Old 07-24-07, 09:51 AM   #31
Tube is your buddy!
helocat's Avatar
TLCA# 1137
Originally Posted by IdahoDoug View Post
I have no hand in what's moving into a debate on force, but I think it's *very* important to differentiate between the very low forces on a slider of dragging it over rocks or lifting with it and what happened here.
Merely lifting a vehicle is child's play - let's call it 3000lbs if you are lifting 50% of the truck's weight with a hi-lift (you aren't). Dropping a 6000lb truck only a few inches may generate a peak force of many times that - say 40,000 lbs - if the surface it hits does not deform (like a rock).
It's why you can try unsuccessfully to push a nail into a board by standing your 175lbs on it all day. Then easily do it with a 1lb hammer in 3 strikes.
DougM
IdahoDoug is nailing it here. (Pun intended with his analogy) Rolling is a whole other chapter when it comes to forces and how things are designed for them. Sliders should not be designed for a roll, period. If you are designing for a roll in an FZJ80 then cut body and properly cage it. Not just web wheeling here, Metal-tech shipped its 400th roll cage two months ago for FJ40’s.
.188” wall box sliders are structurally speaking close to the lower section of the Metal-tech sliders. The lower section is CNC laser cut from a flat plate of .188” and then CNC formed to the shape shown below. All four of the bends are facing the direction of outside impact. (vrs. Standard box where there is only two) The .250” laser cut internal vertical gussets are then put in like ribs in a wing. The ribs are over kill and are what send it off the chart in strength.
We then go and put the two stage rub rail on the outside to help protect the upper body of the truck. Also don’t forget the one piece .500” laser cut and formed and reinforced plate that is the front mount and cat guard on the right side, these crush rocks.
Metal Tech supports the efforts of http://anysoldier.com go to this site to learn how to send a care package to a US Solider in the hot zone.
93' FZJ80 (aka: NEWPIG) - 97' FZJ80 - 79' FJ40 - 78' FJ40
helocat is offline   Reply With Quote
Old 07-24-07, 12:20 PM   #32
CreeperSleeper's Avatar
TLCA# 15577
Originally Posted by steveVA View Post
"At this point I told my passenger I was going to take one more shot at it, then back down and claim defeat."
I have learned in my short 35 years that whenever you say "one more" thats when you get into trouble..ie. im going to catch "one more" wave, "one more" run on the snowboard, "one more" lap on the MX track.. So I NEVER say "one more" anymore..
Sorry about your "one more"!!
Yeah, I know... I just can't stop myself!
Chad
Cascade Cruisers- President
KE7VSA
Views from the Creeper
MetalTech
Originally Posted by DanKunz View Post
You stacked rocks to climb your porch......HA!!!
CreeperSleeper is offline   Reply With Quote
Old 07-24-07, 12:34 PM   #33
TLCA# 15577
Okay, here are more pics of the slider...
As you can see, I didn't touch the main part of the slider at all, just the rub rail...
This is how much it moved... I'm, personally, very impressed. That was a lot of force!!!
Here is a different trip up Can-Opener when I was testing the sliders. I was sliding sideways into the rocks here:
Chad
KE7VSA
MetalTech
Old 07-24-07, 12:36 PM   #34
Hopeless Cruiser Addict
corsair23's Avatar
I can vouch for that!
I've hit that sucker so hard on rocks only to get out to look at the damage and see...well not much of anything . A little scrape if that on the guard while the rock was looking much worse for the wear. I'm still struggling with not cringing everytime I hit my sliders, but that is just because they're so damn purdy I don't want to scratch 'em up, because they definitely are stout
'97 LX450 aka "The Whale" with a winch called Damien
'97 FZJ80 40th AE, Antique Sage, #267
'74 FJ40, 2F, SM420, 4" Lift, ARB locked front and rear, 33" MTRs
'76 FJ40, 2F, 4-speed, 4" Lift, 33" BFG ATs (SOLD)
corsair23 is offline   Reply With Quote
Old 07-24-07, 02:23 PM   #35
Pursuance of Vacuity
Mars's Avatar
Good points about the sliders. That tubing took a serious hit and only deformed a few inches...that's pretty good in my book.
1999 Tacoma TRD
Originally Posted by dieseldog View Post
I mean, after all--how many construction jobs do you get to wear skimpy sequined gowns, high heels, and hugh feathered headpieces?
