While I have the head out and doing the HG replacement, I wanted to get the sensor bung installed on the exhaust manifold for a wide band oxygen sensor. I have searched the archives and done a bit of calling to vendors and have compiled the following Wide Band O2 or Air/Fuel gauge options:
- AutoMeter ATM-5778 (Phantom), working range: 10.0 to 20.0; 2-1/16", ~$350
(I have a Phantom series EGT gauge that would be nice to match.)
http://www.autometer.com/search_results.aspx?q=wideband air/fuel
- AutoMeter ATM-6478 (Nexus w data logging), working range: 10.0 to 20.0; 2-1/16", ~$400
- Innovate G2, working range: 8.0 to 18.0; 2-1/16"; ~$289
http://www.innovatemotorsports.com/products/MTS.php
- Innovate DB; working range: 8.0 to 18.0; 2-1/16"; ~$289
- Innovate G3; working range: 8.0 to 18.0; 2-1/16"; ~$289 Kit
- Greddy p/n16000811; working range: 8.0 to 16.0, 60mm (2.36") Dia; ~$340
http://www.greddy.com/products/display/?Category=electronics&SubCategory=57
- Westach dual A/F - Water Temp degF; working range: 10 to 17; 2"; ~$200
http://www.westach.com/
(Westach as has been pt'd out offers custom gauges with daul-gauges a relatively inexpensive choice - (4) week lead time; they can do the wide band A/F as a single gauge as well.)
- Spa Technique was mentioned but could not find a wide band O2 gauge on their website:
http://www.spatechnique.com/product_pages/gauges.asp
Vendors: Egauges, Summit Racing, JEGS, direct from the mfg
Anyone have others to recommend??
Where along the exhaust are you mtg the bung for the sensor? Upstream from the OEM O2 Sensors? Could install it right next to the EGT sensor that is already on the Y-pipe just down from the cast iron exh manifold.
The Greddy looks greaty but its a lot bigger and likely impossible to fit up in the pillar gauge pod that I have. As I understand it, the work being done on the modified MAF by landtank would require a gauge/sensor pkg that can see below the 10.0 range limit the Auto Meter's can provide. That seems to leave only the Innovate or the Greddy units.
Appreciate any comments! Thanks.
