LinkBack (13) Thread Tools Display Modes
Old 08-24-07, 01:46 PM   #31
Dive on in...
NaterGator's Avatar
TLCA# 18767
Originally Posted by JO MAOMA View Post
what am i missing, is someone not running a oem thermostat or is
cpg's rig essentially air cooled even when towing on a steep grade....
....maybe my rig needs more work on the cooling system than i thought.
Just my experience. There is probably some variance and I don't know what most others see.
The FSM test procedure states that the thermostat should open between 176-183°F and lift at least 10mm by 203°F. Perhaps I just need a new tstat.
'96 LX450, 33" Revos, OME lifted, etc, etc
Love the life you live, live the life you love. -Bob Marley
Selfishness is not living as one wishes to live, it is asking others to live as one wishes to live. -Oscar Wilde
Firefox users, get your youtube on!
NaterGator is offline   Reply With Quote
Old 08-24-07, 04:30 PM   #32
You want to do what...?
e9999's Avatar
interesting
can one set an alarm on that reader?
Hard to believe that the mpg readings would be very accurate. What sensors -if any- does it use for that?
'97: 88K, 3xlock, Custom HD roo bar for sale, 285 MT/Rs on steelies, Hanna sliders, 851+1.5"/863/N73/N74E/SD24, ARB bull with M12, Kaymar with duals, Kaymar rack, Slee TC skid, 2m/440, more stuff, loose nut behind the wheel!)
'03: 99K, the better half's...
DD
souped up DR650
Old 08-24-07, 06:13 PM   #33
tlcwagons.org
FirstToy's Avatar
Wow, I'm surprised by my readings! This is just in-town today
ambient temps (95-100 degrees)
air intake temps (145-172)
Air Conditioner ON the whole time
stock temp gauge never moved from horizontal
-from cold to 185-190 (city streets, stop n go, easy)
-195-198 (freeway)
-parked for 15min -
-213 on startup-heat soak! (172 intake air temp), quickly went down to 193
-200-204 (freeway, slight grade)
-198-204 (city streets)
TLCA#14645
BRC#41798
I love cachapas!
my wip
I drink your milkshake!
Old 08-24-07, 06:37 PM   #34
cpg
cpg's Avatar
TLCA# 2329
oem THERMO STAT. Just last weekend going up highway 17 never went over 190 going down went down to 170.
1996 FZJ 80, 1973 FJ 40
cpg is offline   Reply With Quote
Old 08-24-07, 06:41 PM   #35
tlcwagons.org
FirstToy's Avatar
cpg,
wonder how your temps are so low? maybe I need a new radiator?
I have new fan clutch, t-stat, coolant, rad in good shape...
170-190 is a big difference than mine doing 190-204...
*oh i noticed the side plug on the Scangauge so i flush mounted right on the edge between the insturments and steering colum- shielded from glare, doesn't block the warning lights.
TLCA#14645
BRC#41798
I love cachapas!
my wip
Old 08-24-07, 07:03 PM   #36
cpg
cpg's Avatar
TLCA# 2329
Originally Posted by FirstToy View Post
cpg,
Thats why I replaced the radiator. When I did ravens mod on the stock gauge I was shocked how often it was getting near the red. I had the scan gauge for a while before I changed out the cooling parts and was getting over 200 often but only when there was a hill involved. I think my old fan clutch cooled better than the new blue hup before it was modified. But after modifying it it seems to keep it about 5 degrees cooler. My intake air temps seem lower than most to I have never seen it over 145. I have a long copper pipe for my shower I dont think it helps cool any more maybe it does runs almost the length of the block?
The pic of the scan gauge was last March in Baja about 90 degrees outside.
This is before I modded the fan clutch. On any grade it would rise to 195. After modding it I can keep it around 190.
Old 08-24-07, 10:04 PM   #37
Trunk Monkey's Avatar
TLCA# 11251
Very accurate. You reset when you fill and it learns. Miles driven divided by fuel used, pretty basic.
Cory Fillmore
TLCA Western Individual Representative
99 UZJ
100 Series Wheels FOR SALE-CLICK HERE
Trunk Monkey is offline   Reply With Quote
Old 08-25-07, 10:39 AM   #38
e9999's Avatar
and how does it know accurately the fuel used, exactly?
DD
souped up DR650
Old 08-25-07, 10:43 AM   #39
e9999's Avatar
cpg, I wonder if there is something off with your gauge or sensor or thermostat?
if the thermostat starts to open around 180-185, it is highly unlikely you would get any lower than that coasting down at high temperatures outside since the fan / rad are no longer in the picture when the thermostat is closed.
DD
souped up DR650
Old 08-25-07, 10:48 AM   #40
Dive on in...
NaterGator's Avatar
TLCA# 18767
Because it can calculate the GPH based on the parameters the ECU provides.
Trust me, it's accurate. Always within 1% all said and done at the end of the tank.
Old 08-25-07, 10:56 AM   #41
cpg
cpg's Avatar
TLCA# 2329
I am not sure if the gauge is correct. While coasting down hill I am pretty sure the air flowing thru the engine bay will cool it off easily since it is idling only also the water in the rad will be cooled.
Old 08-25-07, 11:07 AM   #42
e9999's Avatar
that's good. Not sure how the ECU can quantify gas flow that accurately, though. From injector parameters?
on the 100 Navsys, the avg mpg is easily off by 0.5 mpg out of 17 or so, in my experience.