Mars is offline   Reply With Quote
Old 07-24-07, 06:39 PM   #36
Wrench's Avatar
Wow the pics of the slider doesn't look bad after all. Not bad for the force it took.
<>< 1996 FZJ80 With all the goodies to make it go anywhere.
For Genuine Toyota Parts Call Cruiser Dan at 1-800-432-6668 ext. 8
Wrench is offline   Reply With Quote
Old 08-02-07, 01:08 AM   #37
LT
Metal Tech
LT's Avatar
TLCA# 12989
Damn Chad... it was going to happen some time. Time for the sawzall!
As for the rub rail bending I am not surprised on that obstacle. I tried it back when it was covered in snow and ice. It is a full throttle assault just to get past the first rock (couldn't even get past the first rock). I am pretty sure knowing Chad he had the rev limiter bouncing trying to get up that last part. Having a 6,000 lb truck land on those rocks, pretty much was the kiss of death.
It is far different when you are slowly crawling over rocks as Mark and I did at Katemcy. We thoroughly hammered our sliders on his 80 series have some serious deep scoring in the tubing. In the case of Chad this was sheer momentum. If you look at rock crawling buggies you will find that the DOM tubing is bent to hell and back from slamming into the rocks. And those suckers weigh in the area of 2,500 lbs. Everything has a breaking point.
BTW Chad you should of tired going down it for some extra pucker factor
Propane Powered 2f.
LT is offline   Reply With Quote
Old 08-02-07, 08:08 AM   #38
no bueno
Skillet's Avatar
TLCA# 16078
Ih8bodydamage
1993 FZJ80
1973 FJ40
oh no you didn't
"...mud is a hotbed of leftist chat/activity." - swank
Skillet is offline   Reply With Quote
Old 08-02-07, 08:26 AM   #39
Ride On...
lowtideride's Avatar
TLCA# 14891
In any case, your slider bent far less then your sheetmetal would have.
www.NFCruiserheads.org FJ45 Crawler and a 1983 Hilux...
has had no peers for 50 years...
lowtideride is offline   Reply With Quote
Old 05-21-08, 12:57 PM   #40
TLCA# 15577
No kidding! It's all taken care of now, I dropped them off at MetalTech and they retubed them for free! Thanks Mark and LT!
Chad
KE7VSA
MetalTech
Old 05-21-08, 01:01 PM   #41
Whitey
FJBen's Avatar
TLCA# 15530
that is some awesome vendor support for another great mud vendor.
93 FJZ80 Slee 4"/OMEJ, 35's, 4.88's, ARB's, Metal Tech sliders, M12000, On Board Air, caster plates, DC drive shaft, Pin7, CDL, adjustable rear uppers, ARB front bumper, homemade rear, Slee Skid Plate, extended brakelines, backup camera, Conferr Rack
96 FZJ80 285's OME 's ride
FJBen is offline   Reply With Quote
Old 05-21-08, 01:10 PM   #42
TLCA# 15577
No kidding. And (I think it shows on the first page) they saw this thread and told me to bring them in. I didn't ask for them to do that. MetalTech = the awesome.
Chad
KE7VSA
MetalTech
Old 05-21-08, 01:13 PM   #43
FJ40_owner's Avatar
TLCA# 16294
How much air pressure did you have in? Your tires look like they are not aired down.
Third generation Californian! If you don't like it here, leave. And take your fat wife and screeming kids with you.
FJ40_owner is offline   Reply With Quote
Old 05-21-08, 01:30 PM   #44
Roll Tide!
'74 UA FJ's Avatar
Well, it was bound to happen… Last Saturday, fate finally won and I flopped my 80. It was a soft flop, thank God, but a flop just the same. It was on an obstical called Can-Opener on Archer’s Firebreak in the Tillamook State Forest OHV trail system. Now I have made it up Can-Opener a few times, but always in the dry. In fact, the only time I ever tried it wet was to get the MetalTech rock slider shots! Well, this time I went for broke, and broke I did. The pics will show the body damage, but I also broke a passenger side Birfield. That makes two in a month… This is becoming an expensive year!
Here I am first starting up Can-Opener. This will give you some idea just how steep it really is:
Here I’m just approaching the hard section. If you have never wheeled in this area, take a look at my tires… The mud is like baby crap.
This is about as far as I made it on my first run. The majority of rigs stop right about here.
Setting myself up for a second attempt…
Denied… I’m going to need more momentum for this.
Crap… That didn’t work. I have to be farther up that wall… At this point I told my passenger I was going to take one more shot at it, then back down and claim defeat.
