compare it to the current political process where idiots elect liars to transfer wealth to crooks." -- Scott Adams "Damn you, Hants White!" -- Dan-The-Man ![]() |
#133 | |
tlcwagons.org
#134 | |
Hopeless Cruiser Addict
Good info Hants... As for the Scangauge, there is a MAF selection but it comes up blank (no data) when selected. Guess the ECU doesn't pass the info or Scangauge doesn't know the "code" to get the data. Sort of like the AT temp I'd REALLY like to see.
__________________ '97 LX450 aka "The Whale" with a winch called Damien '97 FZJ80 40th AE, Antique Sage, #267 '74 FJ40, 2F, SM420, 4" Lift, ARB locked front and rear, 33" MTRs '76 FJ40, 2F, 4-speed, 4" Lift, 33" BFG ATs (SOLD)
#135 |
I am not sure if this cable will allow the fuse panel cover to be put back on without having to rotate the OBDII connector, but it is a right angle J1962 connector for the scangauge.
OBD2Cables.com Rich __________________ '97 FZJ80 (03/08 - present) '83 FJ60 (11/99 - 12/00, sold) '85 FJ60 (11/98 - 3/08, freed to a good home) '78 FJ40 (03/98 - present) '76 FJ40 (10/94 - 11/97, stolen, but not forgotten) Last edited by thugmusk; 05-30-08 at 09:15 AM. |
#136 |
The Scangauge cable is the same as that one. You can unscrew the OBDII port mount and flip it up under the dash and the cover goes back on.
__________________ Adam 96 LC, OME 851/860, BFG AT 285, Metaltech sliders, IPOR skid, Yellowbox, Landtank seat brackets & MAF, ScangaugeII, Slee harnesses with HIRs & Hella 500s, CDL & Pin 7, George's LEDs, Slee-located washer bottle, 'MUD sticker OME CC bushings for sale
#137 |
Ahh, thanks,,, I was thinking the hassle with the cover was because the Scangauge cable was not a right angle.
__________________ '97 FZJ80 (03/08 - present) '83 FJ60 (11/99 - 12/00, sold) '85 FJ60 (11/98 - 3/08, freed to a good home) '78 FJ40 (03/98 - present) '76 FJ40 (10/94 - 11/97, stolen, but not forgotten) |
#138 |
Does the Scanguage report on transmission temps?
__________________ 1997 FZJ80 factory locked, OME 850/863 N73/N74E, Landtanks seat extension,slees light harness, HIRs, HID off-roads, slees off road light harness. Future projects; rebuild front axle, 150amp Alt.... |
#139 |
Hate that mud...
Read through this thread and you'll have your answer - around page 3 IIRC.
__________________ Tom Ferrin N6TEF - 2m and 70cm 1989 FJ-62 - 200K, 3" OME lift, recent engine overhaul, my daily driver 1997 FZJ-80 - 85K, lifted, bumpers, sliders, lockers, and Moab-trails tested |
#140 |
Do they ahve this type of scanner for FJ62's or are we screwed because we have ODBI? Any conversions? thanks.
#142 |
not for me... consistently much higher than that. i will get some hard numbers for the group over the weekend.
#143 |
#144 | |
With the stock filter I get about 20 degrees consistently over outside air temp once the truck is moving. __________________ 1996 FZJ 80, 1973 FJ 40 |
#145 |
Did anyone have to force it to connect?? I just installed mine and it says Connecting... and then turns off. Anyone have this problem?
__________________ '96 LX 450 67K locked, ARB Bull Bar, Slee 6", Slee step sliders, Slee rear tire carrier, slee skid, CDL, 315/75-16 MTR's, etc. ROTW '07 FJ Cruiser locked, 285/70-17 MTR's Copper State Cruisers #38 TLCA #15560 Rob Clark
#146 | |
__________________ 97 FZJ80, Locked & Loaded, Safari Turbo, Safari Intercooler, LandTank MAF, HKS Turbo Timer, 3" Ceramic Coated Exhaust, OME HD 2.5" Suspension, DBA Slotted Rotors, ARB Stuff, 33" Revos, Center Diff Switch, Slee Stuff: Roof Rack, Step Sliders, TC Skid Plate, SS Brake Lines, DC Drive Shafts. HG PM'd, My Rocky Mountain Mojo Mobile! |