DD
souped up DR650
Old 08-26-07, 12:31 PM   #43
tlcwagons.org
FirstToy's Avatar
after talking to some people, I think the temps at 190-200 are normal. What I don't know yet is how the temps react in trail conditions, but will keep an eye on it.
TLCA#14645
BRC#41798
I love cachapas!
my wip
Old 08-26-07, 12:57 PM   #44
i went over rubicon and my temp maxed out at 191. Thats with new rad tstat fan clutch and hoses.
i think it maxed out going up 49
Maynurd is offline   Reply With Quote
Old 08-26-07, 01:22 PM   #45
TLCA# 11251
Been really good for me. Usually don't have the AC on tho.
Cory Fillmore
99 UZJ
Old 09-02-07, 01:09 PM   #46
livinoffroad's Avatar
While mounting your Scangauge II to your 1995 fzj 80, has anyone noticed how many wires go to the OBD II port ? I count 4, but don't know if that is factory original, or if the PO has been in there before me. I would appreciate some feedback, as my Scangauge II is on order.
'95 80 locked on 33s, OME 863/850 springs w/30mm spacers in front(no stink bug), caster correction drop brackets, ss brake lines, DBA slotted rotors, odyssey 1200, CDL, HIR, scangauge II
'93 4x4runner (sold)
'85 4x4 mini truck/22re (sold)
'80 4x4 Chevy P.U. Snowplow
'86 4x4 MasseyFerguson 1045
livinoffroad is offline   Reply With Quote
Old 09-02-07, 02:27 PM   #47
JO MAOMA's Avatar
four wires is the correct answer.....
"Mate , you must drink some serious piss to need to
get to youre chilly bin that quickly." - topend yobbo
JO MAOMA is offline   Reply With Quote
Old 09-10-07, 11:01 PM   #48
beno's Avatar
TLCA# 14607
Well, I've been borrowing a Scangauge for a few days (thanks Ruadhigh) and as expected my temps. rarely every get over 194*....
Some recordings:
City/highway/traffic/idling driving style: IA: 104*-127*; WT: 188*-200*.
The only time the WT ever went over 200* was after the engine was shut off and immediately after that the temps sometimes read around 204*.
I am going to wheeling on Sunday and I am going to bring this again and see how it does after about 3-4 hours of stop and go, slow moving, high torque, low air movement situations.
I feel much better about my cooling system (though I am overly anal about it anyway) after seeing these readings.
Useful tool. I'm going to get one in the future.
Cheers.
-onur
1997 FZJ80 with and without lots of stuff.
2001 Honda Accord 3.0L V6 VTEC Coupe EX.
beno is offline   Reply With Quote
Old 09-11-07, 12:41 AM   #49
tlcwagons.org
FirstToy's Avatar
onur,
I would love to hear how the temps react. On a recent trip, my truck lived at 195-ish no matter what. It hit 203's on a freeway grade pushing it... from cold, going easy around town, it is around 185
maybe I have to look at my radiator...
thanks
TLCA#14645
BRC#41798
I love cachapas!
my wip
Old 09-11-07, 09:26 AM   #50
e9999's Avatar
when I'm wheeling, in relatively hot weather (say 90F), at low speeds but reasonable power I'm usually around 195-205F (from memory). If I'm doing steep hills up in low in hot weather and low speed for long periods of time, it can go up to 215 or even 220F or so but that's rare.
DD
souped up DR650
Old 09-11-07, 02:05 PM   #51
tlcwagons.org
FirstToy's Avatar
Eric, you being you, I imagine your cooling system is in top condition?
TLCA#14645
BRC#41798
I love cachapas!
my wip
Old 09-11-07, 02:24 PM   #52
peepers's Avatar
has anyone programmed their scan gauge II for 4.88 gears and 35" tires? i can't figure out how to do that...
help please.
peepers is offline   Reply With Quote
Old 09-11-07, 02:28 PM   #53
e9999's Avatar
well, I thought so, but now I've read some posts about folks getting much lower temps that what seemed normal earlier, so I may have to dig in...
I haven't done anything to the fan yet but that seems interesting.
DD
souped up DR650
Old 09-11-07, 02:38 PM   #54
tlcwagons.org
FirstToy's Avatar
peepers,
the way I did it is to go into the MPH choices-->MPH or KPH-->and then there is a % correction in 1% incriments. So if you are 5% off, punch it in.
sorry, don't know how to calculate gear+tires... if you have gps, you can compare the scangauge and gps and punch in % until it matches...
Eric, you mean you don't have the blue fan clutch or that you want to add an aux fan like Romer? Do you have a new radiator?
TLCA#14645
BRC#41798
I love cachapas!
my wip
Old 09-11-07, 02:59 PM   #55
Hopeless Cruiser Addict
corsair23's Avatar
peepers,
x2...Unless Scangauge has updated the software to handle this differently you simply go in and adjust the "adjustment %" up or down compared to stock. Mine is like a 5.45% increase compared to stock and IIRC the Scangauge offers adjustments at .1% increments so you can get pretty close.
I know (when I remember) to input my #'s on fillup it is pretty close to spot on with what Scangauge estimates I used fuel wise to what I actually put in.
'97 LX450 aka "The Whale" with a winch called Damien
'97 FZJ80 40th AE, Antique Sage, #267
'74 FJ40, 2F, SM420, 4" Lift, ARB locked front and rear, 33" MTRs
'76 FJ40, 2F, 4-speed, 4" Lift, 33" BFG ATs (SOLD)
corsair23 is offline   Reply With Quote
Old 09-11-07, 03:14 PM   #56
peepers's Avatar
peepers,