YES! I made it past the first rock! Now stay on it to keep momentum. In this pic, you can see just how much I’m side walling that hill. And it is still as steep as the approach!
Well, the cameraman couldn’t cycle thru shots fast enough, but this is after I laid it over and bounced back to my tires. It was here that I lost momentum.
And here that I broke the Birf…
My fearless passenger and best friend Jordan goofing around as we are waiting for the hook.
The depressing part of the story is a J**P got me to level ground! (Actually, that J**p is owned by Randy, who owns J&H 4WD in Portland, OR. This man is a master at recovery and I was very thankful to have him and his equipment along!)
DAMAGE PICS… Damn, lost another taillight… (BTW, look at the slider!)
Amazingly, everything still opens, all the windows work and no glass broke… Not even the mirror.
And for those who don’t know this truck, this is what it looked like when I bought it 2.5 years ago:
I didn't read the thread, so this may have been asked already. If so, I apologize.
Could you not just pop over the big rock and try the line straight up?
I feel you man. I just rolled my 40 on Saturday...
1974 FJ40 FI vortec 350, H42/Orion 4:1, 4" lift, 35x15.50 SXs on MRW beadlocks, lock-rited f/r, Saginaw ps, etc, etc.
1994 FZJ80 with lockers and 285 revos.
'74 UA FJ is offline   Reply With Quote
Old 05-21-08, 02:03 PM   #45
Nay
The New Avocado
Nay's Avatar
TLCA# 16030
Toyo MT's for sale
Amazing how much protection the step tube on sliders can provide, that saved your sheetmetal.
Back to that front axle - how are you going to make that thing strong enough for that kind of momentum wheeling?
Seems a lot easier to make an 80 feel smaller on big, grippy granite than in that boulder strewn slop. You need 40" Swampers for that kind of stuff
1995 FZJ80 - F.O.R. 3.5" lift - 35" trxus MT - 5.29's - Custom SROR Tube Bumpers - De-plasticized - Dented - Dieted
Nay is offline   Reply With Quote
Old 05-21-08, 02:27 PM   #46
TLCA# 15577
I probably could have if I didn't have those POS Toyo Open Country M/Ts!
Chad
KE7VSA
MetalTech
Old 05-21-08, 02:43 PM   #47
Roll Tide!
'74 UA FJ's Avatar
Time for some 38.5 x 14.50 SS SXs.
Old 05-21-08, 02:45 PM   #48
TLCA# 15577
Would be nice... *sigh*
Chad
KE7VSA
MetalTech
Old 05-21-08, 06:28 PM   #49
LT
Metal Tech
LT's Avatar
TLCA# 12989
37x14x17 bias ply Iroks.... you know you wanna
Propane Powered 2f.
Old 05-21-08, 06:55 PM   #50
IH8MUD Tour Guide
concretejungle's Avatar
TLCA# 14646
LOL, why do you all keep talking about saving his sheet metal? Have you not seen his truck?
I love it. I love to see someone taking the station wagon through the hard stuff!
95' FZJ80 OME med./J lift, ARB rack, ARB Bull Bar w/tmax 12,500, 315 Nitto, stainless brake lines, Center Diff Lock, Sliders, IPOR Skid, IPOR rear bumper, upgraded slee sticker, custom dents, more to come. . .
concretejungle is offline   Reply With Quote
Old 05-27-08, 01:10 PM   #51
TLCA# 15577
Why thank you! And it's true, there isn't much to save anymore!
Chad
KE7VSA
MetalTech
Old 05-27-08, 11:48 PM   #52
i dare anyone to post a pic of a bolt on slider supporting the entire side of an 80 via a highlift. home built or production. if the slider is the pass side and the highlift is toward the front you get bonus points.
97lx450
4" slee/j's, sliders, bumpers, 3" exhaust, custom turbo, HG pm/Valve job/seals, sweet custom skid plate, Sleeoffroad parts, Buys oe parts from Cruiser Dan
used to have 37" swampers..
1 tons and 42's pending.....
Budget Blown
98 100 series. rear locker.
2008 6.7L dodge 2500 quad cab
Dusty is offline   Reply With Quote
Old 05-28-08, 12:29 PM   #53
TLCA# 15577
Will a forklift work?
Chad
KE7VSA
MetalTech
Old 05-28-08, 12:56 PM   #54
LT
Metal Tech
LT's Avatar
TLCA# 12989
